read csv-data and put it in an array
313 Posts 3 Posters 408.1k Views 4 Watching
  • P Offline
    Perlchamp
    why for TODAY ? and not for current MONTH ?
    getDon:
    	getDom: function() {
    		var self = this;
    		// tell MM to call and get our content
    Log.log("LOOK >>>>>>" + JSON.stringify(this.active_birthdays))    // add this line
    			self.updateDom();                          // before this line in the notification code..
    		for(var birthday of Object.keys(this.active_birthdays)) {
    			for(var name of this.active_birthdays[birthday]) {
    				var m = document.createElement("div");
    				Log.log("BIRTHDAY >> " + birthday);
    				Log.log("NAME >> " + name);
    				m.innerText = birthday + " " + name;
    				wrapper.appendChild(m);
    		// pass the created content back to MM to add to DOM.
    		return wrapper;
    S 1 Reply Last reply May 2, 2020, 4:06 PM Reply Quote 0
    • S Away
      sdetweil @Perlchamp
      @Perlchamp said in read csv-data and put it in an array:
      Log.log(“LOOK >>>>>>” + JSON.stringify(this.active_birthdays)) // add this line
      self.updateDom();
      not that way
      			      // save the persons name and age on the list
      			      self.active_birthdays[birth_date].push({'name':birthday.name, 'age': now.diff(moment(birthday.birth,'DD.MM.YYYY'), 'years') })
      Log.log(JSON.stringify(this.active_birthdays))		  // add this line
      sorry, didn’t see the ‘month’.
      still doesn’t matter, that birthday is for january, so nothing to show for may
      change this compare to do only month
      		  // if the date is the same or later, don't use time of day
      		   if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
      		   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))
      hint, google get month from moment
      • P Offline
        Perlchamp
        i got this:
        [2020-05-02 18:10:50.465] [LOG]    {} (/home/dirk/MagicMirror/modules/MMM-Logging/node_helper.js:34 Class.socketNotificationReceived)
        for each entry. i have 5 birthdays in may …
        S 1 Reply Last reply May 2, 2020, 4:17 PM Reply Quote 0
        • S Away
          sdetweil @Perlchamp
          @Perlchamp look in the console log, MMM-Logging is redirecting everything there
          my mmm-logging config
                      module: 'MMM-Logging',
                      disabled: false,
                          // Module functions out of the box with nothing set here.
                          // See below for configurable options.
                          echoLocal: true,
                          echoRemote: true,
                          overwriteBrowserMethods: true,
                          format: "{{message}} ({{folder}}/{{file}}:{{line}} {{method}})",
          • P Offline
            Perlchamp
            i could send you the three files (node_helper.js, MMM-Perlchamp.js, birthdays.csv) via email ?
            S 1 Reply Last reply May 2, 2020, 4:25 PM Reply Quote 0
            • S Away
              sdetweil @Perlchamp
              @Perlchamp sent chat message
              • P Offline
                Perlchamp
                node_helper.js:
                var NodeHelper = require("node_helper");
                var moment = require("moment");
                // add require of other javascripot components here
                // var xxx = require('yyy'); here
                const csv = require("csvtojson");
                var birthdaysArray = [];
                	init(){
                		console.log("init module helper MMM-Perlchamp");
                	start() {
                	stop(){
                		console.log("Stopping module helper: ",this.name);
                	// handle messages from our module// each notification indicates a different messages
                	// payload is a data structure that is different per message.. up to you to design this
                	socketNotificationReceived(notification, payload) {
                		var self = this;
                		console.log("Starting module helper: ",this.name);
                		// convert the csv-file into a JSON-String
                		const csvFilePath = this.path + '/data/birthdays.csv';
                		csv()
                		.fromFile(csvFilePath)
                		.then(function(jsonObj) {
                			JSON.stringify(jsonObj);
                			// send data to [modulname].js
                			self.sendSocketNotification("HAVEDATA", jsonObj);
                		// if config message from module
                		if (notification === "CONFIG") {
                			// save payload config info
                			this.config = payload;
                			// wait 15 seconds, send a message back to module
                			setTimeout(()=> {this.sendSocketNotification("message_from_helper"," this is a test_message")}, 15000);
                		else if(notification === "????2") {
                MMM-Perlchamp.js:
                Module.register("MMM-Perlchamp", {
                	defaults: {
                		language: "de",
                		dimmEntries: true   // true: dims entries and the associated
                							//       symbol when the date has expired.
                							// false: delete entries and the associated
                	active_birthdays: {
                	init: function(){
                		Log.log(this.name + " is in init!");
                	start: function(){
                		Log.log("Starting module: " + this.name);
                		// Set locale
                		moment.locale(config.language);
                	loaded: function(callback) {
                		Log.log(this.name + " is loaded!");
                		callback();
                	// return list of other functional scripts to use, if any (like require in node_helper)
                	getScripts: function() {
                		return	["moment.js"];
                	// return list of stylesheet files to use if any
                	getStyles: function() {
                		return 	[this.data.path + "/css/MMM-Perlchamp.css"];
                	// only called if the module header was configured in module config in config.js
                	getHeader: function() {
                		return this.data.header;
                	// messages received from other modules and the system (NOT from your node helper)
                	// payload is a notification dependent data structure
                	notificationReceived: function(notification, payload, sender) {
                		// once everybody is loaded up
                		if(notification === "ALL_MODULES_STARTED"){
                			// send our config to our node_helper
                			this.sendSocketNotification("CONFIG",this.config);
                		if (sender) {
                			Log.log(this.name + " received a module notification: " + notification + " from sender: " + sender.name);
                		} else {
                			Log.log(this.name + " received a system notification: " + notification);
                	// messages received from from your node helper (NOT other modules or the system)
                	// payload is a notification dependent data structure, up to you to design between module and node_helper
                		if(notification === "HAVEDATA") {
                			var self = this;
                			Log.log(this.name + " received a socket notification: " + notification + " - Payload: " + payload);
                			var now = moment();
                			for(var birthday of payload) {
                				// get 1st 5 chars of birthdate, thru month
                				// we will use this as the key in the hash
                				var birth_date = birthday.birth.substring(0,5);
                				// get the birthday as a moment in this year, for comparing
                				var birth_date_moment = moment(birth_date + now.year(),"DD.MMYYYY");
                				// u can add days to a moment object and then compare
                				//     if the birthdate is before that date (and after now)
                				//     so within the next xx days
                		   	  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))) {
                					// birthday is in this month
                					// check the hash if we've seen anything for today yet
                					// if we haven't see this date yet
                					if(this.active_birthdays[birth_date] == undefined){
                						//  create the holder for its info (array of
                						//		names) in the hash
                						this.active_birthdays[birth_date] = [];
                					// save the persons name on the list
                //					this.active_birthdays[birth_date].push(birthday.name);
                			Log.log("this.active_birthdays >>>>> ", this.active_birthdays);
                //			var currentMonth = new Date().toLocaleDateString('en', {month:'2-digit'});
                			var currentMonth = moment().format("MM");
                			var result = Object.entries(payload
                			.filter(({birth}) => birth.split('.')[1] === currentMonth)
                			.reduce((a, {birth, name}) => {
                				const day = +birth.split('.')[0];
                				a[day] = [...(a[day] || []), name];
                				return a
                			).map(([day, name]) => ({day, name})).sort((a, b) => +a.day - b.day);
                			console.log("LISTE >> ", result);
                			self.updateDom();
                	// system notification your module is being hidden
                	// typically you would stop doing UI updates (getDom/updateDom) if the module is hidden
                	suspend: function() {
                	// system notification your module is being unhidden/shown
                	// typically you would resume doing UI updates (getDom/updateDom) if the module is shown
                	resume: function() {
                	// this is the major worker of the module, it provides the displayable content for this module
                		var self = this;
                		return wrapper;
                birthdays.csv in folder MMM-Perlchamp/data:
                birth,name
                03.01.1940,aaa AAAAA
                06.01.1969,bbb BBBBB
                15.02.1939,ccc CCCCC
                07.03.1972,ddd DDDDD
                10.05.1969,eee EEEEE
                16.05.2012,fff FFFFF
                16.05.1988,ggg GGGGG
                27.05.2002,hhh HHHHH
                08.07.1976,iiii IIIII
                13.07.1914,jjj JJJJJ
                27.08.1968,kkk KKKKK
                21.09.1967,lll LLLLL
                13.10.1965,mmm MMMMM
                16.10.2010,nnn NNNNN
                23.10.1941,ooo OOOOO
                19.12.1935,ppp PPPPP
                MMM-Perlchamp.css in folder MMM-Perlchamp/css
                .MMM-Perlchamp header {
                  letter-spacing: 0.1em;
                  text-transform: uppercase;
                  font-size: 20px;
                  font-family: "Roboto Condensed", Arial, Helvetica, sans-serif;
                  font-weight: 400;
                  border-bottom: 1px solid #444444;
                  line-height: 20px;
                  padding-bottom: 5px;
                  color: #ffffff;
                  font-variant: small-caps;
                S 1 Reply Last reply May 2, 2020, 4:44 PM Reply Quote 0
                • S Away
                  sdetweil @Perlchamp
                  yes it only shows for today+some possible offset… I said u had to fix that to do month comparison
                  • P Offline
                    Perlchamp
                    shame on me, sorry for that. now it’s changed to:
                    if(birth_date_moment.startOf('month').isSameOrAfter(now.startOf('month')) &&
                    					birth_date_moment.startOf('month').isSameOrBefore(birthday_time_window.startOf('month'))) {
                    nothing changed, i have configured the terminal-window to scroll about 3000 (!) lines, but can’t see the beginning …
                    S 1 Reply Last reply May 2, 2020, 4:58 PM Reply Quote 0
                    • S Away
                      sdetweil @Perlchamp
                      @Perlchamp redirect the terminal window to a file and edit that
                      do this in the code
                      			 	//if(birth_date_moment.startOf('day').isSameOrAfter(now.startOf('day')) &&
                                                      //  birth_date_moment.startOf('day').isSameOrBefore(birthday_time_window.startOf('day'))) {
                      			   	if( birth_date_moment.month() == now.month() ){
                      • 15
                      • 16
                      • 17
                      • 18
                      • 19
                      • 31
                      • 32
                      • 17 / 32
                      17 / 32
