    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 81.0k Views 25 Watching
    • ? Offline
      A Former User
      useSnowboy: true,
      if you use this feature, you need to update AMk2
      npm run update
      try this in AMk2 directory
      and enable snowboy library (and electron rebuild for snowboy)
        sdetweil @jimmydew
        @jimmydew in the future please use the markdown for code
        select the text and hit the </> icon above the editor
          jimmydew @Guest
          @Bugsounet
          i got quite a few errors on the rebuild:
          ✖ Rebuild Failed
          An unhandled error occurred inside electron-rebuild
          make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
            CXX(target) Release/obj.target/snowboy/lib/snowboy.o
          In file included from /home/pi/.electron-gyp/6.1.7/include/node/v8-internal.h:14,
                           from /home/pi/.electron-gyp/6.1.7/include/node/v8.h:25,
                           from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
                           from ../../../nan/nan.h:56,
                           from ../lib/snowboy.cc:1:
          /home/pi/.electron-gyp/6.1.7/include/node/v8config.h:326:49: warning: ‘MicrotasksCompletedCallback’ is deprecated [-Wdeprecated-declarations]
             declarator __attribute__((deprecated(message)))
          /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8205:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
             V8_DEPRECATE_SOON("Use *WithData version.",
          /home/pi/.electron-gyp/6.1.7/include/node/v8.h:8214:3: note: in expansion of macro ‘V8_DEPRECATE_SOON’
          In file included from ../lib/snowboy.cc:1:
          ../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
          ../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
               , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
          ../lib/snowboy.cc: In constructor ‘SnowboyDetect::SnowboyDetect(const string&, const string&)’:
          ../lib/snowboy.cc:38:31: warning: catching polymorphic type ‘class std::runtime_error’ by value [-Wcatch-value=]
             } catch (std::runtime_error e) {
          In file included from ../../../nan/nan.h:56,
          ../lib/snowboy.cc: At global scope:
          /home/pi/.electron-gyp/6.1.7/include/node/node.h:572:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]
                 (node::addon_register_func) (regfunc),                          \
          /home/pi/.electron-gyp/6.1.7/include/node/node.h:606:3: note: in expansion of macro ‘NODE_MODULE_X’
             NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
          ../lib/snowboy.cc:183:1: note: in expansion of macro ‘NODE_MODULE’
           NODE_MODULE(SnowboyDetect, SnowboyDetect::Init)
          In file included from /home/pi/.electron-gyp/6.1.7/include/node/node.h:63,
          /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:
          /home/pi/.electron-gyp/6.1.7/include/node/node_object_wrap.h:84:78:   required from here
          /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
                          reinterpret_cast<Callback>(callback), type);
          /home/pi/.electron-gyp/6.1.7/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:
          ../../../nan/nan_object_wrap.h:65:61:   required from here
          /home/pi/.electron-gyp/6.1.7/include/node/v8.h:9810:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
            SOLINK_MODULE(target) Release/obj.target/snowboy.node
          /usr/bin/ld: cannot find -lcblas
          collect2: error: ld returned 1 exit status
          make: *** [snowboy.target.mk:143: Release/obj.target/snowboy.node] Error 1
          make: Leaving directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
          gyp ERR! build error
          gyp ERR! stack Error: `make` failed with exit code: 2
          gyp ERR! stack     at ChildProcess.onExit (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/node-gyp/lib/build.js:194:23)
          gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
          gyp ERR! System Linux 5.4.35-v7l+
          gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/.bin/node-gyp" "rebuild" "--target=6.1.7" "--arch=arm" "--dist-url=https://www.electronjs.org/headers" "--build-from-source" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm" "--remote_path=./snowboy/v1.4.7/Release/" "--package_name=snowboy-v1.4.7-electron-v6.1-linux-arm.tar.gz" "--host=https://github.com/bugsounet/snowboy"
          gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
          gyp ERR! node -v v10.20.1
          gyp ERR! node-gyp -v v6.1.0
          gyp ERR! not ok
          Failed with exit code: 1
          Error: make: Entering directory '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/build'
          gyp ERR! not ok
              at SafeSubscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:267:84)
              at SafeSubscriber.__tryOrUnsub (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:205:16)
              at SafeSubscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:156:26)
              at Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
              at Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
              at MapSubscriber.Subscriber._error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:92:26)
              at MapSubscriber.Subscriber.error (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:72:18)
              at SafeSubscriber._next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/spawn-rx/lib/src/index.js:242:65)
              at SafeSubscriber.next (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/rxjs/internal/Subscriber.js:143:22)
          > @bugsounet/snowboy@1.4.7 postinstall /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy
          > tsc -p tsconfig.json
          + @bugsounet/snowboy@1.4.7
          added 20 packages from 25 contributors and audited 315 packages in 38.481s
          3 packages are looking for funding
            run `npm fund` for details
          found 6 low severity vulnerabilities
            run `npm audit fix` to fix them, or `npm audit` for details
          @bugsounet/snowboy library installed
          • ? Offline
            A Former User
            @jimmydew said in MMM-AssistantMk2 (v3):
            Linux 5.4.35-v7l+
            ah …
            and what version of gcc do you use ?
            try gcc --version in console
              jimmydew @Guest
              @Bugsounet
              pi@raspberrypi:~/MagicMirror $ gcc --version
              gcc (Raspbian 7.3.0-19) 7.3.0
              Copyright (C) 2017 Free Software Foundation, Inc.
              This is free software; see the source for copying conditions.  There is NO
              warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
              • E Offline
                electros Project Sponsor @Guest
                @Bugsounet Hi, again. I managed to make my radio station list and everything works fine, just I don’t know how to stop the radio. Can you please explain me how to add a stop radio command?
                Thank you
                • ? Offline
                  A Former User
                  @jimmydew can you do this command for more informations, please ?
                  cat /etc/*release
                  @electros :
                  Good job !
                  For stop radio (and other A2D module), i create a feature in AMk2 (A2D Server part)
                  You can define your prefered stop command
                  by default it’s stop but … it’s depend of your language !
                  for exemple in french language, when i say stop, google transcript stoppe
                  you have an exemple in AMk2 structure sample
                  E J 2 Replies Last reply Reply Quote 0
                  • E Offline
                    @Bugsounet OK I understand that but if I configure that “stop” in english for example just I must say " jarvis stop" or “jarvis stop radio” ?
                    • ? Offline
                      A Former User
                      It’s depend what’s google return in transcription
                      for verify what it return
                      You have 2 solutions:
                      1. turn Fullscreen ui , activate jarvis and say stop.
                        AMk2 will display in real time what it understand, so if it display stop, it’s ok
                        en french it display stoppe then i have to modify A2DStopCommand: "stoppe",
                      2. in console and debug mode actived
                        you will see the transcription of google
                        transcription: { transcription: 'stoppe', done: true },
                      notes:
                      • if you say stop and method 1 or 2 result is stop too
                        no A2DStopCommand configuration require
                      • stop command defined in A2DStopCommand stops all process of A2D : weblinks, cast, youtube, radio, photos (and MMM-FreeboxTV for french user)
                      Use:
                      just say jarvis (for activating) … stop (or your prefered A2DStopCommand)
                      • E Offline
                        @Bugsounet OK, thank you
                        • 7
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 14
                        • 9 / 14
