    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 78.7k Views 25 Watching
      amsuvarna27 @costascontis
      This post is deleted!
      • ? Offline
        A Former User
        MMM-AssistantMk2 v3.2.3
        NEW UPDATES
        3.2.3 (30/04/2020)
        • ADD: New ui -> Simple
        • OPT: Optional Build with Snowboy embed
        • ADD: A2DStopCommand for personalize your stop command (Assistant2Display Server)
        • FIX: some logs
        3.2.2 (17/04/2020)
        • FIX: Package.json (google-assistant)
        E 1 Reply Last reply Reply Quote 1
        • E Offline
          electros Project Sponsor @Guest
          @Bugsounet Hi, I installed this module and A2D module and it’s working fine just few small problems:
          1 When I want to use this module with A2D and the answer is coming on the screen all the modules is go hiding and its coming back on the screen after 1 minute. If I use without A2D everything works fine and the modules just go blurred behind of the answer window and come back fast.
          2 it’s try to use that radio recipe but I can’t manage to start any radio station. I don’t know how it’s work. Every time when the assistant understands station name he look on the Internet to find information about that radio station but never want to start listening. I must install something else ?
          Apart of this everything it’s fine and the module it’s brilliant. Thank you for this.
          • ? Offline
            A Former User
            hi @electros
            1. i think you forget MagicMirror configuration part
              Read here
            2. i have prepare a guide for create it
              Read here
            but it’s not finish … there is some surprise again … if i have a lot of time ;)
            • E Offline
              @Bugsounet
              Hello again. I tried what you recommended but without much success. First I made the settings for A2D as you recommended and now when I ask something after the assistant answers me an internet window opens with reference to the answer this being a new and very good thing. But when the assistant starts saying the answer, it hides the modules on the screen apart of calendarext. I was talking about this in the post above. I put a short video on youtube.
              https://youtu.be/DOIkuA60tKo
              As for the radio, I tried after that tutorial but without success.
              I tried to use that file “with-radio_fr.js” but when I say “cheriefm” the assistant shows me the website of the radio station “cheriefm” saying “here is what I found on the web” without starting the radio station.
              Thank you.
              • ? Offline
                A Former User
                @electros said in MMM-AssistantMk2 (v3):
                it’s a know bug of calendarext
                ah … “cheriefm” is the name of the block (like a landmark)
                the think to say is “mets chérie fm” in the sample.
                you can try to change it for your language with pattern value
                exemple: if you change pattern value to radio test
                if you say : radio test it will reconize the cheriefm command and execute it (send to A2D mp3 link of the radio and img)
                E 2 Replies Last reply Reply Quote 0
                • E Offline
                  @Bugsounet said in MMM-AssistantMk2 (v3):
                  okay but couldn’t remain all the modules on the screen behind the assistant window?
                  Well I need to practice more with this. for a start I think I should look for another microphone, the assistant doesn’t really understand what I’m saying.
                  Do you think a respeaker board with 2 microphones would be better than a USB microphone?
                  SergeS 1 Reply Last reply Reply Quote 0
                  • SergeS Offline
                    Serge @electros
                    One possible solution for mic
                    Working on getting a good hardware solution for MMM-AssistantMK2
                    • E Offline
                      electros Project Sponsor @Serge
                      @Serge Thank you for the link i was looking for a solution like that.
                        jimmydew
                        Hey everyone, I have a problem with the MMM-assistantMk2:
                        The Icon is showing on the mirror, when i click on it in VNC it activates,and works. but it doesnt activate by my voice on the mirror.
                        any ideas? these are my configs:
                        var config = {
                        	port: 8080,
                        	language: "en",
                        	timeFormat: 24,
                        	units: "metric",
                        			     // false, default for all  NON-armv6l devices
                        			module: "clock",
                        			position: "top_left"
                        			header: "US Holidays",
                        						symbol: "calendar-check",
                        						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                        			module: "compliments",
                        			position: "lower_third"
                        			module: "currentweather",
                        				locationID: "", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                        				appid: "YOUR_OPENWEATHER_API_KEY"
                        			module: "weatherforecast",
                        			header: "Weather Forecast",
                        				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                        			module: "newsfeed",
                        			position: "bottom_bar",
                        				feeds: [
                        						title: "New York Times",
                        				showSourceTitle: true,
                        				showPublishDate: true,
                        				broadcastNewsFeeds: true,
                        				broadcastNewsUpdates: true
                          module: "MMM-AssistantMk2",
                            debug: false,
                            ui: "Classic", // Classic2, Classic or Simple
                            // if you want Google Nest ui style
                            // set Fullscreen ui AND fullscreen_above position
                            assistantConfig: {
                              projectId: "", // Required to use gaction.
                              modelId: "", // (OPTIONAL for gaction)
                              instanceId: "", // (OPTIONAL for gaction)
                              latitude: 52.0955919,
                              longitude: 4.4711253,
                            responseConfig: {
                              useHTML5: true, // sound render by HTML5
                              useScreenOutput: true,
                              useAudioOutput: true,
                              useChime: true,
                              timer: 5000,
                              myMagicWord: true,
                              //Your prefer sound play program.
                              //By example, if you are running this on OSX, `afplay` could be available.
                              //by default mpg321 play program is enabled
                              //if audio output cutting try with mpg123 or cvlc program
                              playProgram: "mpg321",
                              chime: {
                                beep: "beep.mp3",
                                error: "error.mp3",
                                continue: "continue.mp3",
                                open: "Google_beep_open.mp3",
                                close: "Google_beep_close.mp3",
                              // false - animated icons, 'standby' - static icons only for standby state, true - all static icons
                              useStaticIcons: false
                            micConfig: { // put there configuration generated by auto-installer
                              recorder: "arecord",
                              device: "plughw:1",
                            customActionConfig: {
                              autoMakeAction: false,
                              autoUpdateAction: false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                              actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
                            recipes: [ "with-MMM-TelegramBot.js" ],
                            profiles: {
                              "default": {
                                profileFile: "default.json",
                                lang: "en-US"
                            useA2D: false,
                            A2DStopCommand: "stop",
                            useSnowboy: true,
                            snowboy: {
                              audioGain: 2.0,
                              Frontend: true,
                              Model: "jarvis",
                              Sensitivity: null
                        (it’s running on raspberry pi 4b)
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 13
                        • 14
                        • 8 / 14
