    read csv-data and put it in an array
    313 Posts 3 Posters 460.2k Views 4 Watching
    • PerlchampP Offline
      Perlchamp
      done, it’s frozen now. must restart …
        Perlchamp
        question:
        in the
        		if(notification === "HAVEDATA") {
        			var self = this;
        payload should be the variable in which the jsonString is saved ?
          sdetweil @Perlchamp
          @Perlchamp it has the jsonObj from the node_helper
          u can call it anything, its just a name
          so, if you put a stop right on the var self = this
          and then cursor over the work payload in
          it will show you that object content, and u can go up and click on parts to make them expand to examine the contents
            Perlchamp
            ok, there is a light at the end of the tunnel:
              sdetweil
              code was changed to add ages
              in getDom()
              			for(var name of this.active_birthdays[birthday]) {
              				var m = document.createElement("div");
              				Log.log("BIRTHDAY >> " + birthday);
              				Log.log("NAME >> " + name);
              				m.innerText = birthday + " " + name;
              				wrapper.appendChild(m);
              now is
              			for(var person of this.active_birthdays[birthday]){
              				var m=document.createElement('div')
              // create your table row here
              				m.innerText=birthday+ ' '+ person.name+' age='+person.age
                Perlchamp
                great, thanks !
                to your information:
                there are NO semikolons in your posted code. within them it goes !
                  sdetweil @Perlchamp
                  @Perlchamp end of line ; are not required… I cut/pasted that code out of the running module
                    Perlchamp
                    without i have a black screen, with everythings fine.
                    another information:
                    age must be +1 but i think i will solve this alone. if not i’m too stuipid for this all :-)
                    so i can create my table now. but i see:
                    people who has birthday the same day:
                    date should be displayed once, and the names in the same , separated by
                      sdetweil @Perlchamp
                      @Perlchamp ok, I think you can fix those… age is a date diff()… add to results
                      edit: age needs more work that just number… because they were comparing MONTH, but age was exact days.
                      so I change my bd to may, but TODAY I am 68… in may i WILL BE 69 (in the future)
                      so if TODAY or before, do NOT add one, if tomorrow or after (in the month) add 1
                        Perlchamp
                        i think, too. thanks very much, sam. I don’t know how to thank you Thank you very much !
                        you’re great !
                        and it is up to you whether you publish this module. I will not adorn myself with foreign feathers!
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 31
                        • 32
                        • 18 / 32
