    skywriter - python to javascript
    18 Posts 3 Posters 16.1k Views 3 Watching
      Jopyth Moderator @kclemen
      @kclemen Please use three backticks (```) for markdown if you paste your code, instead of one (`). Otherwise it will not recognize it as multi line code.
      The problem are your regular print statements (e.g. print "Gesture is west to east"), these are also read by node, and they are not in the JSON format. You can comment these out, or maybe write them to a log file instead, if you want them to debug.
      • K Offline
        kclemen
        Thanks for the input. Indeed this was the mistake.
        seems I’m missing still something. Now I get following error:
        TypeError: parser.close is not a function
        at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
        at emitOne (events.js:96:13)
        at SAXStream.emit (events.js:188:7)
        at Object.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
        at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:640:35)
        at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:645:5)
        at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:841:5)
        at Object.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1404:13)
        at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
        at yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
        • K Offline
          kclemen
          Ok, the script is performing without any errors at the moment.
          Would somebody be so kind to check why console.log(“payload.action is up”); is not executed in MMM-skywriter.js?
          I only get the message from node-helper.js : console.log(“[” + self.name + "] " + message.gesture);
          Files can be found here: https://github.com/Kclemen/MMM-skywriter
          • K Offline
            kclemen
            Node helper:
            self.sendSocketNotification('gesture', message.gesture);
            script:
            Module.register("MMM-skywriter",{
            	//	gesture_up: 0,
            	//	gesture_right: 0,
            	// Override socket notification handler.
            			console.log ("socketnotificationreceived.")
            		if (payload === "up"){
            			console.log("test - up");
            		else if (payload === "left"){
            			console.log("test - left");
            		else if (payload === "down") {
            			console.log("test - down");
            Why is there no ccommunication between the helper and the script?	}
            J 1 Reply Last reply Reply Quote -1
              @kclemen Are you searching for the output in your browser console? The console.log("...") command from node_helper.js is shown on the console, however console.log("...") commands of your module will appear in your developer tools console in the browser (e.g. electron).
              K 1 Reply Last reply Reply Quote 1
              • K Offline
                kclemen @Jopyth
                @Jopyth said in skywriter - python to javascript:
                Indeed, I want to see the output to verify the communication works.
                Could you elaborate some more about the developer tools console?
                ctrl + shift + i does the trick :)
                @Jopyth you are a HERO. Last 2 days working on it, antd the trick was that simple!
                  @kclemen I was just pointing you in the right direction sometimes. ;) Best of luck with finishing the rest of the module.
                  • K Offline
                    kclemen
                    ok, for now the last question ;):
                    Uncaught reference error: gesture_up is not defined. I understand what this means, but I can’t figure out why it says that :s
                    	// Default module config.
                    	defaults: {
                    		gesture_up: 0,
                    		gesture_right: 0,
                    		if (notification === "gesture_observed"){
                    			const self = this;
                    			console.log ("socketnotificationreceived.");
                    			//self.sendNotification(notification, payload);
                    				if (gesture_up == 0) {
                    					if (gesture_up == 0){
                    						gesture_up = gesture_up+1;
                    						console.log("gesture_up is nu 1");
                    • Y Offline
                      yawns Moderator
                      Try this.config.gesture_up instead
                      • K Offline
                        kclemen
                        This helps indeed for the error, thanks. But how to use it like I want? I mean, how can you do calculations within following up socketnotifications? It looks like with every gesture the this.config;gesture_up starts with the value 0.
