    How to start smart mirror
    7 Posts 4 Posters 2.5k Views 5 Watching
      Atahan
      Hi there
      I am new raspberry and I install magicmiror.
      When I run the software with the code I shared below, nothing appears on the screen.
      cd ~/MagicMirror
      DISPLAY=:0 npm start
      When I look at module file from file manager, I see that modules like clock, calendar are installed. I’d appreciate it if you could help me.
      PS: I use raspberry pi4 2Gb and television
      • qu1queQ Offline
        qu1que Project Sponsor
        Take a look at your config.js file. At first installation, you have a file called config.js.sample. You must rename that file to config.js and try again.
        The path to those files is: /home/pi/MagicMirror/config/
          Atahan @qu1que
          @qu1que said in How to start smart mirror:
          Thank you for your comment. I try this but it doens’t fix. Can I ask one more question
          Does config file contain both config.js and config.js.sample files?
          qu1queQ Mykle1M 2 Replies Last reply Reply Quote 0
          • qu1queQ Offline
            qu1que Project Sponsor @Atahan
            @Atahan
            On a clean installation of MM, only config.js.sample exists, I think. You have to rename it to config.js and configure it as you wish. If config.js doesn’t exists, you can not watch anything on the screen of your mirror.
              Mykle1 Project Sponsor Module Developer @Atahan
              @Atahan
              I would make a copy of the config,js,sample and rename the copy to config.js, leaving the sample file as a safety net in case something goes wrong when you start editing.
              https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
              qu1queQ 1 Reply Last reply Reply Quote 0
                sdetweil
                The installer should have done all this for you
                • qu1queQ Offline
                  qu1que Project Sponsor @Mykle1
                  @Mykle1
                  Yes, always is a good idea to make a backup of a file before modified it :winking_face:
