    skywriter - python to javascript
    18 Posts 3 Posters 14.6k Views 3 Watching
    • K Offline
      kclemen
      Ok, the script is performing without any errors at the moment.
      Would somebody be so kind to check why console.log(“payload.action is up”); is not executed in MMM-skywriter.js?
      I only get the message from node-helper.js : console.log(“[” + self.name + "] " + message.gesture);
      Files can be found here: https://github.com/Kclemen/MMM-skywriter
      • K Offline
        kclemen
        Node helper:
        self.sendSocketNotification('gesture', message.gesture);
        script:
        Module.register("MMM-skywriter",{
        	//	gesture_up: 0,
        	//	gesture_right: 0,
        	// Override socket notification handler.
        			console.log ("socketnotificationreceived.")
        		if (payload === "up"){
        			console.log("test - up");
        		else if (payload === "left"){
        			console.log("test - left");
        		else if (payload === "down") {
        			console.log("test - down");
        Why is there no ccommunication between the helper and the script?	}
        J 1 Reply Last reply Reply Quote -1
          Jopyth Moderator @kclemen
          @kclemen Are you searching for the output in your browser console? The console.log("...") command from node_helper.js is shown on the console, however console.log("...") commands of your module will appear in your developer tools console in the browser (e.g. electron).
          Helpful sticky: How to troubleshoot
          K 1 Reply Last reply Reply Quote 1
          • K Offline
            kclemen @Jopyth
            @Jopyth said in skywriter - python to javascript:
            Indeed, I want to see the output to verify the communication works.
            Could you elaborate some more about the developer tools console?
            ctrl + shift + i does the trick :)
            @Jopyth you are a HERO. Last 2 days working on it, antd the trick was that simple!
              @kclemen I was just pointing you in the right direction sometimes. ;) Best of luck with finishing the rest of the module.
              • K Offline
                kclemen
                ok, for now the last question ;):
                Uncaught reference error: gesture_up is not defined. I understand what this means, but I can’t figure out why it says that :s
                	// Default module config.
                	defaults: {
                		gesture_up: 0,
                		gesture_right: 0,
                		if (notification === "gesture_observed"){
                			const self = this;
                			console.log ("socketnotificationreceived.");
                			//self.sendNotification(notification, payload);
                				if (gesture_up == 0) {
                					if (gesture_up == 0){
                						gesture_up = gesture_up+1;
                						console.log("gesture_up is nu 1");
                • yawnsY Offline
                  yawns Moderator
                  Try this.config.gesture_up instead
                  • K Offline
                    kclemen
                    This helps indeed for the error, thanks. But how to use it like I want? I mean, how can you do calculations within following up socketnotifications? It looks like with every gesture the this.config;gesture_up starts with the value 0.
