    read csv-data and put it in an array
    313 Posts 3 Posters 540.1k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp its not my module… its yours…
        sdetweil @Perlchamp
        @Perlchamp see how interesting ‘just a birthday list’ can be! and u still have styles to apply etc
        • PerlchampP Offline
          Perlchamp
          I do not think so. I could never answer questions about any problems …
          i did:
          ... age='+(person.age + 1);
          the styles you could get from me, no problem. it’s just fair, isn’t it ?
            sdetweil @Perlchamp
            @Perlchamp should be wrong for people with birthday yesterday
              Perlchamp
              ah, oooook … hm. shooted to fast. but let me figured out by myself, cause i don’t wonna feel like a baby … i think if-statements and moment() could be helpfully.
                Perlchamp
                general question:
                is there something like “print”? (for debugging) or have i use innerText or innerHTML or Log.log ? … to display something on screen ?
                  sdetweil @Perlchamp
                  @Perlchamp Log.log only
                  did u see my chat message about fixing a bug in the MMM-Logging module
                    Perlchamp
                    i will have a look on it, though MERCI !
                      sdetweil @Perlchamp
                      @Perlchamp one other thing, u need to start a timer for when the month changes, when the timer expires, send a CONFIG message to the node_helper and it will send the latest birthdays list and everything will recalculate
                        Perlchamp
                        hi sam, yes i thought about. in the moment this is the actually file, though there is code annotate and at the wrong place, … just so you don’t wonder … :
                        /* global Module */
                        /* Magic Mirror
                         * Module: birthdaylist
                         * Author: perlchamp@gmx.net
                         * Lizenz: MIT
                        Module.register("birthdaylist", {
                            // Default module config.
                            defaults: {
                        	debugging: false,
                        	initialLoadDelay: 0,		// How many seconds to wait on a fresh start up.
                        					// This is to prevent collision with all other modules also
                        					// loading all at the same time. This only happens once,
                        					// when the mirror first starts up.
                        	dimmEntries: true,   		// true: dims entries and the associated
                        					//       symbol when the date has expired.
                        					// false: delete entries and the associated
                        	language: "de",			// needed for dateformatting
                        	updateDelay: 5		        // How many seconds after midnight before a refresh
                        				        // This is to prevent collision with other modules refreshing
                        				        // at the same time.
                            active_birthdays: {
                            init: function() {
                        	Log.log(this.name + " is in init!");
                            // Override start method
                            start: function() {
                        	Log.log("Starting module: " + this.name);
                        	// set locale here, default: de
                        	moment.locale(config.language);
                        	// Calculate next midnight and add updateDelay
                        	var now = moment();
                        	this.midnight = moment([now.year(), now.month(), now.date() + 1]).add(this.config.updateDelay, "seconds");
                        	this.loaded = false;
                        	this.scheduleUpdate(this.config.initialLoadDelay * 1000);
                            loaded: function(callback) {
                        	Log.log(this.name + " is loaded!");
                        	callback();
                            // return list of other functional scripts to use, if any (like require in node_helper)
                            getScripts: function () {
                        	return ["moment.js"];
                            // return list of stylesheet files to use if any
                            getStyles: function() {
                        	return [this.data.path + "/css/bdl.css"];
                            // you can configure the heading of the list in config.js
                            getHeader: function() {
                        	return this.data.header;
                            // messages received from other modules and the system (NOT from your node helper)
                            // payload is a notification dependent data structure
                            notificationReceived: function(notification, payload, sender) {
                        	// once everybody is loaded up
                        	if(notification === "ALL_MODULES_STARTED") {
                        	    // send our config to our node_helper
                        	    this.sendSocketNotification("CONFIG",this.config);
                        	if (sender) {
                        	    Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                        	else {
                        	    Log.log(this.name + " received a system notification: " + notification);
                            // messages received from from your node helper (NOT other modules or the system)
                            // payload is a notification dependent data structure, up to you to design between module and node_helper
                        	if(notification === "JSONDATA") {
                        	    var self = this;
                        	    Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                        	    var now = moment();
                        	    var day_month = moment().format("DD");
                        	    for(var birthday of payload) {
                        		// get 1st 5 chars of birthdate, thru month
                        		// we will use this as the key in the hash
                        		var birth_date = birthday.birth.substring(0,5);
                        		// get the birthday as a moment in this year, for comparing
                        		var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
                        		// you can add days to a moment object and then compare
                        		//     if the birthdate is before that date (and after now)
                        		//     so within the next xx days
                        		// if the date is the same or later, don't use time of day
                        		if(birth_date_moment.month() == now.month() ) {
                        		    // birthday is in this month
                        		    // check the hash if we've seen anything for today yet
                        		    // if we haven't see this date yet
                        		    if(this.active_birthdays[birth_date] == undefined) {
                        			// create the holder for its info (array of
                        			//	names) in the hash
                        			this.active_birthdays[birth_date] = [];
                        		    // save the persons name on the list
                        		    self.active_birthdays[birth_date].push({'name':birthday.name,
                        			'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
                        	    // tell MM to call and get our content
                        	    self.updateDom();
                            // system notification your module is being hidden
                            // typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                            suspend: function() {
                            // system notification your module is being unhidden/shown
                            // typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                            resume: function() {
                            // this is the major worker of the module, it provides the
                            // 	   displayable content for this module
                            getDom: function() {
                        	var self = this;
                        	Log.log(JSON.stringify(this.active_birthdays))
                        	if ((moment() > this.midnight) || (!this.loaded)) {
                        	    var month = moment().month();
                        	    var year = moment().year();
                        //	    var monthName = moment().format("MMMM");
                        //	    var monthLength = moment().daysInMonth();
                        	    // tabelle erstellen
                        	    var wrapper = document.createElement("table");
                        	    wrapper.className = 'table';
                        	    wrapper.id = 'birthday-table';
                        	    // tabellenkopf erstellen
                        	    var tHeader = document.createElement("thead");
                        	    tHeader.className = "thead";
                        	    tHeader.id = "birthday-thead";
                        	    var headerTR = document.createElement("tr");
                        	    headerTR.className = "tr-head";
                        	    headerTR.id = "birthday-tr-head";
                        	    var headerTH = document.createElement("th");
                        	    headerTH.colSpan = "2";
                        	    headerTH.scope = "col";
                        	    headerTH.className = "th-head";
                        	    headerTH.id = "birthday-th-head";
                        	    headerTH.innerHTML = this.translate(this.config.title);
                        	    headerTR.appendChild(headerTH);
                        	    tHeader.appendChild(headerTR);
                        	    wrapper.appendChild(tHeader);
                        	    // Create TFOOT section -- currently used for debugging only
                        	    var tFooter = document.createElement('tfoot');
                        	    tFooter.className = "tfoot";
                        	    tFooter.id = "birthday-tfoot";
                        	    var footerTR = document.createElement("tr");
                        	    footerTR.className = "tr-foot";
                        	    footerTR.id = "birthday-tr-foot";
                        	    var footerTD = document.createElement("td");
                        	    footerTD.colSpan ="2";
                        	    footerTD.className = "td-foot";
                        	    footerTD.id = "birthday-td-foot";
                        	    if (this.config.debugging) {
                        		footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
                        	    else {
                        		footerTD.innerHTML = "";
                        	    footerTR.appendChild(footerTD);
                        	    tFooter.appendChild(footerTR);
                        	    wrapper.appendChild(tFooter);
                        	for(var birthday of Object.keys(this.active_birthdays)) {
                        	    for(var person of this.active_birthdays[birthday]) {
                        		var m=document.createElement('div');
                        		// create tour table row here
                        		m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                        		wrapper.appendChild(m);
                        	// pass the created content back to MM to add to DOM.
                        	this.loaded = true;
                        	return wrapper;
                        	    // Create TBODY section with day names
                        	    var eintraege = 3;
                        	    for (var i=1; i<=eintraege; i++) {
                        		var tBody = document.createElement("tBody");
                        		tBody.className = "tbody";
                        		tBody.id = "birthday-tbody";
                        		var bodyTR = document.createElement("tr");
                        		bodyTR.className = "tr-body";
                        		bodyTR.id = "birthday-tr-body";
                        		var bodyTDimage = document.createElement("td");
                        		bodyTDimage.className = "td-image";
                        		bodyTDimage.id = "birthday-td-image";
                        		bodyTDimage.innerHTML = "23";
                        		var bodyTD = document.createElement("td");
                        		bodyTD.className = "td-body";
                        		bodyTD.id = "birthday-td-body";
                        		bodyTD.innerHTML = "Bettina Zimmermann&nbsp;&nbsp;<span class=\"age-span\">46</span></br>Frank Dubiel&nbsp;&nbsp;<span class=\"age-span\">54</span></br>Jürgen Gruse&nbsp;&nbsp;<span class=\"age-span\">52</span>";
                        //		var bodyAgeSpan = document.createElement("span");
                        //		bodyAgeSpan.className = "age-span";
                        //		bodyAgeSpan.id = "birthday-age-span";
                        //		bodyAgeSpan.innerHTML = "&nbsp;&nbsp;46";
                        //		bodyTD.appendChild(bodyAgeSpan);
                        		bodyTR.appendChild(bodyTDimage);
                        		bodyTR.appendChild(bodyTD);
                        		tBody.appendChild(bodyTR);
                        		wrapper.appendChild(tBody);
                            scheduleUpdate: function(delay) {
                        	    Log.log("= = = = = = = = = = = = = = = = = = = = = = = = = = = = = =");
                        	    Log.log("Birthdaylist IS IN DEBUG MODE!");
                        	    Log.log("Remove 'debugging' option from config/config.js to disable.");
                        	    Log.log("Current moment(): " + moment() + " (" + moment().format("hh:mm:ss a") + ")");
                        	    Log.log("scheduleUpdate() delay set at: " + delay);
                        	if (typeof delay !== "undefined" && delay >= 0) {
                        	    nextReload = delay;
                        	if (delay > 0) {
                        	    // Calculate the time DIFFERENCE to that next reload!
                        	    nextReload = moment.duration(nextReload.diff(moment(), "milliseconds"));
                        		var hours = Math.floor(nextReload.asHours());
                        		var  mins = Math.floor(nextReload.asMinutes()) - hours * 60;
                        		var  secs = Math.floor(nextReload.asSeconds()) - ((hours * 3600 ) + (mins * 60));
                        		Log.log("  nextReload should happen at: " + delay + " (" + moment(delay).format("hh:mm:ss a") + ")");
                        		Log.log("                  which is in: " + mins + " minutes and " + secs + " seconds.");
                        		Log.log("              midnight set at: " + this.midnight + " (" + moment(this.midnight).format("hh:mm:ss a") + ")");
                        	var self = this;
                        	setTimeout(function() {
                        	    self.reloadDom();
                        	}, nextReload);
                            reloadDom: function() {
                        	    Log.log("          Calling reloadDom()!");
                        	var now = moment();
                        	if (now > this.midnight) {
                        	    this.updateDom(this.config.fadeSpeed * 1000);
                        	var nextRefresh = moment([now.year(), now.month(), now.date(), now.hour() + 1]);
                        	this.scheduleUpdate(nextRefresh);
                        and thanks agaibn for your time …
                          sdetweil @Perlchamp
                          @Perlchamp awesome…
                            Perlchamp
                            i although thought about to include a template, but first i want to figure out the html-stuff and the if … than -statements (people the same day, date passed, and so on …), but you see i’m on fire right now …
                              sdetweil @Perlchamp
                              @Perlchamp cool… i did the age correction
                                Perlchamp
                                cool too :-) , so you still burn, too :-))
                                  Perlchamp
                                  hi sam, i know that the code of table is working (in testmodule). but can’t get objects in there. did look in dev-widow, but looks fine. in the terminal-window i see that objects have been handed over (node to module.js). this is the code for the body of the table:
                                  	    // create TBODY section with day names
                                  		    //var m = document.createElement('div');
                                  		    // create looped row section
                                  		    bodyTDimage.innerHTML = birthday;
                                  		    bodyTD.innerHTML = person.name + "<span class=\"age-span\">" + person.age + "</span>";
                                  		    //m.innerText = birthday + ' ' + person.name + ' age=' + person.age;
                                  		    //wrapper.appendChild(m);
                                  what did i make wrong ?
                                    Perlchamp
                                    @Perlchamp said in read csv-data and put it in an array:
                                    bodyTD.innerHTML = person.name + “” + person.age + “”;
                                    should be:
                                    bodyTD.innerHTML = person.name + span class = … + person.age + /span;
                                    can’t send html tags here ? how i have to escape them here ?
                                      sdetweil @Perlchamp
                                      @Perlchamp cannot escape tags here, long time complaint
                                        Perlchamp
                                        did it !
                                        this.loaded = true; was wrong placed …
                                          Perlchamp
                                          but this does not work yet:
                                          		    if (birthday.charAt(0) === "0") {
                                          			birthday = birthday.replace("0","");
                                          			birthday = birthday.substring(0,1);
                                          		    bodyTDimage.innerHTML = birthday.substring(0,2);
                                          the value will not displayed, but i will find a way. my code yet is far away from a smart code :-))
                                            Perlchamp
                                            this is the status at the moment :
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
