    Toothbrush integration
    34 Posts 5 Posters 32.5k Views 8 Watching
    • D
      dfuerst
      Now i made a reinstall.
      brushtimer.js works until i rebuild electron!!!
      but without rebuilding MM just shows the white screen error.
      after rebuilding i get this upon sudo node brushTimer.js:
      pi@raspberrypi:~/MagicMirror/modules/MMM-OralB $ sudo node brushTimer.js
      module.js:597
        return process.dlopen(module, path._makeLong(filename));
      Error: Module version mismatch. Expected 48, got 50.
          at Error (native)
          at Object.Module._extensions..node (module.js:597:18)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
          at Module.require (module.js:497:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/modules/MMM-OralB/node_modules/bluetooth-hci-socket/lib/native.js:3:15)
          at Module._compile (module.js:570:32)
          at Object.Module._extensions..js (module.js:579:10)
      so, after this rebuild i get the error of my previous post in MM
      SvenSommerS 1 Reply Last reply
      • SvenSommerS
        SvenSommer @dfuerst
        @dfuerst
        Module version mismatch-Error
        Just to summarize and for clarification:
        The Module version mismatch. Expected 48, got 50
        or
        NODE_MODULE_VERSION 50. This version of Node.js requires
        NODE_MODULE_VERSION 51. Please try re-compiling or re-installing
        is a known “bug”, which we were able to solve by the rebuilding of electron as you posted a few days ago.
        So if you want to use the module in MM you have to use this statement in the MMM-OralB-folder:
        sudo npm rebuild --runtime=electron --target=1.4.6 --disturl=https://atom.io/download/atom-shell --abi=50
        If you want to test brushtimer.js-script standalone in the console, you need to build the packeges in the MMM-OralB-folder with
        npm rebuild
        Behavior of brushTimer.js script
        So if I understood you correctly, you were able to start the timer, but it never stopped?
        For a better understanding I added some debug information in the brushtimer.js -script. Cut you please trigger an update by
        cd ~/MagicMirror/modules/MMM-OralB
        git pull
        and try the following scenarios and provide me with the console output text.
        1. Start the Brush; wait like 10 seconds and stop.
        2. Start and stop within 3 seconds.
        3. Start, wait like 10 seconds and stop. Start again within the next 10 seconds for like 5 seconds.
        4. Start, wait like 10 seconds and stop. Start again after 40 seconds and stop whenever you like.
        Behavior of the module within the MM-framework
        You wrote:
        “noble warning: unknown handle 64 disconnected!”
        “scanning was started. Everything is working fine.”
        this two message’s i get upon every activation, so the MM show always SEARCHING…"
        Actually this behavior is the intended action right now. As I wrote in this Bug Hunt Post I have problems in bringing noble alive within MM²-framework.
        Surprisingly you aren’t suffering from this error, so could you please tell me:
        • Which platform (Rasperry Pi 2/3, etc.),
        • Node - version: node --version
        • npm - version: npm --version
        • MagicMirror: cd ~/MagicMirror/ and DISPLAY=:0 npm start
        you are using?
        Looking for some building inspiration?
        Check out my large, thin and metal framed mirror on robstechlog.com.
        Modules released:
        MMM-GoogleAnalytics
        MMM-GrafanaChart
        MMM-GrafanaGauges
        • D
          dfuerst
          of course, i used the electron downgrade. obviously i didn’t know that i have to enter " npm rebuild" to test the .js, sorry for that.
          you understood me correct. the timer never stopped, i will check that again after git pull
          as i 'm abroad till monday i will provide this infos to you on monday.
          you wrote the error is the xpected behaviour? as i mentioned MM showed just SEARCHING…
          many thanks for your effort
          • SvenSommerS
            SvenSommer
            For the Bug Hunt Post I reduced the code of the MM-scripts to a absolute minmum.
            That’s the reason the module is always showing ‘SEARCHING…’ right now.
            If the scripts would work as exspected the console output would show scanning was started. Everything is working fine. all the time the MM² is started.
            Thats all I’m hoping to see right now.
            Modules released:
            MMM-GoogleAnalytics
            MMM-GrafanaChart
            MMM-GrafanaGauges
            • D
              dfuerst
              ok. i understand. full reply on monday
              • D
                dfuerst
                RPi3
                NODE : v6.9.2
                NPM: 3.10.9
                MagicMirror@2.0.0
                • D
                  dfuerst
                  scenario 1:
                  scanning started…
                  Toothbrush connection ALIVE atMon Jan 30 2017 17:12:15 GMT+0100 (CET)
                  Toothbrush is running
                  0:1
                  0:2
                  Toothbrush connection LOST at Mon Jan 30 2017 17:12:17 GMT+0100 (CET) was alive since Mon Jan 30 2017 17:12:15 GMT+0100 (CET)
                  two input in less than 3 sec! (2 sec) => ignoring input!
                  0:3
                  0:4
                  0:5
                  endless counting
                  scenario 2:
                  scanning started…
                  noble: unknown peripheral e0e5cffc4d8c connected!
                  noble: unknown peripheral e0e5cffc4d8c disconnected!
                  Toothbrush connection ALIVE atMon Jan 30 2017 17:14:25 GMT+0100 (CET)
                  0:1
                  0:2
                  Toothbrush connection LOST at Mon Jan 30 2017 17:14:28 GMT+0100 (CET) was alive since Mon Jan 30 2017 17:14:25 GMT+0100 (CET)
                  0:3
                  0:4
                  0:5
                  0:6
                  endless counting
                  scenario 3:
                  same result as in scenario1
                  scenario 4:
                  Reply Quote 1
                  • D
                    dfuerst
                    This post is deleted!
                    • D
                      dfuerst
                      in MM:
                      , in MagicMirror
                      • SvenSommerS
                        SvenSommer @dfuerst
                        @dfuerst
                        According to results of the tested scenarios your brush has a different behavior than mine.
                        I was expecting a reconnect when you power off your brush.
                        This is very bad.
                        Maybe we can find another person to test the characteristics of this behavior?
                        @Shifty or @onetwankyfive: Are you able to give the testscript a run with the postet scenarios to help us out here?
                        With th help of @aschulz90 I finally solved to run noble within the MM²-framework. See here for details.
                        I noticed the noble warning: unknown handle 64 disconnected!- warning. It’s nothing that should bother.
                        Modules released:
                        MMM-GoogleAnalytics
                        MMM-GrafanaChart
                        MMM-GrafanaGauges
                        O D 2 Replies Last reply
                        • O
                          onetwankyfive @SvenSommer
                          @SvenSommer I have a brush that is compatible and can help… are the instructions posted 5 days ago the correct ones? I can give it a whirl tonight / tomorrow morning if they are.
                          • D
                            dfuerst @SvenSommer
                            @SvenSommer
                            Ok, as proven during the scenarios:
                            my brush does a connect followed by another reconnect after 3sec, which happens without user interaction.
                            so i land again at ‘hcitool con’, can your script be modified easiely to operate as intended at the very beginning (scanning for BLE brush macaddrr. every few seconds and stopping upon not finding it anymore, vanishing+resetting after a defined time period) of this topic?
                            btw i use the:
                            Oral-B Pro 6500 Smart Series Electric Toothbrush with Bluetooth Technology Powered by Braun
                            @onetwankyfive
                            i appreciate your help testing the script, please provide us with the model no/type of your brush
                            • SvenSommerS
                              SvenSommer
                              @onetwankyfive
                              Thanks four your help! Yes, please follow these instructions of the eight steps to get the testscript running.
                              For clarification, please provide us with the output from the four scenarios:
                              And as @dfuerst mentioned the model seems to differ in their behavior. I’m using a a Braun Oral-B PRO 6000. Do you know yours?
                              @dfuerst
                              I don’t get your point in using hcitool.
                              Do you get a reconnect after you have stopped your brush with hcitool?
                              Or is your brush connected via hcitool as long as it’s running?
                              To answer your question: If you want to use hcitool, its easier to adapt to MMM-Networkscanner by @ianperrin like you did in your first attempt.
                              But as I already mentioned, I’m sure this is even more unreliable and unaccurate.
                              But if you wanna try, I’m willing to help you.
                              Modules released:
                              MMM-GoogleAnalytics
                              MMM-GrafanaChart
                              MMM-GrafanaGauges
                              • SvenSommerS
                                SvenSommer
                                @onetwankyfive, @dfuerst
                                As this is not an request topic any more I made a new one in the developer section. You can find it here.
                                Feel free to move over, if you want to assist the development of the module I’m creating right now.
                                Modules released:
                                MMM-GoogleAnalytics
                                MMM-GrafanaChart
                                MMM-GrafanaGauges
