    I can't get mmm-screencast to work
    59 Posts 6 Posters 34.7k Views 6 Watching
    • JerryPJ
      JerryP @jste84
      @jste84 so tried unplugging the shield when I hit the cast button it says no devices found.
      I’m thinking that you want something that’s not possible. Or I’m confused.
      The Shield is a different device. so unplug the power of it.
      Than take a phone whits is on the seem wifi network as the mirror
      Then use your phone en pick a movie on YouTube.com
      and hit the cast button.
      Your config looks oke.
      The pull is als don
      so I don’t know why it’s not working
      In the picture you can see my 2 mirrors.
      “Huiskamer”
      “Spiegeltje”
      • JerryPJ
        JerryP @jste84
        @jste84
        var config = {
        	address: "0.0.0.0"
        	port: 8080,
        	useHttps: false,
        	httpsPrivateKey: "",
        	httpsCertificate: "",
        	language: "nl",
        	timeFormat: 24,
        	units: "metric",
        modules:
        This is my part of de var (ip handeling)
        S J 2 Replies Last reply
          sdetweil @JerryP
          @JerryP your whitelist says only apps inside mirror can connect
          use
          ipWhitelist:[],
          JerryPJ 1 Reply Last reply
          • JerryPJ
            JerryP @sdetweil
            @sdetweil i removed the ip adres of the laptop an tv.
            But for the mmm-screencast module is That no problem
              sdetweil @JerryP
              @JerryP why cant u start allowing everything, and tighten it up later.
                jste84 @JerryP
                @JerryP the only difference between your config and mine is ipWhitelist for me is [] and language is English.
                  jste84
                  I unplugged the shield as that is what you asked me to try.
                  I then used my phone to try and cast… But had no joy. It didn’t find any devices. I rebooted the mirror and it still didn’t find it
                    sdetweil @jste84
                    @jste84 can u remote-control into the mirror?
                    for debug, ive posted at least a couple hundred times,
                    open the developers window, ctrl-shift-i on mirror keyboard,
                    select the tab labeled console and scroll up
                    u can filter messages by module by putting part of the module name in the filter field
                    also look in thr console where u start mm. if using pm2 then
                    pm2 logs --lines=100
                      jste84 @sdetweil
                      @sdetweil sorry I’m not sure what I’m looking at.
                      I’m in the console tab… and getting lots of notifications…
                      Tried using filter to search for the things that you’ve mentioned but no results. I must be doing something wrong
                      S 2 Replies Last reply
                        sdetweil @jste84
                        @jste84 cast in filter field
                          sdetweil @jste84
                          @jste84 then look in the place where u start mm
                          npm start or.pm2 logs
                            jste84 @sdetweil
                            @sdetweil when I put those into filter nothing comes up?
                              sdetweil @jste84
                              @jste84 ok, then look in the startup logs,
                              … do you know how any.of this works?
                                jste84 @sdetweil
                                @sdetweil nope I’m a newbie to this…😓
                                  jste84 @jste84
                                  Would really appreciate anyone who has the time to help me make this work
                                  L 1 Reply Last reply
                                  • L
                                    luizcarlosnery @jste84
                                    @jste84
                                    I think this module died, mine stopped and never came back …
                                    • 3 / 3
