    Config Help!
    9 Posts 5 Posters 10.0k Views 3 Watching
    • I Offline
      IArentBen
      Morning everyone!
      I’ve been trying to get my mirror running for the past few days but I am stumped! I cant get my config file to work the Magic Mirror screen pops up and says if you have a config file to lint it and I have. I rant the pm2 log and i says “mm-0 (err): WARNING! Could not find config. Please create one.”
      Would you please take a peek at my config file for me? If i missed an obvious step please let me know!
      var config = {
      	port : 8080,
      	language : 'en',
      	timeFormat : 24,
      	units : 'metric',
      	modules : [{
      			module : 'clock',
      			position : 'top_left'
      			config : {
      				timeFormat : 24,
      				displaySeconds : false,
      				showPeriod : false,
      				showPeriodUpper : false
      			module : 'calendar',
      			header : 'Calendar',
      			position : 'top_left',
      			config : {
      				calendars : [{
      						symbol : 'calendar-check-o',
      						url : 'webcal://www.calendarlabs.com/templates/ical/Canada-Holidays.ics'
      				maximumEntries : 10,
      				maximumNumberOfDays : 365,
      				displaySymbol : true,
      				defaultSymbol : calendar,
      				maxTitleLength : 25,
      				fetchInterval : 900000,
      				animationSpeed : 2000,
      				fade : true,
      				fadePoint : 0.25,
      				loadingText : 'Loading...',
      				emptyCalendarText : 'No Text to Display...',
      				todayText : 'Today',
      				tomorrowText : 'Tomorrow',
      				runningText : 'coming up'
      			module : 'currentweather',
      			position : 'top_right',
      			config : [{
      					appid : '6160806',
      					units : metric,
      					updateInterval : 900000,
      					timeFormat : 24,
      					showPeriod : false,
      					showPeriodUpper : false,
      					lang : en,
      					initialLoadDelay : 0,
      					retryDelay : 2500,
      					apiVersion : 2.5,
      					apiBase : 'http://api.openweathermap.org/data/',
      					weatherEndpoint : 'weather',
      					iconTable : {
      						'01d' : 'wi-day-sunny',
      						'02d' : 'wi-day-cloudy',
      						'03d' : 'wi-cloudy',
      						'04d' : 'wi-cloudy-windy',
      						'09d' : 'wi-showers',
      						'10d' : 'wi-rain',
      						'11d' : 'wi-thunderstorm',
      						'13d' : 'wi-snow',
      						'50d' : 'wi-fog',
      						'01n' : 'wi-night-clear',
      						'02n' : 'wi-night-cloudy',
      						'03n' : 'wi-night-cloudy',
      						'04n' : 'wi-night-cloudy',
      						'09n' : 'wi-night-showers',
      						'10n' : 'wi-night-rain',
      						'11n' : 'wi-night-thunderstorm',
      						'13n' : 'wi-night-snow',
      						'50n' : 'wi-night-alt-cloudy-windy'
      			module : 'newsfeed',
      			position : 'bottom_bar',
      			config : {
      				feeds : [{
      						title : "CBC Top Stories",
      						url : "http://rss.cbc.ca/lineup/topstories.xml",
      						title : "CBC Calgary",
      						url : "http://rss.cbc.ca/lineup/canada-calgary.xml",
      						title : "CBC World Stories",
      						url : "http://rss.cbc.ca/lineup/World.xml",
      				showSourceTitle : true,
      				showPublishDate : true,
      				showDescription : true,
      				reloadInterval : 900000,
      				updateInterval : 300000,
      if (typeof module !== 'undefined') {
      	module.exports = config;
      Note from admin: Please use Markdown on code snippets so it is easier to read!
      • F Offline
        feuerball
        did you rename your config.js.sample to config.js?
        I 1 Reply Last reply Reply Quote 1
        • P Offline
          PtrBld Module Developer
          There is a , missing After Position: line 8
          • I Offline
            IArentBen @feuerball
            @feuerball sure did!
            • I Offline
              IArentBen @PtrBld
              @PtrBld thanks but that didn’t do it either
              • K Offline
                KirAsh4 Moderator
                You’re missing commas between your feed definitions.
                feeds: [
                                title: "..."
                                url: "..."
                        },      //  <--- you're missing commas there
                                title: "..."
                                url: "..."
                • K Offline
                  KirAsh4 Moderator
                  Also, you are not required to enter all of those weather parameters unless you are actually changing them. Bare minimum all you need is your location and your API ID. The iconTable, apiBase, Version, all of those things are already defined for you. Only if you want to change the defaults do you have to define them.
                  • MichMichM Offline
                    MichMich
                    Best way to check your config.js is to check it using jshint.com or jslint.com - they will show you the errors if there are any.
                    • I Offline
                      IArentBen @MichMich
                      @MichMich I tried the jshint and jslint but, was not successful because of my lack of knowledge in this language. I fixed it but basically scrapping the whole file and doing one section at a time. I learnt a whole lot in two hours though haha
