weather forecast and current weather modules
@popeye2002 said in weather forecast and current weather modules:
it just showed up… like magic.
Are you saying it’s working now? I just copied your entry, put in my api key, and both fired right up for me
sadly no, only the forecast works, not the current weather :( that’s why jumped in this thread because it should work but the current weather does not so there may be a problem elsewhere. That’s where i don’t know where to begin to troubleshoot since it’s a brand new install.
BTW, I ran your current weather code for NY and that did not work either -
wow… RESOLVED… smart me somewhere along the way I entered my location into the currentweather.js file… that was a mistake I made and I shall remember!! @Mykle1 Thank you for your patients and I give to you something to smile and laugh about… betting you may have touched something you shouldn’t have as well… but that was a tough lesson!
Perfect! Learning is the reason I am here, too. Enjoy yourself
@Mykle1 hi how to get appid for current weather module
@ramanasha said in weather forecast and current weather modules:
From the readme:
‘API key, which can be obtained by creating an OpenWeatherMap account.’
This post is deleted! -
@hango DO NOT EDIT the module files…
edit the config.js and put setting in the module config block
{ module: ???? , position: ..... , config: { xyz: iiiii, < ---- stuff goes here } }
the value in the config will replace the ones in the code
you NEVER have to edit the actual module source code
@hango in your post of 'config, you put it in the global section,
not in the little config:{} section related to each module
this is why u are having trouble…
