    Hi, there is a new Alexa Module
    98 Posts 13 Posters 70.0k Views 15 Watching
    • P Offline
      pumpy266 @Stoffbeuteluwe
      The logo doesn’t appear on mine at all, think it did once.
      So try restarting the mirror or disabling it with image: false in the config.
      As a guess, try adding this to the custom.css:
      .module.MMM-AlexaControl{
      .img{
      height: 60;
      width: 60;
      There is a whole sub-forum on CSS, which I haven’t read.
      Anyway, give the above a go and let us know what happens.
      If no joy, please post the whole of your custom.css here.
      StoffbeuteluweS 2 Replies Last reply Reply Quote 0
      • StoffbeuteluweS Offline
        Stoffbeuteluwe Project Sponsor @pumpy266
        @pumpy266 Thank you for your help …:grinning_face: I will try tonight
        • FoziF Offline
          Fozi Project Sponsor @Stoffbeuteluwe
          @Stoffbeuteluwe I‘m struggling to make Alexa find my mirror as a new device. Can you explain shortly how you succeed?
          Thanks in advance,
          Fozi
            Stoffbeuteluwe Project Sponsor @Fozi
            @Fozi Install:
            MMM-Pages
            MMM-page-indicator
            MMM-AlexaControl
            than add the config post from @pumpy266 to your config and that’s it…
            Alexa discover devices…
            FoziF 1 Reply Last reply Reply Quote 0
            • FoziF Offline
              @Stoffbeuteluwe ok, I‘ll give it a try later this evening.
              Thanks,
              Fozi
                @pumpy266 now it works I forgot …px …for pixel
                thanks for helping :folded_hands_light_skin_tone:
                • T Offline
                  tanvir586
                  To use this module do i need an alexa device? Or it works with alexaPi/awesomealexa?
                  • P Offline
                    pumpy266
                    I’m using a ‘real’ Alexa.
                    Why not try it and let us all know?
                    You can always uninstall it if it doesn’t work.
                    Great that the image is how you wanted it.
                      BD0G
                      Similar situation here. Magic Mirror works and modules load on screen and then MMM-Pages takes over and switches to Page 1 as denoted by the circles at the bottom of the page. The screen does not display the modules after that.
                      Installed MMM-AlexaControl
                      MMM-Pages
                      MMM-page-indicator
                      Modified my config.js and checked it with npm run config:check.
                      No syntax errors
                      Alexa fails to find any new devices when using discovery through Alexa App or voice request “Alexa discover new devices” - Reports no new devices found. Same with app.
                      Here are the relevant entries from my config.js
                      			module: 'MMM-AlexaControl',
                      			position: 'bottom_left',
                      			config:{
                      				image: true,
                      				pm2ProcessName: "PM2",
                      				vcgencmd: true,
                      				pages:'3',
                                  module: 'MMM-pages',
                                  modules:
                                      [[ "DarkSkyForecastforecast", "Lunartic"],
                                       [ "DumpsterDay", "clock","calendar","updatenotification"]],
                                  fixed: ["MMM-page-indicator"],
                                  rotationTime:"0",
                              module: 'MMM-page-indicator',
                              position: 'bottom_bar',
                                  pages: 3,
                      FoziF StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                      • FoziF Offline
                        Fozi Project Sponsor @BD0G
                        I have only MMM-AlexaControl installed, without Pages, as I want to control the Podcast2 module. But also here, the discovery of the mirror fails, as well in the Alexa app as by asking my Echo Dot to discover new devices. My config is the same as already provided here, just without the pages statement. I also changed the startport and switched of the 5GHz band on my routers, but no success. Am I missing something obvious but essential?
                          Stoffbeuteluwe Project Sponsor @BD0G
                          @BD0G you have 2 Pages Not 3
                          please change in config and try again
                            BD0G @Stoffbeuteluwe
                            @Stoffbeuteluwe Is it possible to get this working without the MMM-Pages and MMM-page-indicator?
                              @BD0G I don’t think so
                              techcoderunT 1 Reply Last reply Reply Quote 0
                              • techcoderunT Offline
                                techcoderun @Stoffbeuteluwe
                                @Stoffbeuteluwe I’m having similar issues. My Alexa is unable to discover my MM. Don’t believe there are any errors in the config file. Also, the Alexa icon appears on my mirror. Do I need Wemo or Fauxmo in stalled on the RPi?
                                Any others have luck getting their MM discovered?
                                StoffbeuteluweS 3 Replies Last reply Reply Quote 0
                                  Stoffbeuteluwe Project Sponsor @techcoderun
                                  @techcoderun Have you installed:
                                  MMM-Pages
                                  MMM-page indicator ?
                                    BD0G
                                    I installed both MMM-Pages
                                    MMM-page indicator as well as the Alexa Module and never was able to discover my MagicMirror. I think I will move on to the MMM-Awesome-Alexa module and give that a whirl.
                                      @BD0G wanna try my config ?
                                        @Stoffbeuteluwe Sure!
                                          @BD0G
                                                      position: 'bottom_center',
                                                      config:{
                                                      image: true,
                                                      pm2ProcessName: "mm",
                                                      vcgencmd: true,
                                                      pages:'10',
                                                      notifications: [
        port: 11101,
        OnOff: true,
        notification: [["REMOTE_ACTION", { action: "SHOW", module: "module_0_alert" }],["REMOTE_ACTION",{ action: "HIDE", module: "module_0_alert" }]]
        port: 11102,
        OnOff: true,
        notification: [["REMOTE_ACTION", { action: "SHOW", module: "module_1_MMM-Remote-Control" }],["REMOTE_ACTION",{ action: "HIDE", module: "module_1_MMM-Remote-Control" }]]
        port: 11103,
        OnOff: true,
        notification: [["REMOTE_ACTION", { action: "SHOW", module: "module_2_updatenotification" }],["REMOTE_ACTION",{ action: "HIDE", module: "module_2_updatenotification" }]]
        port: 11104,
        OnOff: true,
        notification: [["REMOTE_ACTION", { action: "SHOW", module: "module_3_MMM-Snow" }],["REMOTE_ACTION",{ action: "HIDE", module: "module_3_MMM-Snow" }]]
                                            @BD0G you have to set your number of pages in:
                                            MMM-Pages
                                            and
                                            MMM-page-indicator
                                            • 2 / 5
