    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 107.7k Views 25 Watching
      A Former User
      @sdetweil : of course ! it’s planned ! ;)
        A Former User
        yeah, I receive my RPI, SD card but missing : RPI case, fan and power supply
        It’s the second order and it’s will be deliver tomorrow ;)
        Note: ahahah, I have no RPI for developping !!!
        • L
          Lasmazze
          Hi everyone!
          The module works very well. Good work!
          I just have a request:
          When I say “JARVIS” I would like the sound to be cut or lowered to the minimum if not the assistant records what it is broadcasting like the radio or a youtube video. When I finish talking to the assistant, I would like the sound to come back as it was before.
          Thank you in advance for your help!
            A Former User
            @jimmydew : i confirm there is a bug in my installer. (missing 2 library, I say “bravo !” in French)
            I correct it ;)
            in AMk2 directory retry with:
            npm run update
            and do all process
            It should work now
            • T
              triguyrn
              What microphone/speaker are you all using?
              Looking to add voice control to my mirror as well!
                sdetweil @triguyrn
                @triguyrn I use a Logitech C270 webcam, and also just added a PlayStation Eye webcam to one of them
                • Cr4z33C
                  Cr4z33 @Guest
                  @Bugsounet I’ve turner on my MagicMirror after a stop of 6 months.
                  At first I ran sudo apt-get update && sudo apt-get upgrade, then I updated both MM and its modules.
                  Now MM it ends up with a black screen.
                  So I ran npm run update in MMM-AssistantMk2 folder and answered Yes to all the answers.
                  I still keep getting the black screen at the end of MM loading.
                  What shall I do next now? :smiling_face_with_open_mouth_cold_sweat:
                  Here’s what happening:
                  > magicmirror@2.11.0 start /home/pi/MagicMirror
                  [2020-05-22 08:14:49.750] [LOG]    Starting MagicMirror: v2.11.0
                  [2020-05-22 08:14:49.763] [LOG]    Loading config ...
                  [2020-05-22 08:14:49.776] [LOG]    Loading module helpers ...
                  [2020-05-22 08:14:49.792] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:49.794] [LOG]    Module helper loaded: MMM-WatchDog
                  [2020-05-22 08:14:49.926] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:49.927] [LOG]    Module helper loaded: MMM-Remote-Control
                  [2020-05-22 08:14:51.650] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:51.651] [LOG]    Module helper loaded: MMM-RTSPStream
                  [2020-05-22 08:14:51.652] [LOG]    No helper found for module: alert.
                  [2020-05-22 08:14:51.717] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:51.718] [LOG]    Module helper loaded: updatenotification
                  [2020-05-22 08:14:51.780] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:51.781] [LOG]    Module helper loaded: newsfeed
                  [2020-05-22 08:14:53.984] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:53.985] [LOG]    Module helper loaded: MMM-AssistantMk2
                  [2020-05-22 08:14:53.986] [LOG]    No helper found for module: clock.
                  [2020-05-22 08:14:54.001] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:54.002] [LOG]    Module helper loaded: MMM-Spotify
                  [2020-05-22 08:14:54.583] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:54.584] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                  [2020-05-22 08:14:55.464] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:55.465] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                  [2020-05-22 08:14:55.472] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module '@bugsounet/lpcm16'
                  Require stack:
                  - /home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js
                  [2020-05-22 08:14:55.473] [LOG]    Loading module helpers ...
                  [2020-05-22 08:14:55.484] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:55.486] [LOG]    Module helper loaded: MMM-WatchDog
                  [2020-05-22 08:14:55.486] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:55.487] [LOG]    Module helper loaded: MMM-Remote-Control
                  [2020-05-22 08:14:55.488] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:55.489] [LOG]    Module helper loaded: MMM-RTSPStream
                  [2020-05-22 08:14:55.490] [LOG]    No helper found for module: alert.
                  [2020-05-22 08:14:55.491] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:55.492] [LOG]    Module helper loaded: updatenotification
                  [2020-05-22 08:14:55.493] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:55.494] [LOG]    Module helper loaded: newsfeed
                  [2020-05-22 08:14:55.497] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:55.500] [LOG]    Module helper loaded: MMM-AssistantMk2
                  [2020-05-22 08:14:55.502] [LOG]    No helper found for module: clock.
                  [2020-05-22 08:14:55.504] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:55.505] [LOG]    Module helper loaded: MMM-Spotify
                  [2020-05-22 08:14:55.507] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:55.509] [LOG]    Module helper loaded: MMM-DarkSkyForecast
                  [2020-05-22 08:14:55.510] [LOG]    Initializing new module helper ...
                  [2020-05-22 08:14:55.512] [LOG]    Module helper loaded: MMM-PushBulletNotifications
                  [2020-05-22 08:14:55.517] [ERROR]  App threw an error during load
                  [2020-05-22 08:14:55.519] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                  Require stack:
                      at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                      at Module.require (internal/modules/cjs/loader.js:685:19)
                      at require (internal/modules/cjs/helpers.js:16:16)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js:9:16)
                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                      at Module.load (internal/modules/cjs/loader.js:645:32)
                  [2020-05-22 08:14:55.522] [LOG]    Whoops! There was an uncaught exception...
                  [2020-05-22 08:14:55.523] [ERROR]  Error: Cannot find module '@bugsounet/lpcm16'
                  Require stack:
                      at Module.load (internal/modules/cjs/loader.js:645:32) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/home/pi/MagicMirror/modules/MMM-Hotword/node_helper.js',
                      '/home/pi/MagicMirror/js/app.js',
                      '/home/pi/MagicMirror/js/electron.js',
                      '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                      undefined
                  [2020-05-22 08:14:55.542] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [2020-05-22 08:14:55.546] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                  Fontconfig warning: "/etc/fonts/fonts.conf", line 100: unknown element "blank"
                  [2020-05-22 08:14:55.768] [LOG]    Launching application.
                    A Former User
                    @Cr4z33: just because this errror is not related to MMM-AssistantMk2 module ;)
                    • Cr4z33C
                      Cr4z33 @Guest
                      @Bugsounet oops sorry then! 😅
                      • A
                        acowx
                        I am trying to work out how I can use MMM-AssistantMk2 to voice control the MMM-CalendarExt2 module.
                        My basic needs are to use a voice command to notify MMM-CalendarExt2 to swap to another view.
                        eg, I say “[wakeword] scene monthly” and the Calendar Module will swap to a scene which shows my Monthly calendar view.
                        Or I say “[wakeword] scene weekly” and the Calendar Module will swap to a scene which shows my Weekly calendar view.
                        I have considered TelegramBot but I don’t think that is triggered by a voice command ?
                        Any ideas guys ?
                          sbonn13
                          AssistantMk2 works awesome also together with 2Display. I am in love with that :)
                          User request: I would like to open news as video like https://www.tagesschau.de/100sekunden/ or via youtube play list https://www.youtube.com/user/tagesschau (German public broadcasting service)
                          Problem: Searching Youtube + tagesschau is replied by Google assistant that the news function would not be available for this device yet.
                          Is there a workaround I could use/implement?
                          E.g. Specific search terms opens automatically a specified youtube link or a specific website?
                            sdetweil @acowx
                            @acowx the MMM-Assistant* modules have been terminated, please move to the new MMM-GoogleAssistant module
                              sbonn13
                              Thanks Sam. Sorry I was not aware of. Closed.
                              • A
                                ahmedalkabir @sdetweil
                                @sdetweil why the repository of MMM-AssistantMk2 deleted, is there something happened because I can’t find it anywhere>
                                • A
                                  ahmedalkabir @Guest
                                  @Sean https://github.com/eouia/MMM-AssistantMk2
                                  it doesn’t work anymore, what’s the problem ?
                                  • J
                                    JohnBachini @ahmedalkabir
                                    @ahmedalkabir It’s been replaced with MMM-GoogleAssistant
                                    • A
                                      ahmedalkabir @JohnBachini
                                      @JohnBachini oh, so MMM-GoogleAssitant is better than the older one?
                                      • J
                                        JohnBachini
                                        @ahmedalkabir
                                        Yes it seems to be , Bugsounet took over MMM-Assistantmk2 and then did his magic and turned it into GoogleAssistant 👍
                                        • I
                                          Ivanov_d
                                          Well, now as @Bugsounet closed his modules for MM and @Sean deleted the AssistantMk2 repo the MM users are left without Voice control. Great!
                                            A Former User
                                            no one ask to you use my modules… try to code your own ;)
                                            BUT If I close something … It’s for Made better !!!
                                            SO wait and see (in a couple of day)
                                            OR don’t use it ;)
                                            IN ALL CASE: AMK2 have been totaly recoded (only sound)… and jsut after… deprecied.
                                            If you like only deprecied module or not maintened modules let make your choise in 3rd party module ! 90% of modules have not been maintened since +/- 2 years ;)
                                            @Ivanov_d : for you information :
                                            It’s my module…
                                            • 6
                                            • 7
                                            • 6 / 7
