    MMM-NotificationTrigger transform payload
    24 Posts 4 Posters 7.6k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer @corius
      @corius So I tamed the beast but I’m getting the feeling that @Sean is right.
      The following would alert you of the next event every time the calendar sends a calendar_event notification:
      	  module: "MMM-NotificationTrigger",
      		triggers:[
      			trigger: "CALENDAR_EVENTS",
      			fires: [
      					fire:"SHOW_ALERT",
      					payload: (payload) => {
      						var testMessage = "";
      						var nextEvent = payload.find(event => event.startDate > moment().format("x"));
      						testMessage = nextEvent.title + " " + moment(nextEvent.startDate, "x").format("HH:mm");
      						return {
      							type: "notification",
      							title: "Next event:",
      							message: testMessage
      For some yet unknown reason, I am getting this alert 8 times! The alert then vanishes quite shortly after.
      It is a good idea, but what I would do, no, WILL do, is implement a “Notification Alert Function” directly into the calendar module (or into MMM-CalendarExt, if you’re interested, @Sean).
      I think that would be a better way of ontrolling the alert created from a calendar event appearing.
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
        sdetweil @lavolp3
        @lavolp3 said in MMM-NotificationTrigger transform payload:
        because it still sends an alert notification, with an empty payload
        fire:“SHOW_ALERT”, (always)
        • lavolp3L Offline
          lavolp3 Module Developer @sdetweil
          @sdetweil As far as I understand, it triggers when receiving the CALENDAR_EVENTS noti, and then “fires” a new notification, which is the “SHOW_ALERT” with the new payload.
          This does not explain to me why it sends the “SHOW_ALERT” noti apparently 8 times in a row.
            sdetweil @lavolp3
            @lavolp3 cause calendar payload events is an array, fires once per
