    I can't get mmm-screencast to work
    59 Posts 6 Posters 33.6k Views 6 Watching
    • JerryPJ Offline
      JerryP @jste84
      @jste84 Please use the code input</> button
      and copy past your code
      what I now see is u missing de cast name
      • JerryPJ Offline
        JerryP @jste84
        @jste84
        See her is my config
        		module: 'MMM-Screencast',
        		position: 'bottom_right',
        			position: 'center',
        			castName: 'Spiegeltje',
        			height: 300,
        			width: 500,
        • F Offline
          fribse @JerryP
          @JerryP
          Like this:
                position: 'bottom_right', // This position is for a hidden <div /> and no$
                  castName: 'Spejl',
                  position: 'bottomCenter',
                  height: 600,
                  width: 800,
          JerryPJ 2 Replies Last reply Reply Quote 0
          • JerryPJ Offline
            JerryP @fribse
            @fribse
            position: 'bottomCenter",
            This one is not in use.
            try this one
            position 'bottom_center'
            • JerryPJ Offline
              JerryP @fribse
              • F Offline
                fribse @JerryP
                @JerryP You’re right, ha ha, that’s been there for ages, it works, just places it in the middle of it all, but looks better at the bottom :-D
                JerryPJ 1 Reply Last reply Reply Quote 0
                • JerryPJ Offline
                  JerryP @fribse
                  @fribse So now whit the new line of code i’t a live.
                  Lets stream YouTube.
                  I use the module for the kids to see school movies. Home school. hahaha
                  • F Offline
                    fribse @JerryP
                    @JerryP I wasn’t the OP, I never had a problem I just commented on how to post the code :-)
                      jste84 @JerryP
                      @JerryP I’ve copied your config and still can’t find the device. When I try and cast YouTube. The only device that shows is my Nvidia shield 😓
                      • F Offline
                        fribse @jste84
                        @jste84 Are the pi on wifi or cable? It could be due to mDNS not propagating across wired/wireless.
                          jste84 @fribse
                          @fribse its wifi… Is there a way to check/fix this?
                          F JerryPJ 2 Replies Last reply Reply Quote 0
                          • F Offline
                            fribse @jste84
                            @jste84 As long as the devices are on the same, ie. both on cable, or both on wifi, then you should be good.
                            One thing I wonder though, the shield, is that on cable? It could be client isolation, if you have that activated on your wifi, then it won’t work.
                            • JerryPJ Offline
                              JerryP @jste84
                              @jste84
                              lets try to pull the module!!
                              Navigate to the modules directory via the follow command:
                              cd MagicMirror/modules/MMM-Screencast
                              git pull
                              npm install
                              F J 2 Replies Last reply Reply Quote 0
                              • F Offline
                                fribse @JerryP
                                @JerryP said in I can't get mmm-screencast to work:
                                nam install
                                Is that a new command? :-D
                                  sdetweil @fribse
                                  @fribse typo. npm
                                    jste84 @JerryP
                                    @JerryP ok so have done this. Git pull says up to date.
                                    Npm install - installs with 12 vulnerabilities…
                                    • JerryPJ Offline
                                      JerryP @jste84
                                      @jste84 OK.
                                      And now when you reboot the mirror.
                                      Are u using the same wifi network for our phone and mirror. to broadcast YouTube?? Frome your laptop it’s not working. “At my place only the phone and iPad can connect the module”
                                        jste84 @fribse
                                        @fribse Shield is WiFi too…
                                          jste84 @JerryP
                                          @JerryP same Wifi network for the mirror and shield.
                                          Reboot and when I open YouTube… Still no luck finding the mirror
                                          • JerryPJ Offline
                                            JerryP @jste84
                                            @jste84
                                            Can you try to put de Nvidia shield down. (unplug the power) and is I’t than possible tot see the screencast on the mirror (maybe reboot the mirror after you hef unplug the Nvidia shield)
                                            and kan you post one more time te config.
                                            • 2 / 3
