    Alexa Controll.... Some questions
    10 Posts 4 Posters 3.2k Views 4 Watching
    • C Offline
      Clubjack
      Hello everybody.
      I am very fresh in the matter and just about to build a MM.
      The first steps and experiences I have collected.
      I have now found out that you can insert different pages with “mm Page”.
      In a video I saw that you can switch to a specific page via “mmm alexa control” and the syntax: “alexa, Turn on Page #”.
      Is it possible to change this syntax?
      For example, “alexa, Change to Weather or alexa, change to Calendar?”
      Why I find this interesting?
      This could make the Startscreen very clean (small display of modules or none) and switch to a more detailed page when needed.
      I hope you understand what I mean. I am glad about your opinions and comments.
      J StoffbeuteluweS 2 Replies Last reply Reply Quote 0
        JoChef2 Module Developer
        This post is deleted!
          JoChef2 Module Developer @Clubjack
          @Clubjack It’s possible. You have to create a routine in your Alexa app. There you can create a custom voice command and a device that should turn on or off.
          • StoffbeuteluweS Offline
            Stoffbeuteluwe Project Sponsor @Clubjack
            @Clubjack https://forum.magicmirror.builders/topic/11568/hi-there-is-a-new-alexa-module?page=1
            • C Offline
              Clubjack
              @Stoffbeuteluwe
              Thank you.
              I read this thread. However, I could not find anything to changed announcements. Maybe we can communicate via PM in German. 😉 Or is it also allowed in the thread?
              • C Offline
                Clubjack
                I read it again.
                Now I probably understand it.
                Each newly created page will become a device in alexa.
                With a routine you can therefore select specific pages.
                Did I understand it correctly?
                Here’s an example:
                Page 1 with a calendar becomes device 1, page 2 with a newsfeed becomes device 2.
                I create a routine in alexa with “when I say open calendar, then activate device 1” etc.
                I’ll try that as soon as I have time again.
                Is it also possible that after a certain time again and again the main page appears?
                  @Clubjack That’s right. It should work with routines.
                  • P Offline
                    pumpy266
                    Why not change the name of the device that Alexa has found to something more memorable? Mine found page1, page 2 etc
                    Renaming, with the Alexa App on my phone, “page 1” to “clock” meant that the command “Alexa turn on clock” displays the clock page.
                      Stoffbeuteluwe Project Sponsor @JoChef2
                      @JoChef2 Hi, thanks for that amazing module I’m using it every day.
                      • C Offline
                        Clubjack
                        All that sounds very good. I will try it and hopefully I can do it.
                        Thank You all for that.
