    skywriter - python to javascript
    18 Posts 3 Posters 16.2k Views 3 Watching
    • K
      kclemen
      ok, first steps are being taken… https://github.com/Kclemen/MMskywriter
      • K
        kclemen
        fixed it…
        K 1 Reply Last reply
        • K
          kclemen @kclemen
          I’ve got following error:
          SyntaxError: Unexpected token g in JSON at position 0
          at PythonShell.asJson (/home/pi/MagicMirror/modules/MMM-skywriter/node_modules/python-shell/index.js:142:21)
          at /home/pi/MagicMirror/modules/MMM-skywriter/node_modules/python-shell/index.js:232:35
          at Array.forEach (native)
          at PythonShell.receive (/home/pi/MagicMirror/modules/MMM-skywriter/node_modules/python-shell/index.js:231:11)
          at emitOne (events.js:96:13)
          at Socket.emit (events.js:188:7)
          at readableAddChunk (_stream_readable.js:176:18)
          at Socket.Readable.push (_stream_readable.js:134:10)
          at Pipe.onread (net.js:543:20)
          Here is the script:
          `#!/usr/bin/env python
          import sys
          import json
          import time
          import signal
          import skywriter
          some_value = 5000
          last_airwheel = 0
          delay = 5000
          def to_node(type, message):
          # convert to json and print (node helper will read from stdout)
          try:
          print(json.dumps({type: message}))
          except Exception:
          pass
          # stdout has to be flushed manually to prevent delays in the node helper communication
          sys.stdout.flush()
          to_node(“status”, ‘Skywriter started…’)
          @skywriter.flick()
          def flick(start,finish):
          #slide music player div OFF the screen
          if(start == "north" and finish == "south"):
          	print "gesture is north to south"
          	to_node("gesture", "down")
          #slide music player div ONTO the screen
          elif(start == "south" and finish == "north"):
          	print "gesture is south to north"
          	to_node("gesture", "up")
          #Next track
          elif(start == "west" and finish == "east"):
          	print "Gesture is west to east"
          	to_node("gesture", "next")
          #previous track
          elif(start == "east" and finish == "west"):
          	print "Gesture is east to west"
          	to_node("gesture", "previous")
          #else:
          	# print "Invalid"
          @skywriter.airwheel()
          def spinny(delta):
          global some_value
          global last_airwheel
          global delay
          some_value += delta
          if some_value < 0:
          some_value = 0
          if some_value > 10000:
          some_value = 10000
          now = int(round(time.time() * 1000))
          if(now - last_airwheel > delay):
          print(“TV & Digibox: power”)
          # system(“irsend SEND_ONCE TV KEY_POWER”)
          # system(“irsend SEND_ONCE Digibox KEY_POWER”)
          last_airwheel = now
          signal.pause()`
          I do not really understand what is wrong? Anybody an idea?
          J 1 Reply Last reply
            Jopyth Moderator @kclemen
            @kclemen Please use three backticks (```) for markdown if you paste your code, instead of one (`). Otherwise it will not recognize it as multi line code.
            The problem are your regular print statements (e.g. print "Gesture is west to east"), these are also read by node, and they are not in the JSON format. You can comment these out, or maybe write them to a log file instead, if you want them to debug.
            • K
              kclemen
              Thanks for the input. Indeed this was the mistake.
              seems I’m missing still something. Now I get following error:
              TypeError: parser.close is not a function
              at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
              at SAXStream.emit (events.js:188:7)
              at Object.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
              at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:640:35)
              at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:645:5)
              at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:841:5)
              at Object.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1404:13)
              at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
              at yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
              • K
                kclemen
                Ok, the script is performing without any errors at the moment.
                Would somebody be so kind to check why console.log(“payload.action is up”); is not executed in MMM-skywriter.js?
                I only get the message from node-helper.js : console.log(“[” + self.name + "] " + message.gesture);
                Files can be found here: https://github.com/Kclemen/MMM-skywriter
                • K
                  kclemen
                  Node helper:
                  self.sendSocketNotification('gesture', message.gesture);
                  script:
                  Module.register("MMM-skywriter",{
                  	//	gesture_up: 0,
                  	//	gesture_right: 0,
                  	// Override socket notification handler.
                  			console.log ("socketnotificationreceived.")
                  		if (payload === "up"){
                  			console.log("test - up");
                  		else if (payload === "left"){
                  			console.log("test - left");
                  		else if (payload === "down") {
                  			console.log("test - down");
                  Why is there no ccommunication between the helper and the script?	}
                  Reply Quote -1
                    @kclemen Are you searching for the output in your browser console? The console.log("...") command from node_helper.js is shown on the console, however console.log("...") commands of your module will appear in your developer tools console in the browser (e.g. electron).
                    • K
                      kclemen @Jopyth
                      @Jopyth said in skywriter - python to javascript:
                      Indeed, I want to see the output to verify the communication works.
                      Could you elaborate some more about the developer tools console?
                      ctrl + shift + i does the trick :)
                      @Jopyth you are a HERO. Last 2 days working on it, antd the trick was that simple!
                        @kclemen I was just pointing you in the right direction sometimes. ;) Best of luck with finishing the rest of the module.
                        • K
                          kclemen
                          ok, for now the last question ;):
                          Uncaught reference error: gesture_up is not defined. I understand what this means, but I can’t figure out why it says that :s
                          	// Default module config.
                          	defaults: {
                          		gesture_up: 0,
                          		gesture_right: 0,
                          		if (notification === "gesture_observed"){
                          			const self = this;
                          			console.log ("socketnotificationreceived.");
                          			//self.sendNotification(notification, payload);
                          				if (gesture_up == 0) {
                          					if (gesture_up == 0){
                          						gesture_up = gesture_up+1;
                          						console.log("gesture_up is nu 1");
                          • Y
                            yawns Moderator
                            Try this.config.gesture_up instead
                            • K
                              kclemen
                              This helps indeed for the error, thanks. But how to use it like I want? I mean, how can you do calculations within following up socketnotifications? It looks like with every gesture the this.config;gesture_up starts with the value 0.
