    Which modules with Home Assistant currently work?
    39 Posts 7 Posters 17.8k Views 9 Watching
    • I Offline
      iorifly
      but I will try to use this module. It seems to be more complete.
      https://github.com/leinich/MMM-homeassistant-sensors
      I will create another token in the Home assistant (HA) for him.
      • I Offline
        iorifly
        actually this module is also working. That is,
        operational modules tested by me:
        MMM-HASS
          Babene1 Project Sponsor
          i want to use the modul MMM-HASS
          but i get the error in HA “Login attempt or request with invalid authentication from”
          i use Home Assistant 0.116.2
          here is my MM-Config from the Modul:
                     module: "MMM-HASS",
                             host: "xxx.xxx.xxx.xxx",
                             port: "8123",
                             apipassword: "xxxxxx",
                             hassiotoken: true,
                             token: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                             https: false,
                             devices: [
                             { deviceLabel: "Temp Test",
                                     deviceReadings: [
                                     { sensor: "sensor.temp1", icon: "wi wi-thermometer", suffix: "°"},
                                     { sensor: "sensor.temp1 _2", icon: "wi wi-humidity", suffix: "%"},
          In MM:
          Temp Test undefined°undefined%
          Log from MM:
          [2021-01-09 10:36:47.251] [LOG] { undefined: undefined, label: Temp Test }
          [2021-01-09 10:37:47.408] [LOG] Request URL: http://xxx.xxx.xxx.xxx:8123/api/states/sensor. temp1?api_password= xxxxxx
          [2021-01-09 10:37:47.408] [LOG] Request URL: http://xxx.xxx.xxx.xxx:8123/api/states/sensor. temp1_2?api_password= xxxxxx
          [2021-01-09 10:37:47.524] [LOG] { undefined: undefined, label: Temp Test }
          What I have to config in HA? Would be really grateful for tips
            Babene1 Project Sponsor @Babene1
            Only for information, in case someone has the same problem.
            The module works for me now, with the above configuration
            I found the following articles: https://github.com/aserramonner/MMM-HASS/pull/13/commits/bd816304ba146ad84bce5cada65cb3416194aca7
            I made these changes: In File „node_helper.js“ von MMM-HASS
            row 130 changed in:
            post_options.headers = { 'Authorization' : 'Bearer ' + config.token };
            row 176 changed in:
            get_options.headers = { 'Authorization' : 'Bearer ' + config.token };
            Coolie1101C 1 Reply Last reply Reply Quote 0
            • Coolie1101C Offline
              Coolie1101 @Babene1
              @babene1 Hey, I followed your setup instructions but still get undefined for the sensors, any ideas?
              Config
                                      module: "MMM-HASS",
                                              host: "hass_ip",
                                              port: "8123",
                                              apipassword: "hass_api_password",
                                              hassiotoken: "true",
                                              token: "hass_token_for_MMM-HASS"
                                              https: false,
                                              devices: [
                                              { deviceLabel: "Interior",
                                                      deviceReadings: [
                                                      { sensor: "sensor.living_room_thermostat_temperature"},
                                                      { sensor: "sensor.living_room_ac_temperature"}
                Babene1 Project Sponsor @Coolie1101
                @coolie1101 do you make changes in „node_helper.js“ from MMM-HASS?
                  Coolie1101 @Babene1
                  @babene1 yes
                    @coolie1101 do you have an error entry in the home assistant log?
                      Coolie1101 @Babene1
                      @babene1 No, no errors, in HA.
                      • 4 / 4
