    Memory effect with MM2
    16 Posts 8 Posters 12.3k Views 8 Watching
      schlachtkreuzer6 @strawberry 3.141
      @strawberry-3.141 yeah but i´m a css noob. maybe you can explain that a little? many thanks!
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @schlachtkreuzer6
        @schlachtkreuzer6
        MMM-Anti-Screen-Burn-In.css
        .MMM-Anti-Screen-Burn-In {
            margin: 55px 55px 65px 65px; /*this would shift it 5 pixels higher and 5 pixels to the right side than the standard of 60px on each side*/
        MMM-Anti-Screen-Burn-In.js
        start: function(){
            setInterval(() => {
                document.querySelector("body").classList.toggle("MMM-Anti-Screen-Burn-In");
            }, 6 * 60 * 60 * 1000); // every 6 hours
        getStyles: function(){
            return ["MMM-Anti-Screen-Burn-In.css"];
        S L K 3 Replies Last reply Reply Quote 1
          @strawberry-3.141 WOW! Nice :) Thanks!
          • L Offline
            lolobyte @strawberry 3.141
            @strawberry-3.141
            Great, i’ll try it!
            • K Offline
              kj3rra @strawberry 3.141
              @strawberry-3.141 Hi. This is exactly what I need. However, I dont know how to proceed with the information. Yes, I made the .css and .js file and put them in a new folder inside the module folder, but how do I then “activate” this? Could someone be so kind and explain step by step how to make this work?
              Sorry for not knowing this I presume is quite basic, but so far I only installed ready made modules :)
              • W Offline
                wladek
                @strawberry-3.141 I tried to get your class into my MM but I don’t know where to put the .css and .js files and how to toggle them.
                  sdetweil @wladek
                  @wladek you add the css file to your module folder… and then modify your module.js code per the instructions above to load the css, and the timer code to invoke the other css…
                  you could also make a complete new module with a little more code…
                  make a folder
                  MM/modules/MMM-Anti-Screen-Burn-In
                  put the css file in that folder
                  create a new file in that folder
                  Module.register("MMM-Anti-Screen-Burn-In", {
                  start: function(){
                      setInterval(() => {
                  getDom: function(){
                    return wrapper
                  and the module to config.js
                     module: "MMM-Anti-Screen-Burn-In",
                     position: middle
                  • W Offline
                    wladek @sdetweil
                    @sdetweil Tried that before, somehow works now though, thanks!
                    Only problem I have now is that the module displays two line of text right across the rest of my modules:
                    module_8_MMM-Anti-Screen-Burn-In
                    I didn’t add any text to the .js or .css file tho and I can’t figure out how to get rid of it.
                      sdetweil @wladek
                      @wladek oops… if no getDom(), MM puts out some content
                      replace the js file with this
                      start: function(){
                          setInterval(() => {
                      getDom: function(){
                        return wrapper
                      • W Offline
                        wladek @sdetweil
                        @sdetweil That has fixed it, thank you so much!
                        • T Offline
                          toucherts
                          how do I then “activate” it?
                          Speed Test Scrabble Word Finder Solitaire
                            sdetweil @toucherts
                            @toucherts every 6 hours it toggles the class used to present the screen.
                            I just made a little module package on github
                            https://github.com/sdetweil/MMM-Anti-Screen-Burn-In
                              moali6705 @sdetweil
                              @sdetweil said in Memory effect with MM2:
                              OK GOOD
