    MMM-Launch and other space modules not loading
    8 Posts 3 Posters 1.9k Views 3 Watching
      Dz3015
      Reaching out to @Mykle1 . It seems like “Astronauts” “Launches” “NASA” “NEO” are all behaving the same. Nothing loads except the innerHTML from the ‘if’ statement to check if the module loaded. It appears all the API feeds they are pulling from are still working. ISS-Live and ISS are working but none of the others.
      Thanks!
        Dz3015 @Dz3015
        @Mykle1 I deleted the modules that werent working this evening and reloaded the MMM-Astronauts module. I only get the message “Lost in space…” from the one if statement to show the module has loaded but nothing else.
        Mykle1M 4 Replies Last reply Reply Quote 0
          Mykle1 Project Sponsor Module Developer @Dz3015
          @Dz3015
          Can you start your mirror using npm start dev so the developers tool window opens. Click the console tab in the developers tools window. Then scroll. Please report any errors (in red) here
            @Dz3015
            Also, please post your config.js file here (in a code block)
            Removing anything that is private (api keys, etc)
              @Dz3015
              Here are three of the modules that you mentioned weren’t working. As I told you in our github conversation, I’m sure it’s something simple as all the modules are working as expected.
                @Dz3015
                I sent you a private message. Click my avatar at the bottom right of your screen.
                  Dz3015
                  After disabling all my modules and enabling them one by one it appears these are all working fine and were being broken by MMM-GoogleMapsTraffic
                    sdetweil @Dz3015
                    @Dz3015 and get the fix for googlemapstraffic from my GitHub repo
                    Rename current folder out of the way,
                    git clone mine instead
                    Same config
