    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 163.5k Views 19 Watching
      sdetweil @richmp95
      @richmp95 you’d have to post in an issue in the module GitHub repo
      • V Offline
        Vizulize Module Developer @richmp95
        @richmp95 - last I checked, this still works. Why does it need ‘reviving’?
        If you would like to have extra features, I am open to suggestions and contributions.
        • L Offline
          Layton
          Is there anyway to remove the goal tracking widget underneath each resource?
          I have been trying to play around with removing it myself, but every time I touch something it breaks the whole module.
          Any ideas!?
          • V Offline
            Vizulize Module Developer @Layton
            @Layton
            I haven’t tried this and I haven’t looked at the code in a while, but I think you can just comment out this line to hide the progress bars:
            https://github.com/m-roberts/MMM-Fitbit2/blob/430d35056ceecfe612476a7d0307903b376ed6c0/MMM-Fitbit2.js#L242
            • L Offline
              Layton @Vizulize
              @Vizulize That worked! Thank you :)
                richmp95 @Vizulize
                @Vizulize i am still having issues with this module. all it says is loading. any help with this i would appreciate it
                • V Offline
                  @richmp95 I’m afraid I can’t do much to help without error logs.
                  • MeidlmarkusM Offline
                    Meidlmarkus
                    Hi, updated MM and now Google-Fit can no longer be installed, so I gave MMM-Fitbit2 a go.
                    Thanks @Vizulize for your work, I’d really like to get it running.
                    I have the same error that is reported in the github:
                    npm ERR! must provide string spec
                    To reproduce, just try to install it on an updated MM system.
                    It happens when calling ./init.sh as per your instructions on github
                    Have you/has anybody figured out a way to initialize the module?
                    Markus
                      sdetweil @Meidlmarkus
                      @Meidlmarkus said in MMM-Fitbit2:
                      MMM-Fitbit2
                      remove these lines from package.json
                            "Requires this version to work",
                            "https://github.com/SVendittelli/MMM-fitbit/issues/23#issuecomment-464319931"
                        Meidlmarkus
                        Thanks, Sam!
                        Had it googled in the meantime, had renamed the package-lock.json und run npm init
                        It braught no further error, I called auth.sh and that’s where I’m stuck now.
                        After entering the credentials, no browser dialog opens and I’m not quite sure where to search it.
                        Am logged in over ssh and in addition have a browser open to :8080
                        Neither on the mirror, nor on the pc, there is any dialog appearing.
                        I guess I’ll start from scratch, remove the module folder, clone new from git, and try your suggested method with the original package.json?
                        Thanks again
                        Markus
                          @Meidlmarkus yeh, can’t help on the auth part
                          MeidlmarkusM 1 Reply Last reply Reply Quote 0
                            Meidlmarkus @sdetweil
                            @sdetweil yeah, so I renamed MMM-Fitbit2, cloned fresh.
                            In the package.json there is no such a line that you mentioned (I guess @Vizulize must have fixed it already)
                            Did npm init, then ./init seemingly went through.
                            With ./auth.sh same thing as before - no dialog showing up.
                            I hope @Vizulize sees it and helps out :-)
                            Markus
                              @Meidlmarkus I just checked again
                              still has those lines
                              don’t see another author choice in google search
                                Meidlmarkus
                                Yes, right.
                                Must have looked into the package.json after doing the npm init - my bad. Did another git clone and it is as you said.
                                Meanwhile it turned out I had pip not installed. After installing pip and running ./init.sh again (after npm init) libraries were installed, and also auth.sh was able to start (only saw it when I called the python script directly rather than from auth.sh)
                                So auth.sh was now able to “Open a Web browser” (at least according to its logs), I just don’t see any dialog.
                                Anyway, will now try init with the modified package.json and see if it makes a difference - will report back.
                                Thanks so far
                                Markus
                                  Meidlmarkus
                                  So, quick update:
                                  I tried inist.sh with the modified package.json
                                  The result was just the same - I don’t see any input dialog open.
                                  I believe the module is installed properly and the dependencies are ok.
                                  Markus
                                  • V Offline
                                    Vizulize Module Developer @Meidlmarkus
                                    @Meidlmarkus It’s been a while since I worked on this. From memory, doing this over SSH has extra complexity (probably to do with the DISPLAY environment variable). Honestly, I’ve wanted to rework this to be headless for a while but haven’t had the capacity to do so.
                                    My advice would be to try and run it locally if possible.
                                    Also if anyone can verify that the modification to package.json is a fix, then I will merge this in: https://github.com/m-roberts/MMM-Fitbit2/pull/10/files
                                      Meidlmarkus
                                      @Vizulize thanks a lot!
                                      In the meantime I came a little further.
                                      So about the package.json: Yes, can confirm, @sdetweil 's solution works perfectly.
                                      I did go the other route: after the git clone, I did an npm init, this resolved the prob in the package.json and package-lock.json - this worked, too.
                                      My next problem was when calling the init.sh, I found out I had no pip installed, so the required libraries could not be installed.
                                      So I installed pip, then init.sh ran fine and installed what was required.
                                      I also came to the conclusion that the oauth authentification would probably work better locally rather than over ssh.
                                      So I ran auth.sh, was told that server was now listening on http://127.0.01/8888 - which was also what I entered when registering the app at fitbit. Looked good so far.
                                      No browser was opened though. So restarted MM with an invalid config.js, hooked up a keyboard/mouse on the mirror-raspberry locally and opened electron from a local terminal like so:
                                      /home/pi/MagicMirror/node_modules/electron/dist/electron http://localhost:8888
                                      That’s when the serverside reported
                                      127.0.0.1 - - [04/Dec/2023:20:19:56] "GET / HTTP/1.1" 404 2019 "" "Mozilla/5.0 (X11; Linux armv7l) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/116.0.5845.228 Electron/26.6.2 Safari/537.36"
                                      So, 404.
                                      On the electron window, this was shown:
                                      Traceback (most recent call last):
                                        File "C:\ProgramData\Anaconda3\lib\site-packages\cherrypy\_cpdispatch.py", line 54, in __call__
                                          return self.callable(*self.args, **self.kwargs)
                                      TypeError: index() missing 1 required positional argument: 'state'
                                      During handling of the above exception, another exception occurred:
                                        File "C:\ProgramData\Anaconda3\lib\site-packages\cherrypy\_cprequest.py", line 628, in respond
                                          self._do_respond(path_info)
                                        File "C:\ProgramData\Anaconda3\lib\site-packages\cherrypy\_cprequest.py", line 687, in _do_respond
                                          response.body = self.handler()
                                        File "C:\ProgramData\Anaconda3\lib\site-packages\cherrypy\lib\encoding.py", line 219, in __call__
                                          self.body = self.oldhandler(*args, **kwargs)
                                        File "C:\ProgramData\Anaconda3\lib\site-packages\cherrypy\_cpdispatch.py", line 60, in __call__
                                          raise sys.exc_info()[1]
                                        File "C:\ProgramData\Anaconda3\lib\site-packages\cherrypy\_cpdispatch.py", line 58, in __call__
                                          test_callable_spec(self.callable, self.args, self.kwargs)
                                        File "C:\ProgramData\Anaconda3\lib\site-packages\cherrypy\_cpdispatch.py", line 157, in test_callable_spec
                                          raise cherrypy.HTTPError(404, message=message)
                                      cherrypy._cperror.HTTPError: (404, 'Missing parameters: state')
                                      Pls note: this is not exactly my error, looks like this is coming from a windows machine:
                                      This came up as the first result when entering “missing parameters state” in the google search. But it is close enough to my error (just replace C:\ProgramData… with home/pi/.local/lib/python3.7… - I could not be bothered to type it all off of my mirror :-D )
                                      There was no solution given, though, so that is where I am stuck now…
                                      Thanks again for your help,
                                      Markus
                                        Meidlmarkus
                                        Plus: I learned that the callback page needs to be called exactly as specified, so I tried also with http://127.0.0.1:8888/
                                        with ending slash, without, even with https - all to no avail.
                                        Thanks again
                                        Markus
                                        • 5 / 5
