    MMM-NewsFeedTicker, how do I make the marquee go faster
    8 Posts 3 Posters 3.0k Views 3 Watching
    • LordyL
      Lordy
      Hello,
      I would like to make the marquee faster, but do not know how?
      I’ve already tried it with “Animation Speed”.
      Which possibilities are still there?
      Lordy
      (translate by google)
      • B
        broberg Project Sponsor
        Try adding this to your custom.css :
        .MMM-NewsFeedTicker .tickerbody {
          -webkit-animation: marquee 2s linear infinite;
          -moz-animation: marquee 2s linear infinite;
          -ms-animation: marquee 2s linear infinite;
          -o-animation: marquee 2s linear infinite;
        • LordyL
          Lordy
          Thanks first. (Erstmal Danke)
          But feel no difference to before. (Aber spüre keinen unterschied zu voher)
          Can you do it even faster? (Kann man es noch schneller machen?)
          • B
            broberg Project Sponsor @Lordy
            @Lordy
            Try this, but after that I don’t know.
            .tickerbody {
              -webkit-animation: marquee 1s linear infinite !important;
              -moz-animation: marquee 1s linear infinite !important;
              -ms-animation: marquee 1s linear infinite !important;
              -o-animation: marquee 1s linear infinite !important;
            Be aware that the Raspberry pi doesn’t do animations very well, so something that works smooth and quick on a normal computer won’t work as well on a pi.
            • LordyL
              Lordy
              Thanks, great job.:winking_face:
              There you can see how “important” is important, the same, did yesterday too.
              • LordyL
                Lordy
                I have now discovered a new problem.
                I want to read the entire line and not the same line twice. *(Ich möchte die gesamte Zeile und nicht zweimal dieselbe Zeile lesen.)
                Where can you extend the display time? (Wo kann man die Anzeigezeit verlängern?)
                • J
                  JohnDelta
                  @broberg said in MMM-NewsFeedTicker, how do I make the marquee go faster:
                  MMM-NewsFeedTicker
                  go to the following line in the MMM-NewsFeedTicker.js file and change the number 1000 to a lower number. (some users are finding that changing to 300 works best for them, adjust to your preference)
                  tickerBody.style.animationDuration = Math.round(this.config.updateInterval / 1000) + "s";
                  hope it helps you
                  LordyL 1 Reply Last reply Reply Quote 0
                  • LordyL
                    Lordy @JohnDelta
                    @JohnDelta
                    Unfortunately no, thanks anyway.
                    My main concern is: “I want to read the entire line and not the same line twice. Where can you extend the display time?”
                    Lordy
