    MMM-MarineWeather
    25 Posts 9 Posters 12.2k Views 10 Watching
      ryanbeljan
      @grena this is a super cool module! I noticed that there are quite a few other weather parameters that the StormGlass API offers (i.e. gust, cloudCover, seaLevel, visibility, etc.) that aren’t yet built into your module. Do you have any tips/guide for how I would go about adding them in?
      https://docs.stormglass.io/#/weather
        boivinmi @minomit
        @grena I also have the same behavior. Here is my config :
           module: "MMM-MarineWeather",
           header: "Marine Weather",
              latitude: 46.829853,  // Latitude
              longitude: -71.254028, // Longitude
              appid: "414492aa-c717-11e9-a3da-0242ac130004-4144953e-c717-11e9-a3da-0242ac130004",
              dataSource: "sg",
              params: "airTemperature,windSpeed,windDirection"
        And result is :
          Deckard99
          I’m having the same issue where it just displays “Loading”…….
          module: “MMM-MarineWeather”,
          position: “top_right”,
          latitude: 32.7157,
          longitude: 117.16,
          appid: “XXXXXXXX-9a15-11ea-b3e2-0242ac130002-9be8a7f6-9a15-11ea-b3e2-0242ac130002” //StormGlass API Key (docs.stormglass.io)
          • G Offline
            grena Module Developer @ryanbeljan
            @ryanbeljan : Thank you for your positive feedback. I will work on a new version of the module to use the new information of API v2 (currently the module uses API v1) ;)
            @boivinmi : Currently, it’s not possible to choose the information displayed with params. By removing this line from your configuration, it works fine!
            @Deckard99 : Indeed, there is a problem with waveHeight at your location (probably because it is a lake and not the sea). In the next version, I will integrate a better detection of this type of error to avoid the total blocking of the module!
            B D 2 Replies Last reply Reply Quote 0
              boivinmi @grena
              @grena : Sorry no luck, I removed every config except latitude, longitude et appid and it still shows Loading…
              • G Offline
                grena Module Developer @boivinmi
                @boivinmi
                With your MMM-MarineWeather configuration, it works fine! Did you restart the magic mirror?
                Since I can’t reproduce your bug, you have to see if there are any error messages in the console!
                  Deckard99 @grena
                  @grena I am by the Pacific Ocean…not a lake…not that I don’t like lakes :)
                  • G Offline
                    grena Module Developer @Deckard99
                    @Deckard99 said in MMM-MarineWeather:
                    latitude: 32.7157,
                    longitude: 117.16,
                    For me, the place associated with this coordinates is located near a lake in China! You may be able to verify that the coordinates are correct: www.latlong.net
                      Deckard99
                      Google says this is San Diego…where I live…
                      v2 is up an working, great job!
                      • G Offline
                        I think you forgot the - for the longitude (to the west of Greenwich) !
                        With these coordinates, you’re in San Diego!
                        latitude: 32.7157,
                        longitude: -117.16,
                        • G Offline
                          Hello everyone,
                          MMM-MarineWeather 0.2.0 has just been released, you can now:
                          • Display additional information (pressure, cloud cover, visibility, sea level) with API v2.
                          • Customize displayed information (except water temperature and air temperature).
                          MMM-MarineWeather 0.2.0 ScreenShots
                          To update:
                          cd ~/MagicMirror/modules/MMM-MarineWeather
                          git pull
                          I hope you like this new version.
                          Please inform me of any problems.
                          Grena
                          • uros76U Offline
                            uros76
                            Thanks for this module, it works great!
                              andymassey
                              @grena Nice little module!
                              I have the full thing working (like the graphic on the left), but was hoping to use the simpler version (like the graphic on the far right) – but using params causes an error… Maybe I’m getting the syntax wrong – could you provide an example of how that line of the config should appear please?
                              Thanks.
                              • G Offline
                                grena Module Developer @andymassey
                                Thanks ;)
                                The parameters requested from Storm Glass must be kept to a minimum, i.e., airTemperature and waterTemperature like this:
                                			latitude: 0, // Latitude
                                			longitude: 0, // Longitude
                                			appid: "abcde12345abcde12345abcde12345ab", // StormGlass API key (docs.stormglass.io)
                                			params: ["airTemperature", "waterTemperature"]
                                  RIKKO14 @grena
                                  Hello @grena ,
                                  Have you been able to rework on the module, notably on the high and low tide values ​​which are not correct and the logos that I found for you
