    weather forecast and current weather modules
    Scheduled Pinned Locked Moved Unsolved General Discussion
    22 Posts 8 Posters 9.8k Views 7 Watching
    • L Offline
      lpassamonte
      hello, I have been working on my mirror for a while now but I just got home from college so I have been able to finally finish it. when I start up the mirror the only thing that does not come up are both the default weather modules. I updated the location, app ID, and location ID, even watched YouTube videos but everything I’ve done there is still no display of it. if someone could please help that would be great, thank you :)
      -Lexi
      J Mykle1M 2 Replies Last reply Reply Quote 0
        JohnBachini @lpassamonte
        @lpassamonte
        You need to post your config, so people can see it.
          Mykle1 Project Sponsor Module Developer @lpassamonte
          @lpassamonte said in weather forecast and current weather modules:
          If you used the example config entries (which you should) you’ll find an api key already in place. This number will NOT work. You need to go sign up for a free key at OpenWeather. Also, you don’t NEED a locationID for the modules to work but you do need a location
          Here is an example working bare minimum config entry for both
                  module: "weatherforecast",
                    locationID: "",
                    appid: "YOUR API KEY GOES HERE" //openweathermap.org API key.
              		module: "currentweather",
              			locationID: "",
          popeye2002P R 2 Replies Last reply Reply Quote 0
          • popeye2002P Offline
            popeye2002 @Mykle1
            @Mykle1
            I believe that there may be a new issue. I’ve spent the last few days with the same problem. Current weather does not show but forcast does… I’m also very new… just started MM2 this weekend from knowing nothing to knowing very little … anyway from the very first try the forcast was working but not the current weather.
            		//disabled: true,
            			locationID: "5810490", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            			appid: "getyourownapikey"
            	{	//disabled: true,
            		header: "5-Day Weather Forecast",
            			appid: "getyourownapikey",
            			colored:'true',
            			roundTemp:'true',
            			maxNumberOfDays:'14',
            			initialLoadDelay: '1000',
            			iconTable: {
            				    '01d': 'wi-day-sunny',
            				    '02d': 'wi-day-cloudy',
            				    '03d': 'wi-cloudy',
            				    '04d': 'wi-cloudy-windy',
            				    '09d': 'wi-showers',
            				    '10d': 'wi-rain',
            				    '11d': 'wi-thunderstorm',
            				    '13d': 'wi-snow',
            				    '50d': 'wi-fog',
            				    '01n': 'wi-night-clear',
            				    '02n': 'wi-night-cloudy',
            				    '03n': 'wi-night-cloudy',
            				    '04n': 'wi-night-cloudy',
            				    '09n': 'wi-night-showers',
            				    '10n': 'wi-night-rain',
            				    '11n': 'wi-night-thunderstorm',
            				    '13n': 'wi-night-snow',
            				    '50n': 'wi-night-alt-cloudy-windy'
            I am using Geany for an editor on my RPI4 … it just showed up… like magic.
            thanks for any help you may have
              Mykle1 Project Sponsor Module Developer @popeye2002
              @popeye2002 said in weather forecast and current weather modules:
              Are you saying it’s working now? I just copied your entry, put in my api key, and both fired right up for me
                popeye2002
                sadly no, only the forecast works, not the current weather :( that’s why jumped in this thread because it should work but the current weather does not so there may be a problem elsewhere. That’s where i don’t know where to begin to troubleshoot since it’s a brand new install.
                BTW, I ran your current weather code for NY and that did not work either
                  popeye2002
                  wow… RESOLVED… smart me somewhere along the way I entered my location into the currentweather.js file… that was a mistake I made and I shall remember!! @Mykle1 Thank you for your patients and I give to you something to smile and laugh about… betting you may have touched something you shouldn’t have as well… but that was a tough lesson!
                  Mykle1M ? 2 Replies Last reply Reply Quote 1
                    @popeye2002
                    Perfect! Learning is the reason I am here, too. Enjoy yourself
                      ramanasha @Mykle1
                      @Mykle1 hi how to get appid for current weather module
                        Mykle1 Project Sponsor Module Developer @ramanasha
                        @ramanasha said in weather forecast and current weather modules:
                        From the readme:
                        ‘API key, which can be obtained by creating an OpenWeatherMap account.’
