    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    7" Touch Screen Display
    Custom CSS
    • T
      TigersFan last edited by
      Is there a way to automatically get the MagicMirror information to nicely fit a 7" touch screen display? It’s fine on a large monitor but we are making a magic mirror using the 7" touch screen. I have seen documentation mentioned a “zoom” configuration but it’s anywhere within the config file.
      I seen information about a custom.css file. Is there one out there for reference? How do you get the MagicMirror module to recognize and load the custom.css file?
      Any help would be appreciated!
        A Former User @TigersFan last edited by
        @TigersFan
        https://developer.mozilla.org/en-US/docs/Web/CSS/zoom
        • T
          TigersFan @Guest last edited by
          @Sean Thanks for the reference!
          Do you recommend adding it to the main.css file?
          Mykle1 1 Reply Last reply Reply Quote 0
          • Mykle1
            Mykle1 Project Sponsor Module Developer @TigersFan last edited by
            @TigersFan said in 7" Touch Screen Display:
            It isn’t recommended that you modify the main.css file. Make your changes/modifications to your custom.css file. 🙂
            • T
              TigersFan @Mykle1 last edited by
              @Mykle1
              That’s what I figured. 🙂
              I got the zoom to work in main config file. Any resources for changing the orientation of the screen from landscape to portrait?
              • Mykle1
                @TigersFan
                There is a topic here somewhere that does exactly that with css. Do a search of the forum and I’m sure you’ll find it. 🙂
                • BKeyport
                  BKeyport Module Developer last edited by
                  Personally, I just used my 7" display as a two module unit - clock and calendar. That’s it. Now, it’s the control panel for my 3D Printer.
