    MMM-MarineWeather
    25 Posts 9 Posters 13.1k Views 10 Watching
    • G
      grena Module Developer
      Hello everyone,
      I just released a second Magic Mirror Module, MMM-MarineWeather, it displays the current marine weather :
      • Water and air temperatures
      • Wind conditions : speed, direction
      • Wave conditions : height, direction, period
      MMM-MarineWeather ScreenShots
      [card:grenagit/MMM-MarineWeather]
      I hope you like the module.
      Please inform me of any problems.
      Grena
      Mykle1M 1 Reply Last reply
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @grena
        @grena
        I like it! :thumbsup:
          minomit
          I don’t see … help me please
          G 1 Reply Last reply
          • G
            grena Module Developer @minomit
            @minomit said in MMM-MarineWeather:
            What is your problem? What do you want to do?
              minomit @grena
              @grena loading …
              G B 2 Replies Last reply
              • G
                loading …
                Okay, on my side it works fine!
                Can you specify your MMM-MarineWeather configuration in the config/config.js file with a copy/paste into a code block (“</>” button) to try to find the problem?
                  minomit @grena
                  @grena
                  latitude: 40.10 , // Latitude
                  longitude: 18.52, // Longitude
                  appid: “xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx” // StormGlass API key (docs.stormglass.io)
                  • G
                    @minomit
                    With your MMM-MarineWeather configuration, it works fine !
                    	module: "MMM-MarineWeather",
                    		appid: "414492aa-c717-11e9-a3da-0242ac130004-4144953e-c717-11e9-a3da-0242ac130004" // API Key for your tests
                    Since I can’t reproduce your bug, you have to see if there are any error messages in the console! To start MagicMirror with DevTools open, run npm start dev from the MagicMirror folder like this in a terminal cd ~/MagicMirror/ && npm start dev.
                      minomit @grena
                      @grena I0m copy/past some problem:
                                  "pages": {
                                                  "tempo reale": "top_right"
                                  //position: "top_right",
                      edited, PLEASE use the markup around code and config blocks (three backtics on a separate line before and after)
                      • G
                        @minomit, do you use MMM-Page-Selector ?
                        I wanted to do a final test to reproduce your bug by installing MMM-Page-Selector, it works ! So, I added some error messages in the module to get more information but you will have to look at the console when starting MagicMirror with DevTools.
                          ryanbeljan
                          @grena this is a super cool module! I noticed that there are quite a few other weather parameters that the StormGlass API offers (i.e. gust, cloudCover, seaLevel, visibility, etc.) that aren’t yet built into your module. Do you have any tips/guide for how I would go about adding them in?
                          https://docs.stormglass.io/#/weather
                            boivinmi @minomit
                            @grena I also have the same behavior. Here is my config :
                               header: "Marine Weather",
                                  latitude: 46.829853,  // Latitude
                                  longitude: -71.254028, // Longitude
                                  appid: "414492aa-c717-11e9-a3da-0242ac130004-4144953e-c717-11e9-a3da-0242ac130004",
                                  dataSource: "sg",
                                  params: "airTemperature,windSpeed,windDirection"
                            And result is :
                              Deckard99
                              I’m having the same issue where it just displays “Loading”…….
                              module: “MMM-MarineWeather”,
                              position: “top_right”,
                              latitude: 32.7157,
                              longitude: 117.16,
                              appid: “XXXXXXXX-9a15-11ea-b3e2-0242ac130002-9be8a7f6-9a15-11ea-b3e2-0242ac130002” //StormGlass API Key (docs.stormglass.io)
                              • G
                                grena Module Developer @ryanbeljan
                                @ryanbeljan : Thank you for your positive feedback. I will work on a new version of the module to use the new information of API v2 (currently the module uses API v1) ;)
                                @boivinmi : Currently, it’s not possible to choose the information displayed with params. By removing this line from your configuration, it works fine!
                                @Deckard99 : Indeed, there is a problem with waveHeight at your location (probably because it is a lake and not the sea). In the next version, I will integrate a better detection of this type of error to avoid the total blocking of the module!
                                B D 2 Replies Last reply
                                  boivinmi @grena
                                  @grena : Sorry no luck, I removed every config except latitude, longitude et appid and it still shows Loading…
                                  • G
                                    grena Module Developer @boivinmi
                                    @boivinmi
                                    With your MMM-MarineWeather configuration, it works fine! Did you restart the magic mirror?
                                      Deckard99 @grena
                                      @grena I am by the Pacific Ocean…not a lake…not that I don’t like lakes :)
                                      • G
                                        grena Module Developer @Deckard99
                                        @Deckard99 said in MMM-MarineWeather:
                                        latitude: 32.7157,
                                        longitude: 117.16,
                                        For me, the place associated with this coordinates is located near a lake in China! You may be able to verify that the coordinates are correct: www.latlong.net
                                          Deckard99
                                          Google says this is San Diego…where I live…
                                          v2 is up an working, great job!
                                          • G
                                            I think you forgot the - for the longitude (to the west of Greenwich) !
                                            With these coordinates, you’re in San Diego!
                                            latitude: 32.7157,
                                            longitude: -117.16,
