    read csv-data and put it in an array
    313 Posts 3 Posters 535.7k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      hello,
      i want to read a csv-file and put it in an array. should be like this:
      [line 1, line2, line3, …]
      i don’t know how to handle it. who can help me, please.
      Many thanks in advance
        sdetweil @Perlchamp
        @Perlchamp there are a bunch of libraries for csv to ???
        google is your friend
        https://www.npmjs.com/package/convert-csv-to-array
        if u convert it to json, its a lot easier to work with in code
        I use https://www.npmjs.com/package/csvtojson
          Perlchamp
          @sdtweil:
          thanks a lot. I will take a look at it.
          so long
            Perlchamp
            to include in my modul i have to do the following ?
            1. go in my module-folder
            2. npm i --save csvtojson
            than i have to include in my module.js:
            // required scripts
            getScripts: function() {
            return [“moment.js”, “csvtojson.js”];
            is this right?
            if so, how to use it in my script ?
            many thanks in advance.
            stay healthy !
              sdetweil @Perlchamp
              @Perlchamp you have to use the node_helper.js … the module.js file runs in the browser and doesn’t have access to local files
              var xxx= require(‘’)…
              then module has to send request to node_helper and node_helper has to send results back
              see my MyCovid19 module
              https://github.com/sdetweil/MyCovid19
                Perlchamp
                hello sam,
                i’m a noob. sorry for that. i will have a look to your module.
                this all is new for me. it will take some time …
                if you would help me, that would be great. but first i have to read some things …
                so long
                  sdetweil @Perlchamp
                  @Perlchamp my sample module might be helpful too…
                  https://github.com/sdetweil/SampleModule
                  implements what is in the developing module documentation
                  https://docs.magicmirror.builders/development/introduction.html
                    Perlchamp
                    hello sam,
                    thanks a lot. i will have a look on it, too. sure, i will learn a lot.
                    so long
                      Perlchamp
                      covid chart do not load :-(
                        sdetweil @Perlchamp
                        @Perlchamp show me the config for the module?
                          Perlchamp
                          in config.js i didn’t use the config section. i thought the defaults should be enough. ok, i will put the config section into the config.js. just a moment, please …
                            sdetweil @Perlchamp
                            @Perlchamp no… I don’t pick any countries or states, or describe how big the charts should be…
                            try this
                            			module:"MyCovid19",
                            			disabled:false,
                            			position:"top_left",
                            			classes: 'sam',
                            			config:{
                            				countries:["Italy","USA","China","Spain", "France",'Sweden'],
                            				// line colors can be any definition of color either a name ,or a hex string
                            				// one per country above, used in order,
                            				line_colors:['red','white','green','yellow','#34ebde','#34eb00'],
                            				chart_type:"cumulative_deaths",  // or "cumulative deaths"
                            				chart_title:"cumulative deaths by country", // however u want to label
                            				// the vertical steps on the chart.. how tall u want it to be and how mant increments
                            				ranges:{min:0,max:30000,stepSize:5000},
                            				// size of the chart in pixels
                            			    width: 400,
                            			    height: 400,
                            			    // only used if we need to debug something
                            			    debug:false,
                            			    startDate:'02/01/2020',
                            			    //backgroundColor: 'white',
                              Perlchamp
                              still loading …
                              			module: "MyCovid19",
                              			config:{
                              				countries: "Italy",
                              			    //countries:["Italy","USA","China","Spain","France"],
                                              //OR
                              			    //states:['New York','Illinois','Texas'],
                              			    // one of countries or states MUST be specified
                              			    //line_colors:['red','white','green','yellow','blue'],
                              			    line_colors: "white",
                              			    chart_type:"cumulative_cases",  // or "cumulative deaths"
                              			    chart_title:"Cumulative Cases", // however u want to label
                              			    ranges:{min:0,max:8000,stepSize:10000},
                              		        width: 400,
                              		        height: 500,
                              		        debug:false,
                              		        startDate: "02/01/2020"
                                sdetweil @Perlchamp
                                @Perlchamp said in read csv-data and put it in an array:
                                  		countries: "Italy",
                                must be an array countries : [ ‘Italy’ ] ,
                                  Perlchamp
                                  to include csvtojson i have to do the following ?
                                  getScripts: function () {
                                  		    return ["moment.js", "modules/" + this.name + "/node_modules/csvtojson/bin/csvtojson.js"];
                                  is that right ?
                                  covid do not run … black screen, no loading message …
                                    sdetweil @Perlchamp
                                    @Perlchamp no… see the node_helper.js
                                    you cannot use the csvtojson in the modulename.js
                                      sdetweil @Perlchamp
                                      @Perlchamp did u use my config info above? just to make it work
                                        Perlchamp
                                        yes.
                                        [“Italy”],
                                        which one? in your corona ?
                                          sdetweil @Perlchamp
                                          @Perlchamp i provided a complete working sample for my module above… copy/paste it into your config.js
                                            Perlchamp
                                            i did copy it, but doesn’t work yet. have i look on your code. is there a comma after the date. i think this shouldn’t be there. i deleted it, but still does not work => black screen
                                            • 15
                                            • 16
                                            • 1 / 16
