    Hi, there is a new Alexa Module
    98 Posts 13 Posters 79.8k Views 15 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @pumpy266
      @pumpy266
      can you help me change the image size in css
      I need a smaller size
        pumpy266 @Stoffbeuteluwe
        For which module(s)?
        What is the resolution of the monitor you are using?
        Won’t be able to post a reply tonight as I currently have a broken limb and moving takes slightly longer than usual.
        But post the details and I’ll take a look in the morning.
          @pumpy266 I want to make the Alexa image from the MMM-AlexaControl module smaller in CSS but I don’t know how.
          I have copied the css from the Module to my custom css and tried to change the size but nothing’s happened.
            The logo doesn’t appear on mine at all, think it did once.
            So try restarting the mirror or disabling it with image: false in the config.
            As a guess, try adding this to the custom.css:
            .module.MMM-AlexaControl{
            .img{
            height: 60;
            width: 60;
            There is a whole sub-forum on CSS, which I haven’t read.
            Anyway, give the above a go and let us know what happens.
            If no joy, please post the whole of your custom.css here.
            StoffbeuteluweS 2 Replies Last reply Reply Quote 0
              @pumpy266 Thank you for your help …:grinning_face: I will try tonight
              • FoziF Offline
                Fozi Project Sponsor @Stoffbeuteluwe
                @Stoffbeuteluwe I‘m struggling to make Alexa find my mirror as a new device. Can you explain shortly how you succeed?
                Thanks in advance,
                Fozi
                  Stoffbeuteluwe Project Sponsor @Fozi
                  @Fozi Install:
                  MMM-Pages
                  MMM-page-indicator
                  MMM-AlexaControl
                  than add the config post from @pumpy266 to your config and that’s it…
                  Alexa discover devices…
                  • FoziF Offline
                    @Stoffbeuteluwe ok, I‘ll give it a try later this evening.
                    Thanks,
                    Fozi
                      @pumpy266 now it works I forgot …px …for pixel
                      thanks for helping :folded_hands_light_skin_tone:
                      • T Offline
                        tanvir586
                        To use this module do i need an alexa device? Or it works with alexaPi/awesomealexa?
                          pumpy266
                          I’m using a ‘real’ Alexa.
                          Why not try it and let us all know?
                          You can always uninstall it if it doesn’t work.
                          Great that the image is how you wanted it.
                            BD0G
                            Similar situation here. Magic Mirror works and modules load on screen and then MMM-Pages takes over and switches to Page 1 as denoted by the circles at the bottom of the page. The screen does not display the modules after that.
                            Installed MMM-AlexaControl
                            MMM-Pages
                            MMM-page-indicator
                            Modified my config.js and checked it with npm run config:check.
                            No syntax errors
                            Alexa fails to find any new devices when using discovery through Alexa App or voice request “Alexa discover new devices” - Reports no new devices found. Same with app.
                            Here are the relevant entries from my config.js
                            			module: 'MMM-AlexaControl',
                            			position: 'bottom_left',
                            			config:{
                            				image: true,
                            				pm2ProcessName: "PM2",
                            				vcgencmd: true,
                            				pages:'3',
                                        module: 'MMM-pages',
                                        modules:
                                            [[ "DarkSkyForecastforecast", "Lunartic"],
                                             [ "DumpsterDay", "clock","calendar","updatenotification"]],
                                        fixed: ["MMM-page-indicator"],
                                        rotationTime:"0",
                                    module: 'MMM-page-indicator',
                                    position: 'bottom_bar',
                                        pages: 3,
                            FoziF StoffbeuteluweS 2 Replies Last reply Reply Quote 0
                            • FoziF Offline
                              Fozi Project Sponsor @BD0G
                              I have only MMM-AlexaControl installed, without Pages, as I want to control the Podcast2 module. But also here, the discovery of the mirror fails, as well in the Alexa app as by asking my Echo Dot to discover new devices. My config is the same as already provided here, just without the pages statement. I also changed the startport and switched of the 5GHz band on my routers, but no success. Am I missing something obvious but essential?
                                Stoffbeuteluwe Project Sponsor @BD0G
                                @BD0G you have 2 Pages Not 3
                                please change in config and try again
                                  BD0G @Stoffbeuteluwe
                                  @Stoffbeuteluwe Is it possible to get this working without the MMM-Pages and MMM-page-indicator?
                                    @BD0G I don’t think so
                                    techcoderunT 1 Reply Last reply Reply Quote 0
                                    • techcoderunT Offline
                                      techcoderun @Stoffbeuteluwe
                                      @Stoffbeuteluwe I’m having similar issues. My Alexa is unable to discover my MM. Don’t believe there are any errors in the config file. Also, the Alexa icon appears on my mirror. Do I need Wemo or Fauxmo in stalled on the RPi?
                                      Any others have luck getting their MM discovered?
                                      StoffbeuteluweS 3 Replies Last reply Reply Quote 0
                                        Stoffbeuteluwe Project Sponsor @techcoderun
                                        @techcoderun Have you installed:
                                        MMM-Pages
                                        MMM-page indicator ?
                                          BD0G
                                          I installed both MMM-Pages
                                          MMM-page indicator as well as the Alexa Module and never was able to discover my MagicMirror. I think I will move on to the MMM-Awesome-Alexa module and give that a whirl.
                                            @BD0G wanna try my config ?
                                            • 2 / 5
