    Adding duplicate Modules
    5 Posts 3 Posters 1.9k Views 3 Watching
      shipoffools1
      Does anyone know how to add multiple iterations of the same module. E.g. if I wanted to show 3 city’s weather by using the same module 3 times with 3 different sets of data. Thank you!
        Mykle1 Project Sponsor Module Developer @shipoffools1
        @shipoffools1
        You could try this. It doesn’t always work.
        1. Copy and paste the intended module folder twice so that you now have 3. ( example module - weatherforecast.
        2. Rename one of the copied folders to weatherforecast2. Then open that folder.
        3. Rename the weatherforecast.css file to weatherforecast2.css. Open that file.
        4. Rename all instances of .weatherforecast to weatherforecst2. Save and close.
        5. Rename the weatherforecast.js file to weatherforecast2.js. Open that file.
        6. Edit the Module.register line to weatherforecast2. Inside the quotes only!
        7. Edit the getStyles: function() return line to read "weather-icons.css", "weatherforecast2.css". Inside the quotes only! Save and close.
        Follow the above instructions again with the third folder, renaming, AS ABOVE, to weatherforecast3.
        Then you need a config.js entry for each module, using the names of the original and the 2 renamed modules.
          sdetweil @Mykle1
          @Mykle1 one addition
          if the module you are duplicating is one of the default modules, (located in the modules/defaults/ folder)
          put the copy back into the modules folder…
          modules in the defaults folder get special treatment from a hard coded list
            Yo yo yo! Thanks for that speedy tidbit. (nearly 9 months)
            :laughing:
              sdetweil @Mykle1
              @Mykle1 u want speed or accuracy?! 😆
