    News feed doesn't change after changing the newsfeed.js
    3 Posts 2 Posters 990 Views 2 Watching
    • T Offline
      Timtendo12
      So i tried to change the newsfeed RSS feed with my local news RSS feed but it does not change it keeps getting the news from the NY Times news. My config:```
      Module.register(“newsfeed”,{
      // Default module config.
      defaults: {
      	feeds: [
      			title: "NOS Algemeen",
      			url: "http://feeds.nos.nl/nosnieuwsalgemeen",
      			encoding: "UTF-8" //ISO-8859-1
      	showSourceTitle: true,
      	showPublishDate: true,
      Therminal when starting up:```
      > magicmirror@2.10.1 start /home/pi/MagicMirror
      > ./run-start.sh
      [11:38:24.396] [LOG]    Starting MagicMirror: v2.10.1
      [11:38:24.428] [LOG]    Loading config ...
      [11:38:24.447] [LOG]    Loading module helpers ...
      [11:38:24.452] [LOG]    No helper found for module: alert.
      [11:38:24.670] [LOG]    Initializing new module helper ...
      [11:38:24.673] [LOG]    Module helper loaded: updatenotification
      [11:38:24.676] [LOG]    No helper found for module: clock.
      [11:38:26.515] [LOG]    Initializing new module helper ...
      [11:38:26.517] [LOG]    Module helper loaded: calendar
      [11:38:26.519] [LOG]    No helper found for module: compliments.
      [11:38:26.521] [LOG]    No helper found for module: currentweather.
      [11:38:26.523] [LOG]    No helper found for module: weatherforecast.
      [11:38:26.671] [LOG]    Initializing new module helper ...
      [11:38:26.675] [LOG]    Module helper loaded: newsfeed
      [11:38:26.678] [LOG]    All module helpers loaded.
      [11:38:26.684] [LOG]    Starting server on port 8080 ...
      [11:38:26.750] [LOG]    Server started ...
      [11:38:26.753] [LOG]    Connecting socket for: updatenotification
      [11:38:26.757] [LOG]    Connecting socket for: calendar
      [11:38:26.759] [LOG]    Starting node helper for: calendar
      [11:38:26.761] [LOG]    Connecting socket for: newsfeed
      [11:38:26.763] [LOG]    Starting module: newsfeed
      [11:38:26.765] [LOG]    Sockets connected & modules started ...
      [11:38:27.173] [LOG]    Launching application.
      [11:38:34.446] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
      [11:38:34.586] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      Im new to coding so i hope someone is able to help me and find the issue :)
      • T Offline
        Timtendo12 @Timtendo12
        @Timtendo12 I also tried it with the NYT Technologu Rss feed XML. But also does not change.
        Config:
        Module.register("newsfeed",{
        	defaults: {
        		feeds: [
        				title: "New York Times Technology",
        				url: "https://rss.nytimes.com/services/xml/rss/nyt/Technology.xml",
        And here is the terminal log:
        > ./run-start.sh
        [11:52:02.159] [LOG]    Starting MagicMirror: v2.10.1
        [11:52:02.190] [LOG]    Loading config ...
        [11:52:02.209] [LOG]    Loading module helpers ...
        [11:52:02.216] [LOG]    No helper found for module: alert.
        [11:52:02.379] [LOG]    Initializing new module helper ...
        [11:52:02.381] [LOG]    Module helper loaded: updatenotification
        [11:52:02.383] [LOG]    No helper found for module: clock.
        [11:52:03.944] [LOG]    Initializing new module helper ...
        [11:52:03.946] [LOG]    Module helper loaded: calendar
        [11:52:03.948] [LOG]    No helper found for module: compliments.
        [11:52:03.949] [LOG]    No helper found for module: currentweather.
        [11:52:03.951] [LOG]    No helper found for module: weatherforecast.
        [11:52:04.063] [LOG]    Initializing new module helper ...
        [11:52:04.065] [LOG]    Module helper loaded: newsfeed
        [11:52:04.066] [LOG]    All module helpers loaded.
        [11:52:04.069] [LOG]    Starting server on port 8080 ...
        [11:52:04.123] [LOG]    Server started ...
        [11:52:04.127] [LOG]    Connecting socket for: updatenotification
        [11:52:04.132] [LOG]    Connecting socket for: calendar
        [11:52:04.135] [LOG]    Starting node helper for: calendar
        [11:52:04.137] [LOG]    Connecting socket for: newsfeed
        [11:52:04.139] [LOG]    Starting module: newsfeed
        [11:52:04.141] [LOG]    Sockets connected & modules started ...
        [11:52:04.589] [LOG]    Launching application.
        [11:52:10.718] [LOG]    Create new calendar fetcher for url: http://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics - Interval: 300000
        [11:52:10.923] [LOG]    Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
        [11:53:11.945] [LOG]    Use existing news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml
          You have edited the wrong file, namely the newsfeed.js file. You should be editing the config.js file which resides is the MagicMirror/config folder. If so, you should revert all your changes to their original state and edit the config.js entry for the newsfeed module. It should look something like this. I tested your url for NOS Algemeen and it works fine with the module.
            module: "newsfeed",
            position: "bottom_bar",	// This can be any of the regions. Best results in center regions.
              feeds: [
                  title: "BBC",
                  url: "http://feeds.bbci.co.uk/news/video_and_audio/news_front_page/rss.xml?edition=uk",
          Screenshot
          <img src=https://www.dropbox.com/s/4umt2lz4m75eg6j/newsfeed.png?raw=1 />
