    I can't get mmm-screencast to work
    59 Posts 6 Posters 33.6k Views 6 Watching
      jste84 @JerryP
      @JerryP so tried unplugging the shield when I hit the cast button it says no devices found.
      module: 'MMM-Screencast',
      		position: 'bottom_right',
      			position: 'center',
      			castName: 'Mirror',
      			height: 300,
      			width: 500,
      S JerryPJ 2 Replies Last reply Reply Quote 0
        sdetweil @jste84
        @jste84 did u check to see if there are any errors, pm2 logs or dev window. sounds like the listen for incoming requests is not setup
        u will have to have adresss:“0.0.0.0”, and ipWhitelist:[]
        to allow machines (phone table laptop…) to connect to the mm server running the module
          jste84 @sdetweil
          @sdetweil how do I check for those?
          The address and ipWhitelist are both set this way.
          JerryPJ 1 Reply Last reply Reply Quote 0
          • JerryPJ Offline
            JerryP @jste84
            @jste84 so tried unplugging the shield when I hit the cast button it says no devices found.
            I’m thinking that you want something that’s not possible. Or I’m confused.
            The Shield is a different device. so unplug the power of it.
            Than take a phone whits is on the seem wifi network as the mirror
            Then use your phone en pick a movie on YouTube.com
            and hit the cast button.
            Your config looks oke.
            The pull is als don
            so I don’t know why it’s not working
            In the picture you can see my 2 mirrors.
            “Huiskamer”
            “Spiegeltje”
            • JerryPJ Offline
              JerryP @jste84
              @jste84
              var config = {
              	address: "0.0.0.0"
              	port: 8080,
              	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],
              	useHttps: false,
              	httpsPrivateKey: "",
              	httpsCertificate: "",
              	language: "nl",
              	timeFormat: 24,
              	units: "metric",
              modules:
              This is my part of de var (ip handeling)
              S J 2 Replies Last reply Reply Quote 0
                sdetweil @JerryP
                @JerryP your whitelist says only apps inside mirror can connect
                use
                ipWhitelist:[],
                • JerryPJ Offline
                  JerryP @sdetweil
                  @sdetweil i removed the ip adres of the laptop an tv.
                  But for the mmm-screencast module is That no problem
                    sdetweil @JerryP
                    @JerryP why cant u start allowing everything, and tighten it up later.
                      jste84 @JerryP
                      @JerryP the only difference between your config and mine is ipWhitelist for me is [] and language is English.
                        jste84
                        I unplugged the shield as that is what you asked me to try.
                        I then used my phone to try and cast… But had no joy. It didn’t find any devices. I rebooted the mirror and it still didn’t find it
                          sdetweil @jste84
                          @jste84 can u remote-control into the mirror?
                          for debug, ive posted at least a couple hundred times,
                          open the developers window, ctrl-shift-i on mirror keyboard,
                          select the tab labeled console and scroll up
                          u can filter messages by module by putting part of the module name in the filter field
                          also look in thr console where u start mm. if using pm2 then
                          pm2 logs --lines=100
                            jste84 @sdetweil
                            @sdetweil sorry I’m not sure what I’m looking at.
                            I’m in the console tab… and getting lots of notifications…
                            Tried using filter to search for the things that you’ve mentioned but no results. I must be doing something wrong
                              sdetweil @jste84
                              @jste84 cast in filter field
                                sdetweil @jste84
                                @jste84 then look in the place where u start mm
                                npm start or.pm2 logs
                                  jste84 @sdetweil
                                  @sdetweil when I put those into filter nothing comes up?
                                    sdetweil @jste84
                                    @jste84 ok, then look in the startup logs,
                                    … do you know how any.of this works?
                                      jste84 @sdetweil
                                      @sdetweil nope I’m a newbie to this…😓
                                        jste84 @jste84
                                        Would really appreciate anyone who has the time to help me make this work
                                        • L Offline
                                          luizcarlosnery @jste84
                                          @jste84
                                          I think this module died, mine stopped and never came back …
                                          • 3 / 3
