    read csv-data and put it in an array
    313 Posts 3 Posters 540.0k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp ok, this was just to give you ideas on how to access the data… in a useful way
      • PerlchampP Offline
        Perlchamp
        … and I’m very grateful to you for that. I learn from your messages every time. I think it’s great that there are people like you. that also costs time (apart from health, the most important thing in life). Thanks again for that!
          Perlchamp
          hi sam,
          i have a major problem, that i don’t understand. this is my code in node_helper.js:
          var NodeHelper = require("node_helper");
          var moment = require("moment");
          // add require of other javascripot components here
          // var xxx = require('yyy'); here
          const csv = require("csvtojson");
          var birthdaysArray = [];
          	init(){
          		console.log("init module helper perlchamp");
          	start() {
          		console.log("Starting module helper: " + this.name);
          		//	console.log("Pfad zur csv-Datei: " + this.path + "/data/birthdays.csv");
          		const csvFilePath = this.path + '/data/birthdays.csv';
          		csv()
          		.fromFile(csvFilePath)
          		.then((jsonObj)=>{
          			birthdaysArray = JSON.stringify(jsonObj);
          			console.log("birthdaysArray: " + birthdaysArray);
          			var today_day_month = moment().format("DD.MM");
          			var today_month = moment().format("MM");
          		console.log("birthdaysArray #2: " + birthdaysArray);
          		// moment.js
          		moment.locale(config.language);  // set locale
          		console.log("aktuelle Zeit: " + moment().format('Do MMMM YYYY, hh:mm:ss'));
          		console.log("aktueller Monat(Zahl): " + moment().format('MM'));
          		console.log("aktueller Monat(Text): " + moment().format('MMM'));
          		console.log("aktueller Tag(Zahl mit führender Null): " + moment().format('DD'));
          		console.log("aktueller Tag(Text): " + moment().format('dddd'));
          		console.log("aktueller Tag(Abkürzung): " + moment().format('dd'));
          		console.log("aktuelles Jahr(Zahl): " + moment().format('YYYY'));
          	stop(){
          		console.log("Stopping module helper: " + this.name);
          	// handle messages from our module// each notification indicates a different messages
          	// payload is a data structure that is different per message.. up to you to design this
          	socketNotificationReceived(notification, payload) {
          		//	console.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
          		console.log(this.name + " received a socket notification: " + birthdays);
          		// if config message from module
          		if (notification === "CONFIG") {
          			// save payload config info
          			this.config=payload
          			// wait 15 seconds, send a message back to module
          			setTimeout(()=> { this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000)
          		else if(notification === "????2") {
          why returns
          nothing.
          many thanks in advance
            Perlchamp
            should be
            console.log(this.name + " received a socket notification: " + birthdaysArray);
            of course. couldn’t edit it, because of spam-message from board …
              sdetweil @Perlchamp
              @Perlchamp said in read csv-data and put it in an array:
              > 		csv()
              > 		.then((jsonObj)=>{
              welcome to programming with a asyncronous libraries
              csv().fromFile(csvFilePath) starts a ‘long’ operation,
              going out to disk, reading in the data, and converting it to json from spreadsheet… (long is milliseconds)
              the processor should not wait, so it does not, and the next instruction AFTER the start of the fromFile()
              is console.log("birthdaysArray #2: " + birthdaysArray);
              	// moment.js
              and the start function runs out of things to do and returns back to MM…
              sometime later , the fromFile() will complete, and call the .then() routine with the data
              (jsonObj)=>{
              so, if you need to wait for the data(to prints is content) , then the operations would be inside the .then() handler.
                Perlchamp
                ok, thanks. to move the code is not heavy ;-) … i’ve found a snippte to sort my birthdaysArray, but that doesn’t match :
                		csv()
                		.then((jsonObj)=>{
                		var result = Object.entries(birthdaysArray.reduce((a, {birth, name}) => {
                			const day = +birth.split('.')[0];
                			a[day] = [...(a[day] || []), name];
                			return a
                		}, {})).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day)
                		console.log("sorted birthdays : " + result);
                now i’m looking for another one. is the birthdaysArray a json-Array or a javascript-array or … someone told me, it’s an object-Array and that this has nothing to do witch json … but: csvtojson, so …
                  Perlchamp
                  so i’m bloody happy :
                  	init(){
                  	start() {
                  		console.log("Pfad zur csv-Datei: ", this.path + "/data/birthdays.csv");
                  		csv()
                  		.then((jsonObj)=>{
                  			console.log("birthdaysArray: ", birthdaysArray);
                  		var result = Object.entries(jsonObj.reduce((a, {birth, name}) => {
                  			return a
                  		console.log("sorted birthdays : ", result);
                  	stop(){
                  			this.config=payload
                  so now I just have to manage to filter out the people from the complete csv-file who have their birthday in the current month …
                    Perlchamp
                    if i run :
                    		for(var birthday of birthdaysArray) {
                    			if(birthday.birth.startsWith(today_day_month)) {
                    				// this birthday is for today
                    				console.log(" birthday on "+ today_day_month+" is for "+birthday.name);
                    than i get the following error-messages:
                     Unhandled rejection TypeError: Cannot read property 'startsWith' of undefined
                        at /home/dirk/MagicMirror/modules/perlchamp/node_helper.js:33:22
                        at Object.onfulfilled (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:112:33)
                        at Result.endProcess (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Result.js:83:50)
                        at Converter.processEnd (/home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:179:21)
                        at /home/dirk/MagicMirror/node_modules/csvtojson/v2/Converter.js:172:19
                        at tryCatcher (/home/dirk/MagicMirror/node_modules/bluebird/js/release/util.js:16:23)
                        at Promise._settlePromiseFromHandler (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:547:31)
                        at Promise._settlePromise (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:604:18)
                        at Promise._settlePromise0 (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:649:10)
                        at Promise._settlePromises (/home/dirk/MagicMirror/node_modules/bluebird/js/release/promise.js:729:18)
                        at _drainQueueStep (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:93:12)
                        at _drainQueue (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:86:9)
                        at Async._drainQueues (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:102:5)
                        at Immediate.Async.drainQueues [as _onImmediate] (/home/dirk/MagicMirror/node_modules/bluebird/js/release/async.js:15:14)
                        at processImmediate (internal/timers.js:439:21)
                    I was probably happy too early ;-( … shit happens.
                      sdetweil @Perlchamp
                      @Perlchamp you converted the array to text format, so now its just one big string…
                      to print it out do this
                                              birthdaysArray = jsonObj;
                      			console.log("birthdaysArray: "+JSON.stringify(jsonObj););
                      why do you need to sort them?
                      as you go thru you can just not save the ones not for today, plus/minus some lookahead
                      once you get to the today list you can sort the names if you need to.
                        sdetweil @Perlchamp
                        json is a TEXT structure…
                        but it just so happens that javascript represents objects the same way… so the JSON library provides utilities to convert in both directions.
                        json text to object JSON.parse(text)
                        object to json text JSON.stringify(object)
                        text is text and has no meaning (its called opaque because u cannot tell what it is)
                        no reason to split the birthdate, as u won’t do anything with the individual parts
                        don’t do work if u don’t need the results
                        you do NOT Need to do this data reformatting IN the node helper… you can do it all in the modulename.js file, which would let you use the code debugger in the dev console.
                        in the .then of the node_helper csvtojson, just send the data to the module
                        self.sendsocketNotification(“have data”, jsonObj)
                        and the helper is done
                        on the modulename.js side
                        socketNotificationReceived(notification, payload){
                        if(notification =='have data'){
                        var now = moment()
                        var active_birthdays={}
                        for( var birthday of payload) {
                        // get 1st 5 chars of birthdate, thru month
                        // we will use this as the key in the hash
                        var birth_date=birthday.birth.subString(0,4)
                        // get the birthday as a moment in this year, for comparing
                        var birth_date_moment = moment(birth_date+now.getYear(),"DD.MMYYYY")
                        // u can add days to a moment object and then compare if the birthdate is before that date (and after now)
                        // so within the next xx days
                          // if the date is the same or later, don't use time of day
                           if(birth_date.startOf('day').isSame(now.startOf('day')){
                               // birthday is in this month
                              // check the hash if we've seen anything for today yet
                              // if we haven't see this date yet
                              if(active_birthdays[birth_date] == undefined){
                                   //  create the holder for its info (array of names) in the hash
                                   active_birthdays[birth_date]=[]
                              // save the persons name on the list
                              active_birthdays[birth_date].push(birthday.name)
                             // tell MM to call and get our content
                             self. updateDom()
                        at the end, you will have just birthdays in this month and for people with the same day
                        a list of people on that day
                        in the hash reader (getDom(), Object.keys(active_birthdays) will get you back an array of the
                        DD.MM strings that are present
                        but you can probably do without that… u know what today is, so if there is an object with todays DD.MM
                        then u have the list of people for today
                        if u want to allow (in the next 5 days,matching what the node_helper did), using moment, u can add a day, extract the DD.MM, check the hash,
                        repeat 4 more times
                          Perlchamp
                          ok, thank you sam.
                          Now I have to process the whole thing first, otherwise my head will burst ;-) …
                            Perlchamp
                            this is the actual node_helper.js:
                            	init(){
                            	start() {
                            		//console.log("Pfad zur csv-Datei: ", this.path + "/data/birthdays.csv");
                            		// convert the csv-file into a JSON-String
                            		csv()
                            		.then((jsonObj)=>{
                            			// for debugging only
                            			//console.log("birthdaysArray: ", birthdaysArray);
                            			// send data to [modulname].js
                            			self.sendsocketNotification("have data", birthdaysArray)
                            			// loop thru the array of birthday_info from file (jsonObj),
                            			// one 'row' per birthday
                            	stop(){
                            			this.config=payload
                            i got an error-message :
                            [2020-05-01 23:21:12.072] [WARN]   Unhandled rejection ReferenceError: self is not defined
                                at /home/dirk/MagicMirror/modules/perlchamp/node_helper.js:34:4
                            i think this could be the problem:
                            i tried “this.” and without “self.” and “this.” but nothing changed. now i’m searching in the web, maybe i will found some answers ;-)
                              Perlchamp
                              i have found a typing error. Socket instead socket. if i than change self. to this. no errror messages will displayed. but still black screen.
                              maybe i did not understand how to handle the getDom-section … i will still try …
                              but:
                              i see no notification in the terminal. ‘have data’ should actually appear there, shouldn’t it ?
                                sdetweil @Perlchamp
                                @Perlchamp
                                do this, you need self
                                start() {
                                		var self = this
                                the use self
                                                self.sendsocketNotification("have data", jsonObj)
                                u need to send the obj, not the string
                                as for black screen , that means the modulename side died…
                                f12 on the keyboard or ctrl-shift-i, select the console tab, and look for red text … usually a syntax error…
                                  @Perlchamp
                                  no, the message is sent to the modulename.js side of your module…
                                  using my sample code , right here
                                          // messages received from from your node helper (NOT other modules or the system)
                                  	// payload is a notification dependent data structure, up to you to design between module and node_helper
                                    the two parts look like this
                                    |                                  browser  side                                                 |
                                    |                                       modulename.js (SampleModule.js)                          |
                                    |     receive (socketNotificationReceived)                send ( sendSocketNotification)         |
                                                        |                                                     V
                                    |      send ( sendSocketNotification)                   receive (socketNotificationReceived)     |
                                    |                                       node_helper.js                                           |
                                    |                                  server side                                                   |
                                      Perlchamp
                                      yes, i understood. here’s my perlchamp.js (only socketNitificationReceived)
                                      		Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                                      		if(notification === "message_from_helper"){
                                      			this.config.message = payload;
                                      			// tell mirror runtime that our data has changed,
                                      			// we will be called back at GetDom() to provide the updated content
                                      			this.updateDom(1000)
                                      		if(notification === "have data"){
                                      			var now = moment()
                                      				var birth_date = birthday.birth.subString(0,4)
                                      				Log.log("Tag.Monat :", birth_date)
                                      				var birth_date_moment = moment(birth_date + now.getYear(),"DD.MMYYYY")
                                      				//     if the birthdate is before that date (and after now)
                                      						//		names) in the hash
                                      						active_birthdays[birth_date] = []
                                      			self.updateDom();
                                        sdetweil @Perlchamp
                                        @Perlchamp very good… now, I didn’t test the code I wrote, so there are a couple errors…
                                        but you should be able to see that code in the developers window, sources tab,
                                        navigate on the left tree, modules, your module_name (which has to be perchamp,
                                        folder, filename and the register at the top) all have to match)
                                          Perlchamp
                                          i can’t find … so everything’s right ?
                                            sdetweil @Perlchamp
                                            @Perlchamp you shouldScreenshot at 2020-05-01 18-12-15.png see an error like this
                                            note that I put part of the module name in the filter field
                                            • 6
                                            • 7
                                            • 15
                                            • 16
                                            • 5 / 16
