    read csv-data and put it in an array
    313 Posts 3 Posters 540.0k Views 4 Watching
      sdetweil @Perlchamp
      @Perlchamp
      updated
      	getDom: function(){
      		var wrapper = this.createEl("div",null,null,null);
      		if(Object.keys(this.active_birthdays).length>0){
      			// create your table  here
      			var table = this.createEl("table", "birthday-table", null, wrapper );
      			// table header here, array of column names
      			var table_header=this.createTableHeader(table,null, ["date","Name","age"])
      			// create looped row section
      			var tBody = this.createEl('tbody', "birthday-t-body", "tbody", table, null);
      			var birthdays_seen= {}
      			for(var birthday of Object.keys(this.active_birthdays)) {
      			    for(var person of this.active_birthdays[birthday]) {
      					var bodyTR = this.createEl('tr', null, "TR-BODY" ,tBody, null);
      					let now = moment().format('DD.MM').valueOf();
      					let entrie=now
      				    if(this.config.dimmEntries) {
      						entrie = moment(birthday,'DD.MM').valueOf();
      					var bd = "";
      			    	if(birthdays_seen[birthday]==undefined){
      						bd =(birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
      						var imageTD = this.createEl('td', null, "TD-IMAGE_"+(entrie < now)?"DIMMED":'' , bodyTR, bd);
      						var nameTD = this.createEl('td', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' , bodyTR, person.name);
      									 this.createEl("span", null, null, nameTD, " ");						// needs class for width
      						var spanTDo = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', nameTD, person.age);
      					else{
      						// add a break
      						this.createEl('br', null , null , spanTDo,null);
      						// add a span with name
      						var nameTD = this.createEl('span', null, "TD-BODY_"+(entrie < now)?"DIMMED":'' ,spanTDo, person.name);
      						// add a span with age
      						var spanTD = this.createEl("span", null, "TD-AGE_"+(entrie < now)?"DIMMED":'', spanTDo, person.age);
      					var spacerTR = this.createEl('tr', null, null , tBody, null);
      					var spacerTD = this.createEl('td', null, "SPACER" , spacerTR, " ");
      					spacerTD.colSpan = "2";
      					birthdays_seen[birthday] = true;
      		return wrapper;
      if we see 1st time br, do date, name/span/age
      if second time add line break to old name list
      add span for name, span span for separator (need class for width), span for age
      • PerlchampP Offline
        Perlchamp
        first i have to change my classes ? instead of TD-IMAGE TD-IMAGE_, ?
          sdetweil @Perlchamp
          @Perlchamp the classname is a string
          and the front part is the same
          so , you had duplicated code, just to change the classname…
          I just used your if(entrie) to decide it the name needed the’DIMMED" part added
          move the _ to the “DIMMED”, like this “_DIMMED”
          then they will be TD-IMAGE and TD-IMAGE_DIMMED , just like you had it…
          its the same row data and parentage, just a class change… (nice work having common names, so you could do this), got rid of that big else…
            Perlchamp
            css i don’t get to work. here’s my getDom:
            getDom: function() {
            	var wrapper = this.createEl("div",null,null,null,null);
            	// tell MM to call and get our content
            	Log.log(JSON.stringify(this.active_birthdays));
            	if ((moment() > this.midnight) || (!this.loaded)) {
            	    var month = moment().month();
            	    var year = moment().year();
            	    var monthName = moment().format("MMMM");
            	    var monthLength = moment().daysInMonth();
            	    var now = moment();
            	    if(Object.keys(this.active_birthdays).length > 0) {
            		// create table
            		var table = this.createEl("table", "birthday-table", "TABLE" , wrapper,null)
            		// create tableheader here, array of column names
            		var table_header = this.createTableHeader(table, null, [" "," "]);
            		// create TBODY section with day names
            		var tBody = this.createEl('tBody', "birthday-tbody", "TBODY" , table, null);
            		var spacer = " ";
            			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY" , tBody, null);
            			let entrie=now;
            			// delete leading 0 and month
            			var bd = "";
            			if(birthdays_seen[birthday] == undefined) {
            			    bd = (birthday.startsWith("0")? birthday.substring(1): birthday).split('.')[0];
            			    var imageTD = this.createEl('td', null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
            			    var nameTD = this.createEl('td', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' , bodyTR, person.name);
            			    var spanTDo = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', nameTD, person.age);
            			else{
            			    // add a break
            			    var nameTD = this.createEl('span', null, "TD-BODY" + (entrie < now)?"_DIMMED":'' ,spanTDo, person.name);
            			    var spanTD = this.createEl("span", null, "TD-AGE" + (entrie < now)?"_DIMMED":'', spanTDo, person.age);
            		// Create TFOOT section -- currently used for debugging only
            		if (this.config.debugging) {
            		    var table_footer = this.createTableFooter(tBody, null, [" "," "]);
            		    //footerTD.innerHTML = "Birthdaylist is currently in DEBUG mode!<br />Please see console log.";
            		else {
            	    // pass the created content back to MM to add to DOM.
            	    return wrapper;
            	// Dom is loaded
            	this.loaded = true;
            there should be an error i don’t see.
              sdetweil @Perlchamp
              @Perlchamp use the debugger, expand the elements tree, find the table and look at the classes assigned
                Perlchamp
                hi sam,
                if i do this:
                   var imageTD = this.createEl("td", null, "TD-IMAGE", bodyTR, bd);
                instead of this :
                var imageTD = this.createEl("td", null, "TD-IMAGE" + (entrie < now)?"_DIMMED":'' , bodyTR, bd);
                css are addressed. maybe something has to change in the createEl function ?
                  sdetweil @Perlchamp
                  @Perlchamp let me look…
                    sdetweil @Perlchamp
                    @Perlchamp
                    warning one ( was missing, fixed
                    SORRY… tested now… the + append didn’t work, had to force with concat()…
                    Its the two values, now and entrie
                    				let now = moment().format('DD.MM').valueOf();				 // this is string dd.mm
                    				let entrie=now
                    					entrie = moment(birthday,'DD.MM').format.valueOf();     // this is a moment
                    so later when compared, it doesn;t work
                    and comparing strings with < doesn’t really work…
                    I would do
                    let now=moment()
                    let entrie = moment(birthday,‘DD.MM’)
                    then in the compare
                    (entrie.isBefore(now))?..
                    	getDom: function(){
                    					let now = moment()
                    					let entrie=now
                    					var bd = "";
                    						var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, bd);
                    						var nameTD = this.createEl('td', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') , bodyTR, person.name);
                    						var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), nameTD, person.age);
                    					else{
                    						// add a break
                    						var nameTD = this.createEl('span', null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'') ,spanTDo, person.name);
                    						var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":''), spanTDo, person.age);
                    		return wrapper;
                      @Perlchamp see my update above
                        Perlchamp
                        @sdetweil said in read csv-data and put it in an array:
                        sorry, doesn’t work. blackscreen. if i change back (my post) css is addressed. i didn’t change the jet = part. i think, something’s wrong with the cerateEl function, but you know i’m not an expert.but to control. here is my code :
                        			var bodyTR = this.createEl('tr', "birthday-tr-body", "TR-BODY", tBody, null);
                        			let now = moment();
                        			let entrie = moment(birthday,"DD.MM");
                        			    entrie = moment(birthday,'DD.MM');
                        			var bd = "";
                        			    //var imageTD = this.createEl('td', null, "TD-IMAGE".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, bd);
                        			    //var nameTD = this.createEl("td", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'', bodyTR, person.name);
                        			    var nameTD = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                        			    this.createEl("span", null, "TD-AGE", nameTD, " ");
                        			    //var spanTDo = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTD, person.age);
                        			    var spanTDo = this.createEl("span", null, "TD-AGE", nameTD, person.age);
                        			else{
                        			    // add a break
                        			    this.createEl("br", null , null , spanTDo, null);
                        			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',spanTDo, person.name);
                        			    var nameTD = this.createEl("span", null, "TD-BODY", spanTDo, person.name);
                        			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', spanTDo, person.age);
                        			    var spanTD = this.createEl("span", null, "TD-AGE", spanTDo, person.age);
                        			var spacerTR = this.createEl("tr", null, null , tBody, null);
                        			var spacerTD = this.createEl("td", null, "SPACER", spacerTR, " ");
                          sdetweil @Perlchamp
                          @Perlchamp ah well. both work here… your latest and mine produce the same results
                          your output
                          date	Name	age
                          12	Sam 69
                          2	Frank 81
                          Sue81
                          5	mary 65
                          10	eee EEEEE 51
                          16	fff FFFFF 8
                          ggg GGGGG32
                          27	hhh HHHHH 18
                          my output
                          date	Name	age
                          12	Sam 69
                          2	Frank 81
                          Sue81
                          5	mary 65
                          10	eee EEEEE 51
                          16	fff FFFFF 8
                          ggg GGGGG32
                          27	hhh HHHHH 18
                            Perlchamp
                            what does that mean? but you don’t use css, do you ? YES, but didn’t you see, that i have annotate the
                            lines in the code, i posted ? without entrie.isBefore … css is addressed, with it’s not addressed
                              sdetweil @Perlchamp
                              @Perlchamp I stepped thru and watched it change from with dimmed and without
                                Perlchamp
                                sorry for nerving, sam. i would like to understand the code. where is the part in which the name and age of people with the same birthday are collected/combined ?
                                  sdetweil @Perlchamp
                                  @Perlchamp I’ll use you last code post
                                  // loop thru all the brithdays found in the file that match this month, one at a time
                                                      // each row is a person
                                                          // create a row
                                                          // get timne/date of now
                                  			let now = moment();
                                                          // we need to change the style to dimmed,. if the BD is in the past
                                  			//let entrie = moment(birthday,"DD.MM");                      // < --- problem
                                                          // assume the birthday is NOT in the past
                                  			let entrie = now
                                                          // if the user requested dimming
                                                              // get the brithdate in this year 01.05.2020
                                                              // note the value WAS the SAME as 'now'
                                                          // set the default value for the birthdate display
                                  			var bd = "";  // assume we don't need to display it
                                     			// if we have not seen this birthdate in the loop so far, its the fiist time
                                                              // so we need the number of the day of the month
                                                             // if it starts with 0, get from char 1 on sop 01.05 becomes 1.05, then
                                                             // use split to get the parts [ 1, 05]
                                                             // if not '0', use all bd numbers 12.05, and split to [12,05]
                                                             // and take the 1st element of array
                                                             // 1, or 12, for the two examples
                                                              // now we need a row of data for the the person
                                                              // class name is either TD-IMAGE or TD-IMAGE_DIMMED
                                                              // use the two moments to compare (the fix for the entrie= now above will fix this)
                                                              // if the persons ds is before now, and we want dimmed, then add the tail of the class name on
                                                              // else use this the name (concat('') - add nothing))
                                                              // this  entrie.isBefore(now)?'_DIMMED':'' means
                                                              // the result of the expression is entrie before now
                                                              // if true return '_DIMMED'
                                                              // if false return ''
                                                              // "TD-IMAGE".concat() this means add onto the string "TD-IMAGE" whatever is inside the concat() parens, either '_DIMMED' or ''
                                                              // so the class will be TD-IMAGE (for people with bithrdays ON or AFTER today)
                                                              // or TD-IMAGE_DIMMED for people with birthdays BEFORE today
                                  			    var nameTDo = this.createEl("td", null, "TD-BODY", bodyTR, person.name);
                                  			    //var spanTD = this.createEl("span", null, "TD-AGE".concat(entrie.isBefore(now)?"_DIMMED":'', nameTDo, person.age);
                                  			    var spanTD = this.createEl("span", null, "TD-AGE", nameTD0, person.age);
                                  			else{
                                                               // we HAVE seen the birthday before, the row is already created, so we need to add to the END THAT ROW, ie after the span of the previous person
                                  			    // add a break (to the end of the TD for the name (has span already for age)
                                  			    this.createEl("br", null , null , nameTDo, null);
                                  			    //var nameTD = this.createEl("span", null, "TD-BODY".concat(entrie.isBefore(now)?"_DIMMED":'',nameTDo, person.name);
                                                              //  add a span for the persons name (after the line break
                                  			    var nameTD = this.createEl("span", null, "TD-BODY", nameTDo, person.name);
                                  			    // add a span with for spacing
                                  			    var spanTD = this.createEl("span", null, "TD-AGE", nameTDo, person.age);
                                                              // if we have another person with the same BD, new stuff will be added after this span
                                                          // regardless of 1st or second, we have seen this birthdaty
                                    @Perlchamp my code had
                                    					let now = moment()
                                    					let entrie=now
                                    					var bd = "";
                                      Perlchamp
                                      thanks a lot. i will study this …
                                        sdetweil @Perlchamp
                                        @Perlchamp make that one fix and then my code will work too
                                          Perlchamp
                                          update !
                                          i tried, but how should i do this ?
                                          i was in the dev. didn’t helped me. it’s , how said, the part
                                          with => blackScreen
                                          without => working (formatted => css).
                                            sdetweil @Perlchamp
                                            @Perlchamp have to edit the source code, then reload the browser page, cannot edit in debugger
                                            let now = moment()
                                            					let entrie=now   // <-- this line was not included in yours..   i commented
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 15 / 16
