    I can't get mmm-screencast to work
    59 Posts 6 Posters 27.6k Views 6 Watching
      jste84 @JerryP
      @JerryP so tried unplugging the shield when I hit the cast button it says no devices found.
      module: 'MMM-Screencast',
      		position: 'bottom_right',
      			position: 'center',
      			castName: 'Mirror',
      			height: 300,
      			width: 500,
      S JerryPJ 2 Replies Last reply Reply Quote 0
        sdetweil @jste84
        @jste84 did u check to see if there are any errors, pm2 logs or dev window. sounds like the listen for incoming requests is not setup
        u will have to have adresss:“0.0.0.0”, and ipWhitelist:[]
        to allow machines (phone table laptop…) to connect to the mm server running the module
          jste84 @sdetweil
          @sdetweil how do I check for those?
          The address and ipWhitelist are both set this way.
          JerryPJ 1 Reply Last reply Reply Quote 0
          • JerryPJ Offline
            JerryP @jste84
            @jste84 so tried unplugging the shield when I hit the cast button it says no devices found.
            I’m thinking that you want something that’s not possible. Or I’m confused.
            The Shield is a different device. so unplug the power of it.
            Than take a phone whits is on the seem wifi network as the mirror
            Then use your phone en pick a movie on YouTube.com
            and hit the cast button.
            Your config looks oke.
            The pull is als don
            so I don’t know why it’s not working
            In the picture you can see my 2 mirrors.
            “Huiskamer”
            “Spiegeltje”
            • JerryPJ Offline
              JerryP @jste84
              @jste84
              var config = {
              	address: "0.0.0.0"
              	port: 8080,
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
              	useHttps: false,
              	httpsPrivateKey: "",
              	httpsCertificate: "",
              	language: "nl",
              	timeFormat: 24,
              	units: "metric",
              modules:
              This is my part of de var (ip handeling)
              S J 2 Replies Last reply Reply Quote 0
                sdetweil @JerryP
                @JerryP your whitelist says only apps inside mirror can connect
                use
                ipWhitelist:[],
                • JerryPJ Offline
                  JerryP @sdetweil
                  @sdetweil i removed the ip adres of the laptop an tv.
                  But for the mmm-screencast module is That no problem
                    sdetweil @JerryP
                    @JerryP why cant u start allowing everything, and tighten it up later.
                      jste84 @JerryP
                      @JerryP the only difference between your config and mine is ipWhitelist for me is [] and language is English.
                        jste84
                        I unplugged the shield as that is what you asked me to try.
                        I then used my phone to try and cast… But had no joy. It didn’t find any devices. I rebooted the mirror and it still didn’t find it
                        • 6
                        • 5 / 6
