    MMM-AssistantMk2
    16 Posts 3 Posters 6.2k Views 2 Watching
    • L Offline
      ludacriss57
      Hello,
      I have a problem with my google assistant. everything works fine except youtube.
      when i request a youtube request, the wizard opens a window with the google link, but does not open youtube.
      anyone have track? I can’t find anything on google.
      Modules installed:
      MMM-MyCalendar
      MMM-Jeedom
      MMM-HOTWORD
      MMM-Globe
      MMM-AssistantMk2
      thank you
      • ChrisC Offline
        Chris
        Hello,
        You must install the MMM-Youtube module for this to work and add it to the config file in the MMM-AssistantMk2 module:
        recipes: [
               "MMM-with-Hotword.js", "with-MMM-Youtube.js"
        Regards,
        • L Offline
          ludacriss57
          thank you !
          it works.
          well I have a problem, how do we control it by voice?
          stop youtube it doesn’t work, it’s looking for an application that doesn’t exist.
          • ChrisC Offline
            Chris
            Hello,
            Consult the module wiki.
            In the prepared recipes tab, it says:
            with-MMM-Youtube.js
            Youtube links detector. If a link with youtube is detected, the video is displayed.
            Youtube playlist detector
            You can also use youtube keyword to force search
            Vocal Control to stop video (modify pattern in your prefered language)
            Mute volune on assistant query
            known bugs : on Fullscreen ui, video is stopped when assistant activate
            Regards,
            • L Offline
              ludacriss57
              I’m sorry but there I am lost.
              I am French, I put in:
              module: “MMM-YouTube”,
              hl: “fr”,
              but i still don’t know what to say to the wizard to stop reading.
              I also put in:
              module: “MMM-AssistantMk2”
              recipes: [“with-MMM-Hotword.js”, “with-MMM-Youtube.js”],
              am I good until then?
              ChrisC 2 Replies Last reply Reply Quote 0
              • L Offline
                ludacriss57
                Where can I find the command list for the FR language?
                • ChrisC Offline
                  Chris @ludacriss57
                  @ludacriss57 said in MMM-AssistantMk2:
                  hl: “fr”,
                  Hello,
                  Strangely, I did not need to put it in French for youtube to work.
                  To stop it, I just say SmartMirror.
                  I also try to say “stop the video” but it doesn’t work.
                  Maybe if Sean or Bugsounet goes through there, they can explain the procedure to us.
                  Yes, that’s what I put in my configuration and it works.
                  Regards
                  • L Offline
                    ludacriss57
                    In fact I feel like my problem is more complicated than that.
                    if I deactivate MMM-Hotword and put MMM-AssistantMk2 back in normal voice mode (without recipe), it is impossible to trigger the assistant with “ok google”.
                    as if he couldn’t hear me on MMM-AssistantMk2 but he heard me on MMM-HOTWORD.
                    and actually at the install I had errors when I configure the microphone.
                    but why does it work with hotword?
                    I can not place orders from youtube by hotword?
                    thank you
                    • L Offline
                      ludacriss57
                      here is my config file on the interesting part
                        module: "MMM-AssistantMk2",
                        position: "top_center",
                          ui: "Classic",
                          assistantConfig: {
                          latitude: *****,
                          longitude: *****,
                      responseConfig: {
                            useScreenOutput: true,
                            useAudioOutput: true,
                            useChime: true,
                            timer: 5000,
                            myMagicWord: false
                         micConfig: { // put there configuration generated by auto-installer
                           recorder: "arecord",
                           device: "plughw:1",
                      recipes: [ "with-MMM-Hotword.js", "with-MMM-Youtube.js", "Reboot-Restart-Shutdown.js" ],
                      profiles: {
                            "default": {
                              profileFile: "default.json",
                              lang: "fr-FR",
                      • L Offline
                        ludacriss57
                        module: "MMM-Hotword",
                        position: "bottom_left",
                          useDisplay: false,
                          chimeOnFinish: null,
                          recipes: ["with-AMk2v3-noisy_Jarvis.js"],
                          mic: {
                            recordProgram: "arecord",
                            device: "plughw:1",
                        • L Offline
                          ludacriss57
                            module: "MMM-YouTube",
                            position: "bottom_center",
                              verbose:true,
                              defaultQuality: "default",
                              disableCC: true,
                              showPlayingOnly: true,
                              defaultLoop: false,
                              defaultShuffle: false,
                              defaultAutoplay: true,
                              onStartPlay: null,
                              playerVars: {
                                controls: 0,
                                hl: "fr",
                                enablejsapi: 1,
                                showinfo: 0,
                                rel: 0,
                                cc_load_policy: 0,
                            meusprojetoskali @ludacriss57
                            @ludacriss57 I have the same problem, everything works fine, but does not respond to the STOP VIDEO, PAUSE VIDEO commands …
                            If you can solve it, please tell us what the solution was.
                            • L Offline
                              ludacriss57
                              did you happen triggered the google assistant without mmm-hotword?
                              does it respond to “ok google”?
                              I already have a problem there. it does not respond to the recipe of mmm-assisantmk2.
                              ChrisC 1 Reply Last reply Reply Quote 0
                              • ChrisC Offline
                                Chris @ludacriss57
                                @ludacriss57
                                Hello,
                                I don’t think MMM-AssistantMK2 can work without MMM-Hotword.
                                See my exchange with Sean on this subject.
                                Regards,
                                • ChrisC Offline
                                  Chris @ludacriss57
                                  Hello,
                                  Sean just gave the answer to your problem here,
                                  Regards,
                                  • L Offline
                                    ludacriss57
                                    Thank you for the link
