    Hi, there is a new Alexa Module
    98 Posts 13 Posters 75.0k Views 15 Watching
    • StoffbeuteluweS Offline
      Stoffbeuteluwe Project Sponsor @BD0G
      @BD0G the notification in my config is for MMM-Remote-Control
      to send notifications (on/off) for each module if you like…
        Stoffbeuteluwe Project Sponsor @techcoderun
        @techcoderun i have posted my config…have a look
        techcoderunT 1 Reply Last reply Reply Quote 0
          @techcoderun no, you don’t need to install wemo or fauxmo
            BD0G @Stoffbeuteluwe
            @Stoffbeuteluwe Some progress actually. I used your config. Had Alexa Discover Devices and she did discover 18 new devices. 10 of them were labeled Page 1-10
            Then there was some like PM2 Restart 0 . Refresh, etc.
            When I issue a command like Alexa Turn off page 4 . I get “Page 4 is not responding -please checks its power supply or network connection”
            I get that with every page I try.
            I need to define the pages , but need the exact files to modify for MMM-Pages and MMM-PageIndicator
            I have MMM-RemoteControl installed , but not the version that is custom for Alexa. I bet I need to yank that module and install the custom one.
            • techcoderunT Offline
              techcoderun @Stoffbeuteluwe
              @Stoffbeuteluwe Installed both, but no luck so far.
                @Stoffbeuteluwe I’ll take a look, thanks!
                  @BD0G tonight I will send you my config for the other modules…pages and page indicator
                    BD0G
                    Thanks! It would be helpful to understand what commands can be issued using voice to Amazon Echo devices / Alexa and what they do.
                    For instance if I say Alexa Turn off page one. Is that valid and what should I expect as a result?
                    If I say Alexa Show Notification 1 does that do anything and if so -what?
                    The instructions dont really go into usage examples (if you know what I mean?)
                    Send tonight? Where are you located? Its 9:49 PM here presently LOL!
                    StoffbeuteluweS 3 Replies Last reply Reply Quote 0
                      @BD0G from Germany
                        @Stoffbeuteluwe Thanks! The modules would be extremely helpful!
                          @BD0G
                                     module: 'MMM-pages',
                                     modules:
                                         [[ "clock", "currentweather", "weatherforecast", "MMM-MyCalendar", "MMM-Lunartic", "MMM-MyWastePickup", "MMM-xiaomi", "MMM-Todoist", "MMM-Sonos", "newsfeed", "compliments", "MMM-AlexaControl"],
                                          [ "clock", "MMM-RandomPhoto"],
                                          [ "MMM-EasyBack" ],
                                          [ "MMM-ImagesPhotos" ],
                                          [ "MMM-Globe" ],
                                          [ "MMM-WordClock" ],
                                          [ "MMM-EyeCandy" ],
                                          [ "MMM-EasyPix" ],
                                          [ "clock","MMM-MyScoreboard", "MMM-MyStandings"],
                                     fixed: [""],
                                     rotationTime:"0",
                            @BD0G
                                       module: 'MMM-page-indicator',
                                       position: 'bottom_bar',
                                       pages: 10,
                            techcoderunT B 3 Replies Last reply Reply Quote 0
                              @Stoffbeuteluwe Really appreciate the post! Everything appears to be working properly, but Alexa still does not detect my mirror. I have the 1st Gen Alexa, so its possible that is my issue. Thanks for all your help!
                                @Stoffbeuteluwe UPDATE: I purchased a new Alexa (Echo Dot) and I got everything working properly. Thanks again!
                                StoffbeuteluweS FoziF 2 Replies Last reply Reply Quote 0
                                  @Stoffbeuteluwe Thanks for posting your config settings! Everytime I enable the AlexaControl Module My DarkSkyWeather Forecase, Lunartic, and US Holidays dont load. They just indicate “Loading”. When I pull the AlexaControl section out of the config.js they load without issue.
                                    @techcoderun perfect :slightly_smiling_face:
                                      sdetweil @BD0G
                                      @BD0G open the developers window, ctrl-shift-i, select the console tab, and see if there are any errors
                                        BD0G @sdetweil
                                        @sdetweil Still have not been able to open the Dev Console using Ctrl- Shift -i. :(
                                        • FoziF Offline
                                          Fozi Project Sponsor @techcoderun
                                          @techcoderun you just bought a new Dot and the mirror was detected?
                                            techcoderun @Fozi
                                            @Fozi Yes, literally just the new dot. But I had literally had the first Alexa that came out a few years ago, so it might of had some issues.
                                            • 3 / 5
