    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 84.1k Views 25 Watching
      jimmydew @Guest
      @Bugsounet
      sure:
      pi@raspberrypi:~/MagicMirror $ cat /etc/*release
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      • ? Offline
        A Former User
        gyp ERR! System Linux 5.4.35-v7l+
        in the raspbian web site i see this:
        Raspbian Buster with desktop
        Image with desktop based on Debian Buster
        Version:February 2020
        Release date:2020-02-13
        Kernel version:4.19
        i don’t know why you are the 5.4.x kernel version and it seams the problem
        I don’t try to compile it with it so … sorry, i can’t help
        retry with 4.19.x kernel version
          jimmydew @Guest
          @Bugsounet
          hmm okay, is there a way to change my kernel version??
            sdetweil @jimmydew
            @jimmydew load a different version of the OS
              jimmydew @sdetweil
              oke thank you but I dont now how I load a diffrent Os
                sdetweil @jimmydew
                @jimmydew flash the SD card with a different is version
                  jimmydew @sdetweil
                  @sdetweil i have done now ive installed MM again and it gives me this on startup,
                  [2020-05-19 00:24:34.545] [LOG]    Whoops! There was an uncaught exception...
                  [2020-05-19 00:24:34.545] [ERROR]  Error: Cannot find module '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/binding/Release/electron-v6.1-linux-arm/snowboy.node'
                  Require stack:
                  - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js
                  - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js
                  - /home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js
                      at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                      at Module.require (internal/modules/cjs/loader.js:685:19)
                      at require (internal/modules/cjs/helpers.js:16:16)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js:8:29)
                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                      at Module.load (internal/modules/cjs/loader.js:645:32) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/lib/node/index.js',
                      '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_modules/@bugsounet/snowboy/index.js',
                      '/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js',
                      '/home/pi/MagicMirror/js/app.js',
                      '/home/pi/MagicMirror/js/electron.js',
                      '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                      undefined
                  [2020-05-19 00:24:34.562] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2020-05-19 00:24:34.563] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  [2020-05-19 00:24:34.565] [LOG]    [A2D] MMM-Assistant2Display Version: 1.5.2
                  [2020-05-19 00:24:34.566] [LOG]    [A2D] Assistant2Display is initialized.
                  [2020-05-19 00:26:55.124] [LOG]    Shutting down server...
                  [2020-05-19 00:26:55.126] [LOG]    Stopping module helper: calendar
                  [2020-05-19 00:26:55.128] [LOG]    Stopping module helper: newsfeed
                  [2020-05-19 00:26:55.129] [LOG]    Stopping module helper: MMM-AssistantMk2
                  [2020-05-19 00:26:55.130] [LOG]    Stopping module helper: MMM-Assistant2Display
                  it still not detects my voice, only when i click on the assistant
                    sdetweil @jimmydew
                    @jimmydew @Bugsounet will be by to help…
                    • ? Offline
                      A Former User
                      I ordered an RPI4, I await the end of delivery for tomorrow.
                      So I’m going to do a new installation on it.
                      I come back to you once done
                        sdetweil @Guest
                        @Bugsounet use my script…
                        • 8
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 14
                        • 10 / 14
