    Black screen instead of desktop after installing PIR sensor
    31 Posts 5 Posters 17.5k Views 6 Watching
    • FoziF Offline
      Fozi Project Sponsor @09succotash
      @09succotash As said, copy the whole MM-folder, eg. via scp to another PC and then reinstall Raspbian.
      I’m sorry that I can’t provide a more satisfying solution:disappointed_face:
      • 0 Offline
        09succotash
        This post is deleted!
        • 0 Offline
          09succotash
          @Fozi Ahh, its ok. Thanks for your help, I’ll figure something out.
            sdetweil @09succotash
            @09succotash can u ssh into the machine?
            is MM running on pm2? do pm2 status, and if not stopped do pm2 stop for each line (use number or name)
            0 1 Reply Last reply Reply Quote 0
            • 0 Offline
              09succotash @sdetweil
              @sdetweil I cannot ssh into it. I am able to access the terminal though. MM is running on pm2, I just setup an autostart script for it. I don’t think MM is causing the issue, because the issue started just when I was setting up the PIR sensor.
                @09succotash but it can’t hurt to stop it…
                if you can get to terminal, then its not a desktop problem…
                • 0 Offline
                  @sdetweil I could only get to terminal, by right clicking somewhere on the screen. I tried stopping MM using pm2, didn’t have any effect.
                    @09succotash said in Black screen instead of desktop after installing PIR sensor:
                    ok, so desktop is running, even tho u might not be able to see it…
                    • 0 Offline
                      @sdetweil Exactly. It seems to be running, but my wallpaper, taskbar, and icons are gone. Black screen shows in its place.
                        @09succotash this is stretch or???
                        lsb_release -a in the terminal window
                        • 2 / 4
