    Memory effect with MM2
    16 Posts 8 Posters 11.2k Views 8 Watching
    • strawberry 3.141S Offline
      strawberry 3.141 Project Sponsor Module Developer @schlachtkreuzer6
      @schlachtkreuzer6
      MMM-Anti-Screen-Burn-In.css
      .MMM-Anti-Screen-Burn-In {
          margin: 55px 55px 65px 65px; /*this would shift it 5 pixels higher and 5 pixels to the right side than the standard of 60px on each side*/
      MMM-Anti-Screen-Burn-In.js
      start: function(){
          setInterval(() => {
              document.querySelector("body").classList.toggle("MMM-Anti-Screen-Burn-In");
          }, 6 * 60 * 60 * 1000); // every 6 hours
      getStyles: function(){
          return ["MMM-Anti-Screen-Burn-In.css"];
      schlachtkreuzer6S lolobyteL K 3 Replies Last reply Reply Quote 1
      • schlachtkreuzer6S Offline
        schlachtkreuzer6 @strawberry 3.141
        @strawberry-3.141 WOW! Nice :) Thanks!
        • lolobyteL Offline
          lolobyte @strawberry 3.141
          @strawberry-3.141
          Great, i’ll try it!
          • K Offline
            kj3rra @strawberry 3.141
            @strawberry-3.141 Hi. This is exactly what I need. However, I dont know how to proceed with the information. Yes, I made the .css and .js file and put them in a new folder inside the module folder, but how do I then “activate” this? Could someone be so kind and explain step by step how to make this work?
            Sorry for not knowing this I presume is quite basic, but so far I only installed ready made modules :)
            • W Offline
              wladek
              @strawberry-3.141 I tried to get your class into my MM but I don’t know where to put the .css and .js files and how to toggle them.
                sdetweil @wladek
                @wladek you add the css file to your module folder… and then modify your module.js code per the instructions above to load the css, and the timer code to invoke the other css…
                you could also make a complete new module with a little more code…
                make a folder
                MM/modules/MMM-Anti-Screen-Burn-In
                put the css file in that folder
                create a new file in that folder
                Module.register("MMM-Anti-Screen-Burn-In", {
                start: function(){
                    setInterval(() => {
                getDom: function(){
                  return wrapper
                and the module to config.js
                   module: "MMM-Anti-Screen-Burn-In",
                   position: middle
                • W Offline
                  wladek @sdetweil
                  @sdetweil Tried that before, somehow works now though, thanks!
                  Only problem I have now is that the module displays two line of text right across the rest of my modules:
                  module_8_MMM-Anti-Screen-Burn-In
                  I didn’t add any text to the .js or .css file tho and I can’t figure out how to get rid of it.
                    sdetweil @wladek
                    @wladek oops… if no getDom(), MM puts out some content
                    replace the js file with this
                    start: function(){
                        setInterval(() => {
                    getDom: function(){
                      return wrapper
                    • W Offline
                      wladek @sdetweil
                      @sdetweil That has fixed it, thank you so much!
                      • T Offline
                        toucherts
                        how do I then “activate” it?
                        Speed Test Scrabble Word Finder Solitaire
