    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 17.8k Views 9 Watching
    • I Offline
      iorifly
      I tried this option but also to no avail.
      https://github.com/aserramonner/MMM-HASS/pull/13
        darbos @iorifly
        @iorifly to dvbit point you could just use fullpageos if you just want to display a Lovelace tab…
        Also, I have had homeassistany sensors working recently…if you want to give some more detail of what you’ve done and what the problem is. And share you relevant code I can try to help…
        • I Offline
          iorifly @darbos
          @darbos
          I would love to know how to display only one lovelace tab. But still it would be the whole screen or I can go down the screen to show only what I want.
          I have my problem report here too:
          https://community.home-assistant.io/t/magic-mirror/8443/59
          what do you need ? I can pass everything !!!
            dvbit
            You can use a custom card called custom header to minimize the top and right bar . also having it happen just for the mm through user agent recognition
              sdetweil @iorifly
              @iorifly add debuglogging: true,
              to the config.js for the HASS module
              it doesn’t handle errors at all… but will report status if that flag is enabled
              request(get_options, function(error, response, body) {
                        completed_requests++;
                        if(config.debuglogging) {
                          console.log(error);
                          console.log(body);
              • I Offline
                iorifly @sdetweil
                added it to my config.js. However nothing happened or signaled … Thanks anyway.
                  sdetweil @iorifly
                  @iorifly Will be in the terminal window, or pm2 logs output
                  • I Offline
                    iorifly
                    I managed to solve !!! Connected !!! THANKS !!
                      sdetweil @iorifly
                      @iorifly what was it? Can’t keep us guessing!
                      • I Offline
                        iorifly
                        I created another token (in HA). and replace in the module.
                        • 3 / 4
