    MMM-DarkSkyForecast one part to other section ? - styling question
    7 Posts 3 Posters 2.4k Views 3 Watching
    • T
      trividar
      Hi all and @j-e-f-f ;o)
      It is possible to move just the actual wether icon to to middle section of my Mirror and make it larger?
      ![Bild Text](0_1578403418360_Bildschirmfoto 2020-01-07 um 14.21.32.png Bild Link)
      and my second question is, It’s possible to add animated “.mov” format icons to this module? I have found some amazing icons, but just bevor I buy it i will be shure that it will be working…metgraphics Could someone help me with this? THX
      • T
        trividar
        Hmmmm no one can help?
        In general is that possible just to move this icons or a part from a module to an other section with css?
        THX
        StoffbeuteluweS 1 Reply Last reply
        • StoffbeuteluweS
          Stoffbeuteluwe Project Sponsor @trividar
          @trividar does your globe update automatically??
          T 1 Reply Last reply
          • T
            trividar @Stoffbeuteluwe
            @Stoffbeuteluwe thats an old picture, so I don‘t use the globe anymore. I would like to have a big actually animated weather icon. But can‘t figure it out how to do that ;0(
            lavolp3L 2 Replies Last reply
            • lavolp3L
              lavolp3 Module Developer @trividar
              @trividar You can’t easily move part of a module to a completely different section.
              So my answer is: “Not without tricks”.
              One “trick” would be to use the module in the center region a second time and hide everything but the cloud for that specific module. Slightly messy but possible via css.
              To the second question: There are animated icons included in MMM-DarkSkyForecast. Maybe have a look at that and check how these are implemented.
              How to troubleshoot modules
              MMM-soccer v2, MMM-AVStock
              • lavolp3L
                @trividar
                Also possible using MMM-DarkSkyForecast.
                You need to hide all forecast elements, all extra current conditions
                showExtraCurrentConditions: false,
                showSummary: false,
                showHourlyForecast: false,
                showDailyForecast: false
                and via your custom.css you need to set
                .MMM-DarkSkyForecast .current.temperature {
                    display: none;
                That hides hides current temperature and only shows the current icon.
                If you want to keep a complete second darksky-module you need to limit above selector to the region you where you want to hide the elements,
                e.g. .middle_center .MMM-DarkSkyForecast .current.temperature
                No guarantees this will work!
                • T
                  trividar @lavolp3
                  @lavolp3 Thanks sooooo much!! I will try your suggestion and let you know if it worked. The current weather icons are animated, but not as cool as this one in .mov ;o) But first I will try to have only the icon in the middle of the screen. Thanks!!!
