    MMM-MarineWeather
    25 Posts 9 Posters 13.1k Views 10 Watching
    • G
      grena Module Developer
      Hello everyone,
      MMM-MarineWeather 0.2.0 has just been released, you can now:
      • Display additional information (pressure, cloud cover, visibility, sea level) with API v2.
      • Customize displayed information (except water temperature and air temperature).
      MMM-MarineWeather 0.2.0 ScreenShots
      To update:
      cd ~/MagicMirror/modules/MMM-MarineWeather
      git pull
      I hope you like this new version.
      Please inform me of any problems.
      Grena
      • uros76U
        uros76
        Thanks for this module, it works great!
        My magicmirror projects: https://forum.magicmirror.builders/post/79889, https://forum.magicmirror.builders/post/93241 and https://forum.magicmirror.builders/post/94586
        • A
          andymassey
          @grena Nice little module!
          I have the full thing working (like the graphic on the left), but was hoping to use the simpler version (like the graphic on the far right) – but using params causes an error… Maybe I’m getting the syntax wrong – could you provide an example of how that line of the config should appear please?
          Thanks.
          G 1 Reply Last reply
          • G
            grena Module Developer @andymassey
            Thanks ;)
            The parameters requested from Storm Glass must be kept to a minimum, i.e., airTemperature and waterTemperature like this:
            		module: "MMM-MarineWeather",
            			latitude: 0, // Latitude
            			longitude: 0, // Longitude
            			appid: "abcde12345abcde12345abcde12345ab", // StormGlass API key (docs.stormglass.io)
            			params: ["airTemperature", "waterTemperature"]
            R 1 Reply Last reply
            Reply Quote 1
            • R
              RIKKO14 @grena
              Hello @grena ,
              Have you been able to rework on the module, notably on the high and low tide values ​​which are not correct and the logos that I found for you
