    Help with MMM-NOA
    2 Posts 2 Posters 376 Views 2 Watching
      Medicpg
      newbie here having trouble with my configuration. cant seem to get the NOA working…code is below. I removed api keys
      /* Magic Mirror Config Sample
      • By Michael Teeuw http://michaelteeuw.nl
      • MIT Licensed.
      • For more information how you can configurate this file
      • See https://github.com/MichMich/MagicMirror#configuration
      var config = {
      address: “localhost”, // Address to listen on, can be:
      // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
      // - “”, “0.0.0.0”, “::” to listen on any interface
      // Default, when address config is left out, is “localhost”
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
      // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
      language: "en",
      timeFormat: 12,
      units: "imperial",
      		     // false, default for all  NON-armv6l devices
      		module: "alert",
      	    module: 'MMM-NOAA3',
              position: 'top_left',
              provider: "must be in quotes", // From list above
         apiKey: "",        // From one of the providers listed above
         airKey: "",
         css: "NOAA4",                   // THIS MUST CONTAIN A CSS STYLE NAME
         userlat: "37.5485", //MUST HAVE BOTH
         userlon: "121.9886",  //MUST HAVE BOTH
      		module: "updatenotification",
      		position: "top_bar"
      		module: "clock",
      		position: "top_left"
      		header: "US Holidays",
      					symbol: "calendar-check",
      					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
      module: ‘MMM-BartTimes’,
      position: ‘lower_third’,
      station: ‘FRMT’,
      station: ‘24TH’,
      train_blacklist: [],
      key: ‘’,
      module: “currentweather”,
      position: “top_right”,
      locationID: “4920512”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      appid: “”
      module: “weatherforecast”,
      header: “Weather Forecast”,
      appid: “”
      module: “newsfeed”,
      position: “bottom_bar”,
      feeds: [
      title: “New York Times”,
      url: “http://feeds.feedburner.com/breitbart”,
      showSourceTitle: true,
      showPublishDate: true,
      broadcastNewsFeeds: true,
      broadcastNewsUpdates: true,
      if (typeof module !== “undefined”) {module.exports = config;}
        Mykle1 Project Sponsor Module Developer @Medicpg
        @Medicpg said in Help with MMM-NOA:
        provider: “must be in quotes”, // From list above
        You have no provider entered?
        Example: provider: "darksky",
