    Hmm, a lot of modules are putting up a fight for me :-(
    10 Posts 4 Posters 3.0k Views 4 Watching
    • F
      fribse
      Being a newbie I struggle quite a lot with the configuration of the modules.
      Latest example is with the yr forecast, I’ve git’ed the module down, and I’ve added this to the config as per the example:
                              module: "mmm-weatherchart",
                              position: "bottom-left",
                                      country: "Danmark",
                                      area: "Sjælland",
                                      city: "Greve",
                                      updateInterval: 60 * 60 * 1000,
                                      hideBorder: true,
                                      negativeImage: true,
      But now the MM is not showing anything (not even that the config is wrong.
      S evroomE 2 Replies Last reply Reply Quote 0
        sdetweil @fribse
        @fribse a black screen usually means some coding problem as compared to what was entered in the config section of this module in config.js
        open the developers window, using keyboard its ctrl-shift-i, or npm start dev if starting mm…
        then select the tab at the top labeled ‘console’, and then scroll up to locate any errors, usually red text
        S F 2 Replies Last reply Reply Quote 1
          see here https://forum.magicmirror.builders/topic/506/mmm-weatherchart/18
          there are two mmm-weatherchart modules… one has an error, the other fixes the error
          • evroomE
            evroom @fribse
            @fribse said in Hmm, a lot of modules are putting up a fight for me :-(:
            Due to questions in another threat I installed that module myself.
            I found out that this repository works (not the paphko version):
            git clone https://github.com/szech/mmm-weatherchart.git
            Try this:
            $ cd ~/MagicMirror/modules/
            $ mv mmm-weatherchart mmm-weatherchart.saved
            $ git clone https://github.com/szech/mmm-weatherchart.git
            $ cd ~/MagicMirror/modules/mmm-weatherchart
            $ npm install
            When it works:
            $ rm -rf mmm-weatherchart.saved
            MagicMirror version: 2.37.0
            F 1 Reply Last reply Reply Quote 1
            • R
              You say yr forecast… perhaps you should look at the module MMM-YrThen.
              • F
                fribse @sdetweil
                @sdetweil Sounds like a plan, I’ll look into that when I have some time again, thankyou! (maybe not for this module, but there are quite a few putting up a fight).
                  sdetweil @fribse
                  @fribse np… the black screen is because the ui thread has crashed due to some fatal error…
                  in this case, the module uses a node library, which isn’t installed… but you didn’t know.
                  • F
                    fribse @evroom
                    @evroom Great, thankyou for clearing that up, I’ll go and get the other download!
                    • F
                      fribse
                      Ok, so I finally got the compliments in danish up and running properly, as well as danish news feeds, danish calendar and current danish weather, I’ll go and have a go with this one now.
                      • F
                        fribse
                        I used the YRThen, and it works nicely, I do think it would be nice to have a fade option, like in many of the other modules.
