    I can't get mmm-screencast to work
    59 Posts 6 Posters 33.4k Views 6 Watching
    • JerryPJ Offline
      JerryP @jste84
      @jste84
      var config = {
      	address: "0.0.0.0"
      	port: 8080,
      	useHttps: false,
      	httpsPrivateKey: "",
      	httpsCertificate: "",
      	language: "nl",
      	timeFormat: 24,
      	units: "metric",
      modules:
      This is my part of de var (ip handeling)
      S J 2 Replies Last reply Reply Quote 0
        sdetweil @JerryP
        @JerryP your whitelist says only apps inside mirror can connect
        use
        ipWhitelist:[],
        JerryPJ 1 Reply Last reply Reply Quote 0
        • JerryPJ Offline
          JerryP @sdetweil
          @sdetweil i removed the ip adres of the laptop an tv.
          But for the mmm-screencast module is That no problem
            sdetweil @JerryP
            @JerryP why cant u start allowing everything, and tighten it up later.
              jste84 @JerryP
              @JerryP the only difference between your config and mine is ipWhitelist for me is [] and language is English.
                jste84
                I unplugged the shield as that is what you asked me to try.
                I then used my phone to try and cast… But had no joy. It didn’t find any devices. I rebooted the mirror and it still didn’t find it
                  sdetweil @jste84
                  @jste84 can u remote-control into the mirror?
                  for debug, ive posted at least a couple hundred times,
                  open the developers window, ctrl-shift-i on mirror keyboard,
                  select the tab labeled console and scroll up
                  u can filter messages by module by putting part of the module name in the filter field
                  also look in thr console where u start mm. if using pm2 then
                  pm2 logs --lines=100
                    jste84 @sdetweil
                    @sdetweil sorry I’m not sure what I’m looking at.
                    I’m in the console tab… and getting lots of notifications…
                    Tried using filter to search for the things that you’ve mentioned but no results. I must be doing something wrong
                      sdetweil @jste84
                      @jste84 cast in filter field
                        sdetweil @jste84
                        @jste84 then look in the place where u start mm
                        npm start or.pm2 logs
                          jste84 @sdetweil
                          @sdetweil when I put those into filter nothing comes up?
                            sdetweil @jste84
                            @jste84 ok, then look in the startup logs,
                            … do you know how any.of this works?
                              jste84 @sdetweil
                              @sdetweil nope I’m a newbie to this…😓
                                jste84 @jste84
                                Would really appreciate anyone who has the time to help me make this work
                                • L Offline
                                  luizcarlosnery @jste84
                                  @jste84
                                  I think this module died, mine stopped and never came back …
                                  • 3 / 3
