    Warn-App NINA
    25 Posts 9 Posters 12.6k Views 11 Watching
    • V
      v0rtex
      Hello
      is it posible to creat a modul for Warn-App NINA?
      https://www.bbk.bund.de/DE/NINA/Warn-App_NINA.html
      M 1 Reply Last reply
      Reply Quote 1
      • JalibuJ
        Jalibu Module Developer
        @sdetweil please mark this topic as “solved”.
        => Module Forum Thread https://forum.magicmirror.builders/topic/15429/mmm-nina
        • M
          MajorC Project Sponsor @v0rtex
          @v0rtex that would be very nice to have!
          • Feedy88F
            Feedy88
            Doesn’t look like there is an API available, so basically no way to get the data in.
            cowboysdudeC 1 Reply Last reply
            • M
              There seams to be a RSS feed, but no API at the moment. :face_with_cold_sweat:
              • FoziF
                Fozi Project Sponsor
                NINA is the most useless service ever. It never worked a single time on my phone. Not even when they send test alarms. https://www.faz.net/aktuell/politik/inland/pannen-beim-warntag-bbk-praesident-unger-droht-abloesung-16956336.html Any effort on a Nina module is currently a waste of time and resources.
                Reply Quote -1
                • M
                  MajorC Project Sponsor @Fozi
                  I have to strongly disagree with you on this point. The NINA app has worked for me several times and has been proven to work fast and accurately. Even with GPS-based locations (e.g. on business trips) it warned me about events on the move.
                  Of course the whole system, not the app, failed during the warning day. But it wasn’t the app’s fault, there were several cascading effects.
                  Nevertheless, big fires in my area, airplane bomb discoveries, all this has worked very well, fast and reliable during the last years.
                  Therefore my clear PRO for the app and also for finally releasing the API. Via “Ask the State” they tried this before, unfortunately without success.
                  Translated with www.DeepL.com/Translator (free version)
                  FoziF 1 Reply Last reply
                  • FoziF
                    Fozi Project Sponsor @MajorC
                    @MajorC I don’t blame the app but the whole backend, which is unreliable. When I lived in Munich a few years ago two WWII bombs were found on a construction ground near our house within two months. We got noticed by the police when they rang on our door and requested our evacuation. Both times no warnings from Nina and we had to leave immediately without any possibility to pack some stuff for our 14 months old daughter. Then the shooting at McDonalds. I work about 500 m away, the notification came 3 hours later and the situation that evening was chaotic. Followups? Forget it! But if the system collapses already under dry-run conditions, then it is no wonder that in an real emergency the system would fail, too. Such systems have to work 100% reliable under all circumstances. If they don’t, they are useless and people like me start to lose trust. And over the last years obviously nothing improved. I fully agree that we need a warning system, but Nina unfortunately lost a lot of trust for me. The tweets from the local police departments are by far more reliable, accurate, trustworthy and faster.
                    • U
                      ueffchen
                      the simplest is to create your own custom RSS Feed on NINA such as RSS and put it in the newsfeed. This won’t give you the whole text, but this would anyway be very long and in my view too much to display on the MM
                      • cowboysdudeC
                        cowboysdude Module Developer @Feedy88
                        @feedy88 Oh there’s always a way
                        Reply Quote 1
                        • JalibuJ
                          @v0rtex @MajorC
                          Is there still a need for this?
                          I just stumbled upon the Nina API (i.e. https://warnung.bund.de/api31/dashboard/082210000000.json for Heidelberg)
                          It should be very easy to implement a client module for MagicMirror
                          • M
                            MajorC Project Sponsor @Jalibu
                            @jalibu that would be very cool to see on the mirror.
                            • JalibuJ
                              Hier mal ein erster Entwurf: https://github.com/jalibu/MMM-NINA
                              An der Optik müssen wir noch Arbeiten ;-)
                              Bin hier für Vorschläge (Mockups, etc) offen.
                              Reply Quote 1
                                santicoia
                                Hallo @Jalibu
                                Habe dein Modul installiert und den AGS auf meine Region angepasst. Bekomme eine Fehlermeldung und config:check ergibt unexpected token ags Colume 13.
                                        module: "MMM-NINA",
                                        position: "top_bar",
                                            updateIntervalInSeconds: 120,
                                            maxAgeInHours: 6,
                                            showNoWarning: true
                                            ags: "034570022022",
                                Nun habe ich entdeckt, dass es für meinen Ort unterschiedliche Angaben im Netz gibt. Unter deinem Link erhalte ich die oben eingefügte Zahl. Unter diesem Link sieht der AGS so aus 03457022. Es fehlt also scheinbar eine 0 oder bei deinem Link wäre eine zuviel. Hab ich natürlich getestet, aber egal wie eingetragen, es funzt nicht.
                                Daraufhin hab ich deine Beispiel-Config von Github eingetragen und erhalte nach wie vor den selben Fehler… unexpected token ags.
                                Wo liegt mein Fehler? Bin für jegliche Hilfe dankbar und danke schon mal fürs Lesen.
                                Grüße
                                Sandra
                                JalibuJ 1 Reply Last reply
                                • JalibuJ
                                  Jalibu Module Developer @santicoia
                                  Hallo @santicoia ,
                                  herzlich willkommen in der Community und danke für dein Interesse an meinen Modulen.
                                  In deiner config.js fehlt ein Komma nach showNoWarning:true
                                  Wenn man das ergänzt, dann funktioniert es bei mir wunderbar :-)
                                  Reply Quote 1
                                    santicoia @Jalibu
                                    @jalibu
                                    vielen Dank für die schnelle Hilfe. Peinlich, dabei hatte ich bestimmt 10 Mal drüber geguckt. Aber zu meiner Entlastung, das Komma fehlt auch in deinem Beispiel auf Github ;)
                                    • JalibuJ
                                      @santicoia said in Warn-App NINA:
                                      @jalibu
                                      @MajorC hat es dankenswerterweise eben schon gefixt :-)
                                      • M
                                        @jalibu das war easy, das musste ich schnell abstauben :-)
                                        Reply Quote 1
                                        • FoziF
                                          Fozi Project Sponsor @Jalibu
                                          @jalibu Ich habe das Modul mal am Wochenende installiert und es funktioniert. D.h., wenn ich eine Warnung auf mein Handy bekomme, sehe ich sie auch im Modul.
                                          Vorschlag:
                                          • Wenn keine Warnungen anliegen, sollte lediglich “Keine Warnungen” als Nachricht erscheinen in #666 statt grün und ohne Haken davor. Das würde besser zu MMM-DWDWarweather Modul passen ☺.
                                          • In der config würde ich noch die header: option angeben, die man sich nach Wunsch benennen kann. Ausserdem hat man dann auch eine schöne Headline über dem Modul.
                                          JalibuJ M 2 Replies Last reply
                                          • JalibuJ
                                            Jalibu Module Developer @Fozi
                                            Servus @fozi,
                                            könntest du hierzu auch Issues auf Github anlegen? Dann wirds nicht in Vergessenheit geraten.
                                            Reply Quote 1
                                            • FoziF
                                              @jalibu Klar, ist schon erledigt.
                                              Reply Quote 1
