    [MMM-JaST] Just another Stock Ticker (new: version 2.x)
    166 Posts 37 Posters 237.6k Views 39 Watching
      requiemmg
      Just noticed that I get this message on MM startup. Everything is running, current update installed this morning.
      0|MagicMirror  | [26.01.2022 11:04.50.818] [ERROR]
      0|MagicMirror  | ERROR! Could not validate main module js file.
      0|MagicMirror  | [26.01.2022 11:04.50.839] [ERROR]
      0|MagicMirror  | ReferenceError: Log is not defined
      0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-Jast/MMM-Jast.js:14:4347)
      0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1116:14)
      0|MagicMirror  |     at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10)
      0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:988:32)
      0|MagicMirror  |     at Module._load (node:internal/modules/cjs/loader:829:12)
      0|MagicMirror  |     at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
      0|MagicMirror  |     at Module.require (node:internal/modules/cjs/loader:1012:19)
      0|MagicMirror  |     at require (node:internal/modules/cjs/helpers:94:18)
      0|MagicMirror  |     at Class.loadModuleDefaultConfig (/home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:313:30)
      0|MagicMirror  |     at /home/pi/MagicMirror/modules/MMM-Remote-Control/node_helper.js:267:26
      0|MagicMirror  | [2805:0126/110450.830713:ERROR:viz_main_impl.cc(161)] Exiting GPU process due to errors during initialization
      JalibuJ 1 Reply Last reply Reply Quote 0
      • JalibuJ Offline
        Jalibu Module Developer @requiemmg
        @requiemmg whats your MagicMirror version?
        • karsten13K Offline
          karsten13 @Jalibu
          @jalibu
          I have similar errors running MMM-RAIN-MAP, happens only when using electron (not in server only). Using current mm develop branch.
          • JalibuJ Offline
            Jalibu Module Developer @karsten13
            thx @karsten13, I’ll check that for both modules
            • JalibuJ Offline
              Hi @karsten13 @requiemmg,
              this is a MMM-Remote-Control Bug: https://github.com/Jopyth/MMM-Remote-Control/issues/267
                requiemmg @Jalibu
                Thanks for the update. So I just ignore it and wait for fix.
                  MMuser
                  Hi, i am struggling with your module. I am testing MM in VM on Ubuntu. It seems that module is running but i still see only Loading instead of content. I ve tried default config provided on Git and also some config from this feed with no succes.
                  • JalibuJ Offline
                    Jalibu Module Developer @MMuser
                    @mmuser did you install the dependencies using npm install?
                      MMuser
                      Hi, yes i installed everything and after few restarts it is finally working, you did indeed great job, thanks for this module.
                      Maybe one quick question, for horizontal scrolling, on the left side, scrolling is aligned with module above but on right side, scrolling starting on very right side ( don’t know how to insert screenshot to this forum). I tried to modify maxWidth -no result, as it is according to description related only to vertical style. Any possibility to correct this ?
                      • O Offline
                        Overbid4225
                        Was anyone able to make this work for Australia?
                        I have tried AS and ASX both dont work. Example BOQ.AS but works on Yahoo Finance
                        • JalibuJ Offline
                          Jalibu Module Developer @Overbid4225
                          @Overbid4225 please check your logs: API request for BOQ.AS failed: Quote not found for ticker symbol: BOQ.AS
                          This message does not come from the MMM-Jast module, but from the Yahoo Finance library. Apparently a required value is not available for this symbol.
                          Since MMM-Jast depends on the results of the Yahoo Finance Library, unfortunately I can’t help you here either.
                          • O Offline
                            Overbid4225 @Jalibu
                            @Jalibu I see, thanks for the reply. Strange on Yahoo’s part to resolve BOQ.AS on their website or any other asx for that matter but not allow on API. https://finance.yahoo.com/quote/BOQ.AX?p=BOQ.AX&.tsrc=fin-srch
                            • JalibuJ Offline
                              @Overbid4225 yap, that‘s strange. The Yahoo Finanance library is unofficial and does not use a public API. Instead it just parses the Yahoo Website ;-)
                                Dracarys @Jalibu
                                @Jalibu Hi, for me the module just stopped working since yesterday. It only says ‘loading’. Restartig the mirror doesnt Help. Before that it worked flawlessly for months. Is it Just me or does anyone else have this problem too?
                                • JalibuJ Offline
                                  Jalibu Module Developer @Dracarys
                                  @Dracarys It still works for me without any problems.
                                  Do you get any logs?
                                    Dracarys
                                    I will post it as soon as i have the time :)
                                    EDIT:
                                    [30.06.2022 01:07.44.449] [ERROR] There was an error requesting the API. Failed Yahoo Schema validation
                                    • JalibuJ Offline
                                      @Dracarys
                                      That’s strange. Can you sort out which symbol causes this error?
                                      If it makes you happy, right now it’s better to see an error message on the mirror than to be shown the current stock performance.
                                        Dracarys
                                        i just got rid of all smybols and used BMW.DE Its still the same unfortunately. I even updated on the last version of jast but that also didnt help.
                                        • JalibuJ Offline
                                          @Dracarys can you please create an issue on Github? https://github.com/jalibu/MMM-Jast/issues
                                            Dracarys @Jalibu
                                            @Jalibu Since my magicmirror is running since a few years without updates/upgrades i updated everything (Rpi, MagicMirror, Node, Jast etc…). Now the module works again :)
                                            MartinLoidoltM 2 Replies Last reply Reply Quote 0
                                            • D Dracarys referenced this topic on
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 6 / 9
