    MMM-MarineWeather
    25 Posts 9 Posters 13.1k Views 10 Watching
    • G
      grena Module Developer @minomit
      @minomit
      With your MMM-MarineWeather configuration, it works fine !
      	module: "MMM-MarineWeather",
      		latitude: 40.10 , // Latitude
      		longitude: 18.52, // Longitude
      		appid: "414492aa-c717-11e9-a3da-0242ac130004-4144953e-c717-11e9-a3da-0242ac130004" // API Key for your tests
      Since I can’t reproduce your bug, you have to see if there are any error messages in the console! To start MagicMirror with DevTools open, run npm start dev from the MagicMirror folder like this in a terminal cd ~/MagicMirror/ && npm start dev.
      M 1 Reply Last reply
        minomit @grena
        @grena I0m copy/past some problem:
                    "pages": {
                                    "tempo reale": "top_right"
                    //position: "top_right",
        edited, PLEASE use the markup around code and config blocks (three backtics on a separate line before and after)
        • G
          @minomit, do you use MMM-Page-Selector ?
          I wanted to do a final test to reproduce your bug by installing MMM-Page-Selector, it works ! So, I added some error messages in the module to get more information but you will have to look at the console when starting MagicMirror with DevTools.
            ryanbeljan
            @grena this is a super cool module! I noticed that there are quite a few other weather parameters that the StormGlass API offers (i.e. gust, cloudCover, seaLevel, visibility, etc.) that aren’t yet built into your module. Do you have any tips/guide for how I would go about adding them in?
            https://docs.stormglass.io/#/weather
            G 1 Reply Last reply
              boivinmi @minomit
              @grena I also have the same behavior. Here is my config :
                 header: "Marine Weather",
                    latitude: 46.829853,  // Latitude
                    longitude: -71.254028, // Longitude
                    appid: "414492aa-c717-11e9-a3da-0242ac130004-4144953e-c717-11e9-a3da-0242ac130004",
                    dataSource: "sg",
                    params: "airTemperature,windSpeed,windDirection"
              And result is :
                Deckard99
                I’m having the same issue where it just displays “Loading”…….
                module: “MMM-MarineWeather”,
                position: “top_right”,
                latitude: 32.7157,
                longitude: 117.16,
                appid: “XXXXXXXX-9a15-11ea-b3e2-0242ac130002-9be8a7f6-9a15-11ea-b3e2-0242ac130002” //StormGlass API Key (docs.stormglass.io)
                • G
                  grena Module Developer @ryanbeljan
                  @ryanbeljan : Thank you for your positive feedback. I will work on a new version of the module to use the new information of API v2 (currently the module uses API v1) ;)
                  @boivinmi : Currently, it’s not possible to choose the information displayed with params. By removing this line from your configuration, it works fine!
                  @Deckard99 : Indeed, there is a problem with waveHeight at your location (probably because it is a lake and not the sea). In the next version, I will integrate a better detection of this type of error to avoid the total blocking of the module!
                  B D 2 Replies Last reply
                    boivinmi @grena
                    @grena : Sorry no luck, I removed every config except latitude, longitude et appid and it still shows Loading…
                    • G
                      grena Module Developer @boivinmi
                      @boivinmi
                      With your MMM-MarineWeather configuration, it works fine! Did you restart the magic mirror?
                        Deckard99 @grena
                        @grena I am by the Pacific Ocean…not a lake…not that I don’t like lakes :)
                        • G
                          grena Module Developer @Deckard99
                          @Deckard99 said in MMM-MarineWeather:
                          latitude: 32.7157,
                          longitude: 117.16,
                          For me, the place associated with this coordinates is located near a lake in China! You may be able to verify that the coordinates are correct: www.latlong.net
                            Deckard99
                            Google says this is San Diego…where I live…
                            v2 is up an working, great job!
                            • G
                              I think you forgot the - for the longitude (to the west of Greenwich) !
                              With these coordinates, you’re in San Diego!
                              latitude: 32.7157,
                              longitude: -117.16,
                              • G
                                Hello everyone,
                                MMM-MarineWeather 0.2.0 has just been released, you can now:
                                • Display additional information (pressure, cloud cover, visibility, sea level) with API v2.
                                • Customize displayed information (except water temperature and air temperature).
                                MMM-MarineWeather 0.2.0 ScreenShots
                                To update:
                                cd ~/MagicMirror/modules/MMM-MarineWeather
                                git pull
                                I hope you like this new version.
                                Please inform me of any problems.
                                Grena
                                • uros76U
                                  uros76
                                  Thanks for this module, it works great!
                                  • A
                                    andymassey
                                    @grena Nice little module!
                                    I have the full thing working (like the graphic on the left), but was hoping to use the simpler version (like the graphic on the far right) – but using params causes an error… Maybe I’m getting the syntax wrong – could you provide an example of how that line of the config should appear please?
                                    Thanks.
                                    • G
                                      grena Module Developer @andymassey
                                      Thanks ;)
                                      The parameters requested from Storm Glass must be kept to a minimum, i.e., airTemperature and waterTemperature like this:
                                      			latitude: 0, // Latitude
                                      			longitude: 0, // Longitude
                                      			appid: "abcde12345abcde12345abcde12345ab", // StormGlass API key (docs.stormglass.io)
                                      			params: ["airTemperature", "waterTemperature"]
                                      R 1 Reply Last reply
                                        RIKKO14 @grena
                                        Hello @grena ,
                                        Have you been able to rework on the module, notably on the high and low tide values ​​which are not correct and the logos that I found for you
