    MMM-MarineWeather
    25 Posts 9 Posters 12.8k Views 10 Watching
      boivinmi @grena
      @grena : Sorry no luck, I removed every config except latitude, longitude et appid and it still shows Loading…
      • G
        grena Module Developer @boivinmi
        @boivinmi
        With your MMM-MarineWeather configuration, it works fine! Did you restart the magic mirror?
           module: "MMM-MarineWeather",
           header: "Marine Weather",
              latitude: 46.829853,  // Latitude
              longitude: -71.254028, // Longitude
              appid: "414492aa-c717-11e9-a3da-0242ac130004-4144953e-c717-11e9-a3da-0242ac130004"
        Since I can’t reproduce your bug, you have to see if there are any error messages in the console!
          Deckard99 @grena
          @grena I am by the Pacific Ocean…not a lake…not that I don’t like lakes :)
          • G
            grena Module Developer @Deckard99
            @Deckard99 said in MMM-MarineWeather:
            latitude: 32.7157,
            longitude: 117.16,
            For me, the place associated with this coordinates is located near a lake in China! You may be able to verify that the coordinates are correct: www.latlong.net
              Deckard99
              Google says this is San Diego…where I live…
              v2 is up an working, great job!
              • G
                I think you forgot the - for the longitude (to the west of Greenwich) !
                With these coordinates, you’re in San Diego!
                latitude: 32.7157,
                longitude: -117.16,
                • G
                  Hello everyone,
                  MMM-MarineWeather 0.2.0 has just been released, you can now:
                  • Display additional information (pressure, cloud cover, visibility, sea level) with API v2.
                  • Customize displayed information (except water temperature and air temperature).
                  MMM-MarineWeather 0.2.0 ScreenShots
                  To update:
                  cd ~/MagicMirror/modules/MMM-MarineWeather
                  git pull
                  I hope you like this new version.
                  Please inform me of any problems.
                  Grena
                  • uros76U
                    uros76
                    Thanks for this module, it works great!
                    • A
                      andymassey
                      @grena Nice little module!
                      I have the full thing working (like the graphic on the left), but was hoping to use the simpler version (like the graphic on the far right) – but using params causes an error… Maybe I’m getting the syntax wrong – could you provide an example of how that line of the config should appear please?
                      Thanks.
                      • G
                        grena Module Developer @andymassey
                        Thanks ;)
                        The parameters requested from Storm Glass must be kept to a minimum, i.e., airTemperature and waterTemperature like this:
                        			latitude: 0, // Latitude
                        			longitude: 0, // Longitude
                        			appid: "abcde12345abcde12345abcde12345ab", // StormGlass API key (docs.stormglass.io)
                        			params: ["airTemperature", "waterTemperature"]
                          RIKKO14 @grena
                          Hello @grena ,
                          Have you been able to rework on the module, notably on the high and low tide values ​​which are not correct and the logos that I found for you
